ENCORE CET ECRAN BLEU et WHO CRASHED
serge152
Message par serge152 »
Pouvez-vous m'aider ?
Crash Dump Analysis
On Sun 27/03/2011 09:12:20 GMT your computer crashed
This was probably caused by the following module: Unknown (0x7725E2A0)
Bugcheck code: 0xB8 (0xFFFFFA8003749040, 0xFFFFF8800316DF80, 0x0, 0x0)
Error: ATTEMPTED_SWITCH_FROM_DPC
Bug check description: This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown ATTEMPTED_SWITCH_FROM_DPC
On Fri 25/03/2011 02:01:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032511-33072-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x82EDA)
Bugcheck code: 0x100000B8 (0xFFFFFA80046F1690, 0xFFFFF8800336DF80, 0x0, 0x0)
Error: CUSTOM_ERROR
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
unknown
Re: ENCORE CET ECRAN BLEU et WHO CRASHED
Image Télécharge ZHPDiag de Nicolas Coolman sur ton bureau.
Image Clique sur Image pour lancer l'installation.
Image Clique sur Image pour lancer le programme.
Image Clique sur Image pour vérifier si une mise à jour du logiciel est disponible.
Image Clique sur Image pour lancer le scan.
Image Clique sur Image quand le scan sera terminé pour mettre le rapport dans le presse-papier.
Image Héberge ce dernier sur Cjoint.
Poste le lien obtenu.
Image Referme l'outil.
Image Le rapport sera enregistré sur le bureau. Image
serge152
Belle panoplie.
1- ImageTélécharge AD-Remover sur ton bureau.
Image Double clique sur AD-R.exe
Clique sur le bouton Nettoyer.
Image Poste le rapport qui va s'ouvrir en fin de scan.
Le rapport est sauvegardé sous C:\Ad-report-SCAN[1].txt
Puis ferme le programme par Quitter.
2- Image Télécharge et installe Malwarebytes Anti-Malware de RubbeR DuckY
Image Double-clique sur le fichier mbam-setup-1.50.exe (sous Vista et 7 autorise les modifications)
  • -Mettre à jour Malwarebytes' Anti-Malware
Image Clique sur Terminer
Coche Image Exécuter un examen rapide, clique sur le bouton Image
Image A la fin du scan, sélectionne tout et clique sur Supprimer la sélection
Image Poste le rapport qui s'ouvre après cette suppression.
3- Fais un scan avec ton antivirus et poste le rapport avec les deux autres.
4- Fais analyser ce fichier : C:\Program Files (x86)\Artisteer 2\bin\Artisteer.exe sur VirusTotal
5- Mets à jour Java et supprimes les autres versions.
-Java Runtime Environment (JRE)6u24 :
http://java.sun.com/javase/downloads/index.jsp
Clique sur Download Java Runtime Environment (JRE) 6 update24
Dans la page suivante, choisis Windows dans Platform coche I agree to the Java SE Runtime Environment 6 License Agreement et Continue
Dans la nouvelle page, coche Windows Offline Installation - jre-6u24-windows-i586.exe //15.75MB.
Tu l'installeras hors connexion.
serge152
belle panoplie ??? c'est à dire ???
serge152
Rapport Ad Remover : http://cjoint.com/?1dBnoGVPsZh
Rapport Malwraebytes : http://cjoint.com/?1dBnzAyKpxu
je n'arrive pas à avoir virus total ! :-(
serge152
allo ?
As-tu encore des problèmes ?
serge152
pour l'instant non mais cela etait déjà très aléatoire !
que voulais tu dire par belle panoplie ?
et enfin je n'arrive pas à avoir virustotal
Belle panoplie veut dire que tu avais une certaine quantité de toolbars inutiles entre autres.
Pour VirusTotal qu'est-ce que tu n'arrives pas à avoir ?
