Resultat Whocrashed - 0x50: PAGE_FAULT_IN_NONPAGED_AREA
ptondoh
Message par ptondoh »
J'ai des ecran blue chaque 1h envirion . Après analyse avec Whocrashed j'ai les résultat suivant:
System Information (local)
computer name: T-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Pentium(R) Dual-Core CPU E5700 @ 3.00GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 8585306112 total
VM: 2147352576, free: 1974022144
Crash Dump Analysis
On Tue 27/03/2012 22:00:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032712-52743-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x71F00)
Bugcheck code: 0x50 (0xFFFFFAC007E34F50, 0x1, 0xFFFFF8000289ADE6, 0x5)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
This was probably caused by the following module: ntfs.sys (Ntfs+0x32667)
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 27/03/2012 21:03:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032712-68000-01.dmp
Bugcheck code: 0x50 (0xFFFFFAC00C8C27F0, 0x1, 0xFFFFF80002894DE6, 0x5)
On Mon 26/03/2012 22:57:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032712-87454-01.dmp
Bugcheck code: 0x50 (0xFFFFFAC008F649B0, 0x1, 0xFFFFF800028D0DE6, 0x5)
On Mon 26/03/2012 22:49:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032612-79092-01.dmp
Bugcheck code: 0x50 (0xFFFFFAC007F42590, 0x1, 0xFFFFF8000289ADE6, 0x5)
Conclusion
5 crash dumps have been found and analyzed.
Avez vous une idées du problème.
Re: Resultat Whocrashed - 0x50: PAGE_FAULT_IN_NONPAGED_AREA
Ce Bug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA peut être en général provoqué par :
  • L'installation d'un matériel défectueux ou en cas de défaillance du matériel installé (généralement liée à un défaut de RAM, que ce soit la mémoire principale, L2 RAM cache, ou RAM vidéo).
  • Une autre cause fréquente est l'installation d'un service de système défectueux.
  • Les logiciels antivirus peuvent également déclencher cette erreur, tout comme un volume NTFS endommagé.
Il te faudrait dans un 1er temps faire un diagnostic de mémoire.
Soit avec l'outil intégré Windows 7 :
Panneau de configuration -> Outils d'administration -> Diagnostic de mémoire Windows
Soit avec un outil tiers comme Memtest86
Tester ses barrettes de RAM avec MemTest
