crash sous seven
samlepirate
crash sous seven
Message par samlepirate »
bonjour a tous et a toutes
je me suis fait plaisir et je me suis fait une configuration pc et pour l occasion j ai installer seven
ors regulierement sans raison apparente j ai des crash bleu avec reboot system
j ai installe whocrashed et voila le rapport
etant un peu nul en anglais et en gestion windows pourriez m aider a resoudre cela
merci d avance
On Sat 12/12/2009 10:04:43 your computer crashed
This was likely caused by the following module: rdyboost.sys
Bugcheck code: 0x1A (0x1236, 0xFFFFFA8005BB9360, 0xFFFFFA8005BB9478, 0xC5E5E)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\121209-14695-01.dmp
file path: C:\Windows\system32\drivers\rdyboost.sys
description: ReadyBoost Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
On Sat 12/12/2009 05:28:42 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x109 (0xA3A039D8958CF699, 0xB3B7465EE809C8C7, 0xFFFFF80002DD6800, 0x1)
Error: CRITICAL_STRUCTURE_CORRUPTION
Dump file: C:\Windows\Minidump\121209-14258-01.dmp
On Sat 12/12/2009 05:14:27 your computer crashed
Bugcheck code: 0x109 (0xA3A039D895B05704, 0xB3B7465EE82D2932, 0xFFFFF80002D1A4A1, 0x1)
Dump file: C:\Windows\Minidump\121209-15319-01.dmp
On Sat 12/12/2009 04:02:10 your computer crashed
This was likely caused by the following module: tcpip.sys
Bugcheck code: 0x1000007E (0xFFFFFFFFC000001D, 0xFFFFF8800183E98B, 0xFFFFF88002FD8FC8, 0xFFFFF88002FD8820)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Dump file: C:\Windows\Minidump\121209-15085-01.dmp
file path: C:\Windows\system32\drivers\tcpip.sys
description: Pilote TCP/IP
On Fri 11/12/2009 23:57:00 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x50 (0xFFFFFAA009F4D4E0, 0x1, 0xFFFFF880012F5BF7, 0x5)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Dump file: C:\Windows\Minidump\121209-18595-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
On Fri 11/12/2009 17:14:24 your computer crashed
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8000BBDDF0, 0xFFFF, 0x0)
Dump file: C:\Windows\Minidump\121109-16317-01.dmp
On Fri 11/12/2009 16:57:59 your computer crashed
Dump file: C:\Windows\Minidump\121109-16489-01.dmp
On Fri 11/12/2009 02:46:11 your computer crashed
This was likely caused by the following module: dxgkrnl.sys
Bugcheck code: 0xD1 (0xFFFFFA803C7CFFCD, 0x2, 0x1, 0xFFFFF8800422F1C8)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\121109-24195-01.dmp
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
On Thu 10/12/2009 13:09:04 your computer crashed
This was likely caused by the following module: cdfs.sys
Bugcheck code: 0xA (0xFFFFFA800BC45670, 0x2, 0x0, 0xFFFFF80002A74EEB)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\121009-24367-01.dmp
file path: C:\Windows\system32\drivers\cdfs.sys
description: CD-ROM File System Driver
On Thu 10/12/2009 12:45:02 your computer crashed
Bugcheck code: 0x1A (0x41790, 0xFFFFFA800177BBE0, 0xFFFF, 0x0)
Dump file: C:\Windows\Minidump\121009-33165-01.dmp
On Wed 09/12/2009 19:50:43 your computer crashed
This was likely caused by the following module: fileinfo.sys
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88002FBD548, 0xFFFFF88002FBCDA0, 0xFFFFF80002A63517)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\120909-32058-01.dmp
file path: C:\Windows\system32\drivers\fileinfo.sys
description: FileInfo Filter Driver
Conclusion
11 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Jango78
Re: crash sous seven
Message par Jango78 »
Une première impression est que toutes ces erreurs ont peut-être un point commun, i.e. corruption généralisée du système de fichiers... donc en priorité, mise en cause du disque dur ou de la partition d'installation.
Ce qui n'exclut pas forcément d'autres pistes côté matériel.
samlepirate
ok c est d ailleur le seul element de mon pc qui ne soit pas neuf ....
depuis quelques temps le dd me fait de temps en temps un bruit metalique
jj ai installer hd tune
et ce dernier m annonce que le statut est ok bien
que spin retry count a un soucis apparemment apres une recherche sur le net
il s agirais du moteur du dd qui a du mal a donner la pleine vitesse de rotation aux disque
est ce que cela pourrais provenir de la ?
