Kernel data inpage error
Alizée
Message par Alizée »
Bonjour, j'ai depuis quelques jours un problème d'écran bleu qui s'affiche avec le message suivant "kernel data inpage error", j'ai donc installé Whocrashed et j'ai fait une analyse, que j'ai collée ci dessous, que dois je faire ?
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
On Sun 22/03/2015 12:05:31 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032215-27203-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1509A0)
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0006D873C20, 0x13AD5EC)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Sat 21/03/2015 14:52:44 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-22843-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0002B62B590, 0xA0D8B60)
On Sat 21/03/2015 14:40:23 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-22750-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0004C177830, 0x4F60044)
On Sat 21/03/2015 14:27:55 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-22218-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0005811DE80, 0xA0EF240)
On Sat 21/03/2015 14:15:32 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-23296-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0017F47DE80, 0x76EA9680)
On Sat 21/03/2015 14:03:06 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-22625-01.dmp
Bugcheck code: 0x50 (0xFFFFF6BD071431F8, 0x0, 0xFFFFF803228E8EB1, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Sat 21/03/2015 13:49:53 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-23937-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE0017758FE80, 0xA900BF0)
On Sat 21/03/2015 13:37:25 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-22093-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE000BC44D950, 0xA102000)
On Sat 21/03/2015 13:24:55 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\032115-23140-01.dmp
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE00050047B60, 0x7240D05C)
Conclusion
36 crash dumps have been found and analyzed. Only 10 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Re: Kernel data inpage error
