Impossible de faire l'indice de performance [Résolu]
slackk
Message par slackk »
Il m'est impossible de faire l'indice de performance. J'ai Windows 7 pro 64bits. J'ai avast car j'avais lu que cela pouvait venir de Kapersky.
Voici le fichier winsat. Peut être que quelque chose m'échappe.
2551458 (4328) - winsat\logging.cpp:0815: --- START 2009\12\3 08:18:53 ---
2551458 (4328) - winsat\main.cpp:4301: Command Line = "C:\Windows\system32\winsat.exe" formal -cancelevent 87518142-7f1b-45a9-9044-4dd49dd5f26d
2551458 (4328) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
2551599 (4328) - winsat\main.cpp:4474: > IsFormal=TRUE  IsMoobe=FALSE.
2551630 (4328) - winsat\main.cpp:4585: Watch dog system enabled
2551630 (4328) - winsat\main.cpp:4600: Main watch dog timer set to 600.0 seconds
2551630 (4328) - winsat\main.cpp:3115: A failure occured while trying to read partial assessments from the datastore.  Running full assessment
2551630 (4328) - winsat\main.cpp:2490: > DWM Running.
2551801 (4328) - winsat\main.cpp:2497: > turning off DWM.
2551801 (4328) - winsat\main.cpp:2470: > EMD service will be restored on exit.
2552082 (4328) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
2552082 (4328) - winsat\main.cpp:2793: > power policy saved.
2552254 (4328) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
2552254 (4328) - winsat\main.cpp:2814: > power policy set to maximum.
2553096 (4328) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
2553096 (4328) - winsat\main.cpp:0948: > IsOfficial=TRUE  IsFormal=TRUE  IsMoobe=FALSE  RanOverTs=FALSE  RanOnbatteries=FALSE
2553096 (4328) - winsat\main.cpp:1775: > Run Assessment features
2553174 (4328) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
2565218 (4328) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 47694200
2565218 (4328) - winsat\main.cpp:2037: > DWM Assessment results processing SUCCESS
2565218 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2571395 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2577744 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
2584172 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
2590661 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2596855 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2603032 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
2609537 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
2615918 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname GeomF4 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 150;200;241 -batchcnt C(50);C(200);C(300) -objs C(12);C(26);C(45) -noalpha -geomf4shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
2624654 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname GeomV8 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75;100;120 -batchcnt C(25);C(100);C(150) -objs C(8);C(17);C(29) -noalpha -geomv8shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
2632875 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10  -aname CBuffer -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75 -batchcnt C(25) -objs C(8) -rendertotex 6 -rtdelta 3 -texpobj C(1) -cbuffershader -cbufa 2 -cbuff 5 -cbufp 6
2638881 (4328) - winsat\main.cpp:1775: > Run Assessment mfmedia -input C:\Windows\Performance\WinSAT\winsat.wmv -nopmp
2640613 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_MPEG2_HD_15mbps.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2647352 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_VC1_15mbps.wmv -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2653733 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480i_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2660519 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480p_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2667055 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_10mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2673591 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480_5sec_6mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2679972 (4328) - winsat\main.cpp:1775: > Run Assessment media -input C:\Windows\Performance\WinSAT\winsatencode.wmv -encode C:\Windows\Performance\WinSAT\winsat.prx
2683341 (4328) - winsat\main.cpp:1775: > Run Assessment moobego
2683341 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption -up
2686399 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression -up
2696524 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2 -up
2699581 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression2 -up
2709628 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption
2719783 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression
2730001 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2
2740204 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression2
2750453 (4328) - winsat\main.cpp:1775: > Run Assessment mem
2755679 (4328) - winsat\main.cpp:1775: > Run Assessment disk -seq -read -n 0
2764462 (4328) - winsat\main.cpp:1775: > Run Assessment disk -ran -read -n 0
2776770 (4328) - winsat\main.cpp:1775: > Run Assessment disk -scen 2009 -drive C:
2847361 (4328) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 47694200
2847361 (4328) - winsat\processresults.cpp:0962: > Wrote cpu expression compression score to the registry 151
2847377 (4328) - winsat\processresults.cpp:1004: Total physical mem available to the OS : 3,99 Go (4 290 240 512 bytes)
2847377 (4328) - winsat\processresults.cpp:1253: Skipping StdDefPlayback limit check.
