Ecran bleu :(
Snakiss
Ecran bleu :(
Message par Snakiss »
je viens vous demandez en aide car début Février des problèmes sont survenue, je suis donc aller chez l'informaticien qui ma fait un reformatage. Les écrans bleus ont disparus puis sont réapparus mais trés peu souvent (grosse session de jeu 6h+) et maintenant depuis quelque jours je ne peux plus jouer aux jeux. Je joue 10-15 min puis écran bleu ou écran bloquer.
J'ai fais une analyse avec whocrashed, les voici ci dessous.
En espérant que vous pourriez m'aider :) Merci d'avance.
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should ge the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: USER-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) II X2 550 Processor AMD586, level: 16
2 logical processors, active mask: 3
RAM: 4294156288 total
VM: 2147352576, free: 1880809472
Crash Dump Analysis
On Sun 30/03/2014 20:25:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\033014-17581-01.dmp
This was probably caused by the following module: unknown_module_00000000`00000004.sys (Unloaded_Unknown_Module_00000000`00000004+0x6)
Bugcheck code: 0xA (0x2B, 0x2, 0x0, 0xFFFFF80002C81289)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: unknown_module_00000000`00000004.sys .
Google query: unknown_module_00000000`00000004.sys IRQL_NOT_LESS_OR_EQUAL
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Fri 28/03/2014 23:00:57 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032914-21652-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0xA (0xFFFFFA7FFFFFD010, 0x2, 0x1, 0xFFFFF80002CFF7FE)
On Thu 20/03/2014 19:17:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032014-16879-01.dmp
Bugcheck code: 0xA (0xFFFFFA7FFFFFD010, 0x2, 0x1, 0xFFFFF80002C997FE)
On Sun 16/03/2014 17:47:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031614-45255-01.dmp
Bugcheck code: 0xA (0x10, 0x2, 0x1, 0xFFFFF80002CA5150)
On Sun 09/03/2014 12:20:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030914-23524-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6F880)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002C3C5FE, 0xFFFFF88002811E40, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Snakiss
Ecran bleu :(
Désolé j'ai oublié de précisé que sa peut aussi survenir lors de streaming.
Je tournes sur Windows 7.
Re: Ecran bleu :(
Avec Vista, 7, 8 et 8.1.
Dans le panneau de configuration, Outils d'administration, Diagnostic de mémoire Windows, choisis parmi les deux options proposées.
Cette opération se fera au redémarrage.
Un rapport sera affiché sur le bureau en cas de problème.
Avec Memtest. Tous systèmes
Mode d'emploi :Memtest86
Si cela ne règle rien, il faudra envisager une désinfection possible, les sites de streaming étant une source non négligeable à ce sujet.
