[Résolu] ecran bleu de la mort
Cela fait maintenant plusieurs jours que j'ai un écran bleu de la mort qui apparait aléatoirement lorsque je vais sur internet. Je ne sais plus quoi faire.
J'ai utilisé WhoCrashed et voici le rapport. Merci pour votre aide.
Jeanno67
Crash Dump Analysis
On Wed 2014-03-05 18:22:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030514-21465-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF880094D81EA)
Bugcheck code: 0xD1 (0x74B2300, 0x2, 0x0, 0xFFFFF880094D81EA)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Program Files (x86)\ShopperPro\JSDriver\1.0.0.27\jsdrv.sys
product: JsDriver
description: jsdrv
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: jsdrv.sys (jsdrv, ).
Google query: jsdrv.sys DRIVER_IRQL_NOT_LESS_OR_EQUAL
This was probably caused by the following module: jsdrv.sys (jsdrv+0x51EA)
product: JsDriver
description: jsdrv
On Wed 2014-03-05 17:45:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030514-23150-01.dmp
This was probably caused by the following module: jsdrv_fffff88009a71000.sys (0xFFFFF88009A761EA)
Bugcheck code: 0xD1 (0x17EAB578, 0x2, 0x0, 0xFFFFF88009A761EA)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: jsdrv_fffff88009a71000.sys .
Google query: jsdrv_fffff88009a71000.sys DRIVER_IRQL_NOT_LESS_OR_EQUAL
On Sun 2014-03-02 19:29:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030214-15849-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF880090E31EA)
Bugcheck code: 0xD1 (0x1850F6F8, 0x2, 0x0, 0xFFFFF880090E31EA)
product: JsDriver
description: jsdrv
On Sun 2014-03-02 18:58:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030214-21621-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF8800957D1EA)
Bugcheck code: 0xD1 (0x1835E618, 0x2, 0x0, 0xFFFFF8800957D1EA)
product: JsDriver
description: jsdrv
On Sun 2014-03-02 00:32:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030114-33212-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF880089A41EA)
Bugcheck code: 0xD1 (0x1895DFD0, 0x2, 0x0, 0xFFFFF880089A41EA)
product: JsDriver
description: jsdrv
On Sun 2014-03-02 00:17:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030114-27721-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF88008D631EA)
Bugcheck code: 0xD1 (0x16638290, 0x2, 0x0, 0xFFFFF88008D631EA)
product: JsDriver
description: jsdrv
On Sat 2014-03-01 22:23:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030114-21933-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF88004C8E1EA)
Bugcheck code: 0xD1 (0x16954248, 0x2, 0x0, 0xFFFFF88004C8E1EA)
product: JsDriver
description: jsdrv
On Sat 2014-03-01 22:09:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030114-22432-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF8800A72D1EA)
Bugcheck code: 0xD1 (0x1B8DAFC8, 0x2, 0x0, 0xFFFFF8800A72D1EA)
product: JsDriver
description: jsdrv
On Sat 2014-03-01 20:44:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030114-21075-01.dmp
This was probably caused by the following module: jsdrv.sys (0xFFFFF880077AF1EA)
Bugcheck code: 0xD1 (0x23CBDB68, 0x2, 0x0, 0xFFFFF880077AF1EA)
product: JsDriver
description: jsdrv
Conclusion
13 crash dumps have been found and analyzed. Only 10 are included in this report. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
jsdrv.sys (jsdrv, )
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Jeanno67
Crash Dump Analysis
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
product: JsDriver
description: jsdrv
Conclusion
jsdrv.sys (jsdrv, )
Modifié en dernier par jeanno67 le ven. 7 mars 2014 00:29, modifié 1 fois.
Re: ecran bleu de la mort
je n'ai pas de driver de ce nom, essaie d'aller sur "désinfection" avoir un avis:
Çà pourrait être un possible de virus ou malware lié à "Shopper pro" (Goobzo LTD), si tu as ça:
http://www.pcrisk.fr/guides-de-suppress ... -pro-virus
Mais je m'avance peu-être, on courage.
Alain Quarré
Je pense aussimwonex a écrit :Çà pourrait être un possible de virus ou malware lié à "Shopper pro" (Goobzo LTD)
un nettoyage s'impose
Pour faire un premier diagnostic, appliquer cette procédure dans l'ordre
1 [sub]
[/sub] AdwCleanerV3 de Xplode sur ton bureau[/b]
Lance l'outil en cliquant sur AdwCleaner.exe.
Sous Vista et Windows 7 par un clic droit sur l'icône et cliquer sur Exécuter en tant qu'administrateur dans le menu contextuel.
Clique sur le bouton Scanner
Une fois l'analyse terminée clique sur Nettoyer
Un message t'informe que toutes les applications vont être fermées, valide par OK pour continuer.
Une fois le scan terminé, une fenêtre d'informations va s'ouvrir. Lis bien son contenu et valide par OK.
Le pc va redémarrer. Valide par OK
Poste le rapport qui s'ouvre après le redémarrage de l'ordinateurpar copier-coller dans ta réponse.
Il sera enregistré sous C:\AdwCleane\AdwCleaner[S0].txt
2 [sub]
[/sub] Malwarebytes Anti-Malware
Clique sur Télécharger maintenant et installe-le une fois sur ton ordinateur.
Double-clique sur le fichier mbam-setup-1.75.0.1300.exe
(Sous Vista et 7 autorise les modifications)
La troisième ligne est optionnelle pour découvrir pendant un mois la version commerciale.
Clique sur Terminer
Coche
, clique sur le bouton
A la fin du scan, sélectionne tout et clique sur Supprimer la sélection
Poste le rapport qui s'ouvre après cette suppression.
