Alors c'est simple j'ai des bluescreen et c'est fortement gênant donc voila le raport de whocrashed :
On Sun 26/12/2010 23:12:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\122710-23680-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0x50 (0xFFFFFA800D6AB000, 0x0, 0xFFFFF880069E52D0, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Mon 20/12/2010 22:03:41 GMT your computer crashed
crash dump file: C:\Windows\Minidump\122010-23478-01.dmp
Bugcheck code: 0x50 (0xFFFFFA80106AB000, 0x0, 0xFFFFF880065CD2D0, 0x0)
On Sat 01/05/2010 14:11:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050110-20170-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x12834)
Bugcheck code: 0x116 (0xFFFFFA80045BA010, 0xFFFFF88003CF7834, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: ATI Technologies Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, ATI Technologies Inc.).
Google query: atikmdag.sys ATI Technologies Inc. VIDEO_TDR_ERROR
Conclusion
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
stp aider moi
merci d'avance
aide blue sreen
Re: aide blue sreen
Voici la traduction de Google :
As tu essaye de mettre a jour ta carte graphique - voir ICI3 vidages sur incident ont été trouvés et analysés. Un pilote tiers a été identifié pour être à l'origine plantage du système sur votre ordinateur. Il est fortement recommandé que vous vérifiez les mises à jour de ces pilotes sur leurs sites Web d'entreprise. Cliquez sur les liens ci-dessous pour des recherches avec Google pour les mises à jour de ces pilotes:
atikmdag.sys (ATI Radeon Kernel Mode Driver, ATI Technologies Inc)
Si aucune mise à jour de ces pilotes sont disponibles, essayez de chercher avec Google sur les noms de ces pilotes en combinaison les erreurs qui ont été rapportées pour ces pilotes et inclure le nom de marque et le modèle de votre ordinateur ainsi dans la requête. Cela donne souvent des résultats intéressants des discussions des utilisateurs qui ont connu des problèmes similaires.
Lisez les suggestions thème général pour le dépannage plantage du système pour plus d'informations.
Notez que ce n'est pas toujours possible d'affirmer avec certitude si un conducteur a signalé est réellement responsable de plantage de votre système ou que la cause profonde est dans un autre module. Néanmoins, il est suggéré que vous recherchez des mises à jour pour les produits que ces pilotes et appartiennent à visiter régulièrement mise à jour Windows ou activer les mises à jour automatique pour Windows. Dans le cas où un morceau de dysfonctionnement du matériel est à l'origine des problèmes, une recherche avec Google sur les erreurs de vérification de bogue avec le nom du modèle et la marque de votre ordinateur peut vous aider à étudier plus à fond.
Re: aide blue sreen
Enfaite le problème de carte graphique a été résolu mais la le problème provient du kernel de Windows mais comme la indiquer whoscrashed il n'y a pas de solution donc voila pourquoi je demande
Re: aide blue sreen
Tu peux tester la mémoire de deux manières :
- Dans Panneau de configuration > Outils d'administration > Diagnostic de mémoire Windows tu cliques dessus et tu suis la routine.
- Avec Memtest
- Avec Memtest
Re: aide blue sreen
Le diagnostic na rien donnée et aujourd'hui même j'ai cette même erreur :
cela provient du kernel mais g aucune solution .
svp aider moi
svp aider moi
Re: aide blue sreen
A quel moment est apparu ce probleme ??? une MAJ ?
Est ce que tous tes drivers sont a jour ?
As tu essaye de revenir en arriere pour certains drivers ?
SYNTAX-ERROR
Re: aide blue sreen
Code erreur 0x00000050.
Beaucoup de soluces concerne XP, mais ce sont quand même des pistes a explorer.Logiciel : Erreur STOP Windows
Intitulé : PAGE_FAULT_IN_NONPAGED_AREA
Solution
[1] Un pilote de périphérique ou un service cherche en mémoire vive des données qui n'y sont pas.
[2] Une barrette de mémoire vive peut être défectueuse ou un logiciel (souvent un antivirus ou une application de contrôle à distance) est incompatible avec la version de Windows que vous utilisez.
[3] Windows XP - Vous utilisez Easy CD Creator 5, incompatible avec Windows XP . Téléchargez une mise à jour sur le site de l'éditeur : Roxio.
[4] Windows XP - Vous utilisez le scanner HP ScanJet 4400 ou 4470 connecté sur le port parallèle. Installez se Service Pack 1 ou 2 de WIndows XP.
[5] Windows XP - Si l'erreur sruvient au redémarrage de l'ordinateur après l'installation du Service Pack 1, elle est due au pilote de la carte graphique. Désinstallez-la et installez un pilote plus récent en mode sans échec).
[6] Windows XP - Le pilote du lecteur USB Lexar Media est incompatible avec Windows XP. Téléchargez un pilote plus récent sur le site de Lexar Media.
[7] Windows XP SP2 - Si l'erreur survient pendant l'installation du SP2, il est possible que le logiciel BootSkin ou ZoneAlarm soit responsable. téléchargez un correctif ou une nouvelle version sur le site de l'éditeur.
Pierre Desproges
ЅЎЍТΔХ~ΣЯЯФЯ™
Pierre Desproges
ЅЎЍТΔХ~ΣЯЯФЯ™
