Redémarrage intempestif et écran bleu
tazounetfor
Message par tazounetfor »
je suis nouveau sur le forum et d habitude je gere bien mon matériel informatique, mais la depuis un bon moment mon ordi redemarre de fcon aleatoire, avec a la cle un bel ecran bleu, j ai installe whocrashed et j ai obtenu des rapports je les poste et j aimerais juste avoir un avis s il vous plait et accessoirement enfin trouvé une solution :
Crash Dump Analysis
On Thu 26/04/2012 01:43:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042612-19203-01.dmp
This was probably caused by the following module: dxgmms1.sys (dxgmms1+0x323AC)
Bugcheck code: 0xA (0x3, 0x2, 0x1, 0xFFFFFFFF82C981CC)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: dxgmms1.sys (dxgmms1!VidMmInterface+0x22DAC)
On Sun 22/04/2012 12:14:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042212-18843-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xAC00B)
Bugcheck code: 0x119 (0x1, 0x15B2ABF, 0x15BF029, 0x15BF028)
Error: VIDEO_SCHEDULER_INTERNAL_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 296.10
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 296.10
Bug check description: This indicates that the video scheduler has detected a fatal violation.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 296.10 , NVIDIA Corporation).
Google query: nvlddmkm.sys NVIDIA Corporation VIDEO_SCHEDULER_INTERNAL_ERROR
On Wed 18/04/2012 12:17:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041812-20218-01.dmp
Bugcheck code: 0x119 (0x1, 0xBD5ABF, 0xBDF2D3, 0xBDF2D2)
On Mon 16/04/2012 20:18:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041612-18046-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x393AB)
Bugcheck code: 0x7F (0xD, 0x0, 0x0, 0x0)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
On Mon 16/04/2012 10:52:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041612-19093-01.dmp
On Fri 13/04/2012 10:12:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041312-19578-01.dmp
This was probably caused by the following module: hal.sys (hal+0xEFCD)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8658201C, 0xFFFFFFFFB2000040, 0x800)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hal.sys .
Google query: hal.sys WHEA_UNCORRECTABLE_ERROR
On Thu 12/04/2012 20:46:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041212-19906-01.dmp
Bugcheck code: 0x119 (0x1, 0xFFFFFFFF94F4FABF, 0x38EAC8, 0x38EAC7)
Conclusion
8 crash dumps have been found and analyzed. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
hal.sys
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Et je vous met ma config :
MSI G31 TM-P21 1.0
Intel Core 2 quad q6600 @ 3.01 Ghz (2.40Ghz d origine)
4 Go DDr2
Nvidia 9800 GtX+
Voila en éspérant enfin que quelqu'un reussisse a me sortir de ce tourment LOL :-)
Re: Redémarrage intempestif et écran bleu
Première opération, vérifier la bonne insertion de la carte vidéo dans son slot et bien serrer la vis de fixation.ainsi que la patte à l'arrière si présente.
Pour la suite il faut désactiver le contrôle des comptes d'utilisateurs et avoir installé le dernier pilote Nvidia.
Manipulation
Dans C:\Windows\system32\drivers, renomme nvlddmkm.sys en nvlddmkm.sys.old
Dans le dossier C:\NVIDIA\Winvista\xxx.xx, localise le fichier nvlddmkm.sy_ fais un clic droit dessus et copier.
Ouvre le dossier C:\Windows\system32, clic droit et coller.
Ouvre une invite de commande dans Tous les programmes-Accessoires par clic droit et Exécuter en tant qu'administrateur.
Tape cd\ pour te placer a la racine du disque dur, puis cd windows et cd system32.
Tape la commande suivante : expand.exe nvlddmkm.sy_ nvlddmkm.sys
Récupère le fichier nvlddmkm.sys dans le dossier C:\windows\system32 et le coller dans C:\windows\system32\drivers
Supprime le fichier C:\Windows\System32\nvlddmkm.sy_
Réactive le contrôle des comptes d'utilisateurs.
Redémarre l'ordinateur.
Si le problème ne se reproduit pas tu peux supprimer le fichier C:\Windows\system32\drivers\nvlddmkm.sys.old
Essaie. @+
