Ecran bleu
apt
Ecran bleu
Message par apt »
Je reçois a chaque démarrage un ecran bleu et c'est iusb3xhc.sys qui est la cause de ce problème.
Commet régler cela.
Merci d'avance.
Voici le rapport WhoCrashed :
Crash Dump Analysis
Crash dumps are enabled on your computer. This system is not configured for complete or automatic crash dumps. For best results, configure your system to write out complete or automatic crash dumps. Select Tools->Crash Dump Configuration from the main menu to configure your system to write out complete memory dumps.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Thu 14/06/2018 19:53:16 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061418-21808-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF8800434368C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800434368C, 0xFFFFF880037FE5A8, 0xFFFFF880037FDE10)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\drivers\iusb3xhc.sys
product: USB 3.0 Device Driver
company: Intel Corporation
description: Intel(R) USB 3.0 eXtensible Host Controller Driver
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: iusb3xhc.sys (Intel(R) USB 3.0 eXtensible Host Controller Driver, Intel Corporation).
Google query: iusb3xhc.sys Intel Corporation SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
crash dump file: C:\Windows\MEMORY.DMP
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF8800434368C, 0xFFFFF880037FE5A8, 0xFFFFF880037FDE10)
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
On Thu 14/06/2018 19:50:33 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061418-50201-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF88004EBD68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88004EBD68C, 0xFFFFF8800371D5A8, 0xFFFFF8800371CE10)
On Thu 14/06/2018 19:28:50 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061418-50294-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF8800424E68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800424E68C, 0xFFFFF880037E25A8, 0xFFFFF880037E1E10)
On Thu 14/06/2018 19:26:09 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061418-50575-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF88004F4568C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88004F4568C, 0xFFFFF880037F05A8, 0xFFFFF880037EFE10)
On Thu 14/06/2018 19:23:29 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061418-50435-01.dmp
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800424E68C, 0xFFFFF880039165A8, 0xFFFFF88003915E10)
On Mon 11/06/2018 08:48:07 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061118-51215-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF8800511F68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800511F68C, 0xFFFFF880039085A8, 0xFFFFF88003907E10)
On Sun 10/06/2018 19:23:05 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061018-18907-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF8800507C68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8800507C68C, 0xFFFFF8800371D5A8, 0xFFFFF8800371CE10)
On Sun 10/06/2018 18:08:14 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061018-18361-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF880048BC68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF880048BC68C, 0xFFFFF880037E25A8, 0xFFFFF880037E1E10)
On Wed 06/06/2018 17:14:58 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\061018-16458-01.dmp
This was probably caused by the following module: iusb3xhc.sys (0xFFFFF88004A8A68C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF88004A8A68C, 0xFFFFF880037E95A8, 0xFFFFF880037E8E10)
Conclusion
On your computer a total of 18 crash dumps have been found. Only 10 have been analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Re: Ecran bleu
Le pilote iusb3xhc.sys (Intel(R) USB 3.0 eXtensible Host Controller Driver, Intel Corporation) est le responsable de ces écrans bleus.
Ton problème est semblable à celui de ce fil, résolu par la mise à jour des pilotes Intel.
https://www.commentcamarche.net/forum/a ... oin-d-aide
Regarde si une mise à jour de tes pilotes Intel est disponible en t'aidant de ce tutoriel.
https://www.malekal.com/mise-a-jour-pilotes-intel/
