a l'aide ,bluescreen!!!!!!!
antoninhavy
Message par antoninhavy »
bonjour a tous je m appel antonin et je viens d avoir un plantage (arrêt non programmé bluesreen) ,je viens dinstaller whocrashred et voila se qu'il me dit:
Crash dump directory: E:\Windows\Minidump
On Thu 10/03/2011 23:55:10 GMT your computer crashed
crash dump file: E:\Windows\Minidump\031111-19702-01.dmp
This was probably caused by the following module: bdselfpr.sys (bdselfpr+0x299B)
Bugcheck code: 0x50 (0xFFFFFFFFD7E0D018, 0x0, 0xFFFFFFFFA738399B, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: E:\Program Files\BitDefender\BitDefender 2011\bdselfpr.sys
product: BitDefender Firewall
company: BitDefender LLC
description: BitDefender Self Protection Driver
Bug check description: This indicates that invalid system memory has been referenced.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bdselfpr.sys (BitDefender Self Protection Driver, BitDefender LLC).
Google query: bdselfpr.sys BitDefender LLC PAGE_FAULT_IN_NONPAGED_AREA
crash dump file: E:\Windows\memory.dmp
This was probably caused by the following module: bdselfpr.sys (bdselfpr+0x7D27)
Conclusion
2 crash dumps have been found and analyzed. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
je suis vraiment pas douée an anglais dons un grand merci a ceux qui pourrais sur le sujet.
Re: a l'aide ,bluescreen!!!!!!!
Les rapports sont très explicites.
C'est ta suite BitDefender qui ne convient pas à ton système et notamment le pare-feu.
Désinstalle complètement BitDefender en utilisant l'outil spécifique de désinstallation
http://kb.bitdefender.com/KB333-fr--How ... ender.html
Installe une autre protection comme Antivir, Avast ou Microsoft Security Essentials associé avec le pare-feu Windows 7, et dis-nous si les écrans bleus ont disparu.