2847377 (4328) - winsat\processresults.cpp:1265: Skipping StdDefPlayback limit check.
2847377 (4328) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 590
2847377 (4328) - winsat\processresults.cpp:1498: > Wrote random read disk score to the registry 1536
2847392 (4328) - winsat\main.cpp:0948: > IsOfficial=TRUE  IsFormal=TRUE  IsMoobe=FALSE  RanOverTs=FALSE  RanOnbatteries=FALSE
2847408 (4328) - winsat\main.cpp:4736: ERROR:  Unable to save validated results.
2847439 (4328) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
2847439 (4328) - winsat\main.cpp:2855: > Power state restored.
2847439 (4328) - winsat\main.cpp:2870: > Successfully reenabled EMD.
2847704 (4328) - winsat\main.cpp:2896: > Composition restarted
2847720 (4328) - winsat\watchdog.cpp:0311: Watch dog system shutdown
2847720 (4328) - winsat\main.cpp:4909: > exit value = 1.
Si vous avez besoin d'informations supplémentaires, indiquez moi.
Jango78
Re: Impossible de faire l'indice de performance
Message par Jango78 »
A priori l'erreur winsat\main.cpp:4736 indiquerait que les résultats n'ont pu être sauvegardés sur le disque, tandis que les valeurs précédemment enregistrées sont partiellement illisibles selon notification en début de log.
Juste pour voir... si on supprime le contenu du dossier \Windows\Performance\WinSAT\DataStore, le panneau Système affiche en bonne logique "L'évaluation de l'ordinateur n'est pas disponible".
A ce moment cliquer sur le lien et relancer "Evaluer cet ordinateur".
slackk
Toujours le même résultat. Impossible d'effectuer le test.
slackk
Toujours le meme soucis mais cette fois avec seven ultimate. Je pense que ça doit venir d'une probleme de pilote ou de maj de la carte mere.
HELP !!!
Faldrel
Message par Faldrel »
slackk a écrit :Bonjour,
HELP !!!
J'ai déjà fait l'indice de performance et il n'y a pas eu de problèmes,j'ai Windows 7 Edition Intégrale 64 bits,j'ai aussi Kaspersky anti virus et il n'y a pas eu de problèmes non plus.
Mettez à jour les pilotes de vos matériels et de votre carte mère et réessayez.
slackk
J'ai difficilement trouvé la solution sur le web avec un cas similaire. (4 Mois) Il s'agit normalement du bios. Il faut que je mette à jour le bios.
Comment faire ?
Je me doute bien que pour les autres tout va bien sinon j'aurai déjà trouvé la reponse. Mes pilotes sont à jours (tout les drivers, driverschecker etc.. testé). Il est m'est impossible de lancer 3DMark et cpu-z m'indique rien au niveau de la carte mere.
Faldrel
slackk a écrit :J'ai difficilement trouvé la solution sur le web avec un cas similaire. (4 Mois) Il s'agit normalement du bios. Il faut que je mette à jour le bios.
Comment faire ?
J'ai déjà utilisé CPU-Z et il me semble bien que la marque et le modèle de la carte mère sont indiqués,autrement vous pouvez ouvrir votre boitier et regarder la carte mère,la marque et le modèle devraient être indiqués.Vous pouvez également regarder les informations du bios de votre carte mère au démarrage,la marque et le modèle sont indiqués.
slackk
Oui oui ils sont indiqués sur cpu-z sauf que sur mon pc nan. La cause => Bios pas à jour.
Faldrel
Vous devriez trouver un nouveau bios sur le site du fabricant de votre carte mère,vous devez aussi récupérer un utilitaire pour mettre à jour votre bios à moins que vous puissiez mettre votre bios à jour à partir des options de réglages du bios de votre carte mère.
slackk
VOila le probleme est resolu ! Par contre :evil: l'evaluation se fait mais je vois voit pas le resultat maintenant.
