windows xp and windows 7 dual boot issue: they won't
colintyvu
Message par colintyvu »
I read the complete step by step how to on setting up dual booting windows 7 and xp. I prepared all my partitions beforehand, and labeled them accordingly so there would be no confusion i. I installed windows 7 on my new SATA drive. Everything went OK, except that I never got a boot menu presented - to 7, it was as if XP was not there i.
I downloaded and installed, and ran, easybcd, and tried to add the xp menu entry manually. It asks for the drive, and the drive with xp on it is now, under windows 7, drive D (it is E when I boot xp). All necessary files (ntldr, ntdetect.com, boot.ini) are all on this drive. But when I try that menu entry, all the computer does is reboot. It will still only boot windows 7, unless I go into the BIOS settings and change the boot order of the hard drives (in this list, if I make the one with the Win7 partition nr 1, I can boot windows 7 and only that; if I make the one with the XP partition nr 1, I get my regular old boot menu from boot.ini (which also gets me into my wubi install of ubuntu).
I would like to be able to boot into XP from the windows 7 boot menu, or, alternately, would like to boot windows 7 from the xp boot menu. (that would be even better). Does anyone have any pointers for me?
Thanks in advance.
SYNTAX-ERROR
Re: windows xp and windows 7 dual boot issue: they won't
Message par SYNTAX-ERROR »
Hi.
Have you installed XP first and then Win 7 ??
Pierre Desproges
ЅЎЍТΔХ~ΣЯЯФЯ™
Jango78
Message par Jango78 »
Je doute que ce post transitant par la SCTV Saigon soit légitime...
Communauté francophone windows 7 :bizar:
Jango78
Bah c'est surtout que ce pseudo semble universellement référencé depuis au moins les années 90, et que visiblement de nombreux posts ont été swordés ici ou là.
Mais on trouve encore des traces, par ex. ici avec une bannière de pub:
Scheduled Tasks not starting?
Cette question apparaît également sur des dizaines de forums en Autriche, UK, Allemagne, Italie, Pays-Bas, Suède, Australie, USA et même en Afrique du Sud.
Donc... spam :hein:
Avez-vous remarqué les deux i qui pointent vers un site w*w.hochanhvietnam.com/vn/giasu.html ?
Je les supprime et verrouille le sujet.