Pour supprimer les programmes potentiellement dangereux, PUP, règle comme indiqué sur l'image ci-dessous, avant de faire le scan.
3 [sub]
[/sub] ZHPDiag de Nicolas Coolman sur ton bureau.
Une fois téléchargé, clique sur le fichier ZHPDiag2.exe pour installer l'outil et suis la routine.
Laisse coché Installer une icône sur le bureau quand cela te sera proposé.
Lance ZHPDiag en cliquant sur l'icône ZHPDiag affichée sur le bureau
1 - Dans l'interface, clique sur le bouton Configurer pour afficher la rangée d'icône en bas.
2 - Clique sur la loupe avec le signe + Pour lancer l'analyse.
Laisse faire le scan jusqu'à ce que la barre de progression en bas soit à 100%.
Tu refermes ZHPDiag en cliquant sur la croix rouge en haut à droite.
Tu l'héberges sur Cjoint en cochant 21 jours dans la ligne Et pour quelle durée ?
Explications pour Cjoint
Si besoin est, nous ferons appel à d'autres outils.
1 [sub]
Lance l'outil en cliquant sur AdwCleaner.exe.Sous Vista et Windows 7 par un clic droit sur l'icône et cliquer sur Exécuter en tant qu'administrateur dans le menu contextuel.
Poste le rapport qui s'ouvre après le redémarrage de l'ordinateurpar copier-coller dans ta réponse.Il sera enregistré sous C:\AdwCleane\AdwCleaner[S0].txt
2 [sub]
[/sub] Malwarebytes Anti-MalwareClique sur Télécharger maintenant et installe-le une fois sur ton ordinateur.
Double-clique sur le fichier mbam-setup-1.75.0.1300.exe (Sous Vista et 7 autorise les modifications)
Clique sur TerminerUne fenêtre Mise à jour de Malwarebytes' Anti-Malware va s'ouvrir avec une barre de progression.
Coche
Poste le rapport qui s'ouvre après cette suppression.Redémarre le pc si cela est demandé
3 [sub]
Une fois téléchargé, clique sur le fichier ZHPDiag2.exe pour installer l'outil et suis la routine.Laisse coché Installer une icône sur le bureau quand cela te sera proposé.
Lance ZHPDiag en cliquant sur l'icône ZHPDiag affichée sur le bureau1 - Dans l'interface, clique sur le bouton Configurer pour afficher la rangée d'icône en bas.
Tu refermes ZHPDiag en cliquant sur la croix rouge en haut à droite.Un fichier ZHPDiag.txt sera enregistré sur le bureau.
Tu l'héberges sur Cjoint en cochant 21 jours dans la ligne Et pour quelle durée ?Tu me communiques le lien obtenu dans ta réponse.
Merci pour votre aide. Je viens de terminer toutes les étapes que tu m'as demandé de faire. Voici les rapports.
Rapport AdwCleaner
# AdwCleaner v3.020 - Rapport créé le 05/03/2014 à 17:31:14
# Mis à jour le 27/02/2014 par Xplode
# Système d'exploitation : Windows 7 Home Premium Service Pack 1 (64 bits)
# Nom d'utilisateur : geist - GEIST-PC
# Exécuté depuis : C:\Users\geist\Downloads\adwcleaner.exe
# Option : Scanner
***** [ Services ] *****
***** [ Fichiers / Dossiers ] *****
Dossier Présent : C:\Users\geist\AppData\Local\Google\Chrome\User Data\Default\Extensions\cigiagpbkapepgklncnajbakkpkopmam
Dossier Présent : C:\Users\geist\AppData\Roaming\Mozilla\Firefox\Profiles\3vz39weq.default\Extensions\2eb528f3-950d-48a3-be4b-5d7de6c8331e@a41e199b-6ca4-4d23-ab87-73f2d1973314.com
Dossier Présent : C:\Users\THOMAS\AppData\Local\Google\Chrome\User Data\Default\Extensions\cigiagpbkapepgklncnajbakkpkopmam
Dossier Présent : C:\Users\THOMAS\AppData\Roaming\Mozilla\Firefox\Profiles\zx2bk18q.default\Extensions\2eb528f3-950d-48a3-be4b-5d7de6c8331e@a41e199b-6ca4-4d23-ab87-73f2d1973314.com
Dossier Présent C:\Program Files (x86)\iWebar
Dossier Présent C:\Program Files (x86)\LSHunter.TV
Dossier Présent C:\Program Files (x86)\myfree codec
Dossier Présent C:\ProgramData\Microsoft\Windows\Start Menu\Programs\myfree codec
Dossier Présent C:\ProgramData\Tarma Installer
Dossier Présent C:\Users\geist\AppData\Local\PackageAware
Dossier Présent C:\Users\geist\AppData\LocalLow\iWebar
Dossier Présent C:\Users\geist\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\LSHunter.TV
Dossier Présent C:\Users\geist\Documents\Mobogenie
Dossier Présent C:\Users\geist\Documents\Optimizer Pro
Dossier Présent C:\Users\THOMAS\AppData\LocalLow\iWebar
Dossier Présent C:\Windows\SysWOW64\AI_RecycleBin
Fichier Présent : C:\Users\geist\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_www.wajam.com_0.localstorage-journal
Fichier Présent : C:\Windows\System32\roboot64.exe
Fichier Présent : C:\Windows\System32\Tasks\iWebar-chromeinstaller
Fichier Présent : C:\Windows\System32\Tasks\iWebar-codedownloader
Fichier Présent : C:\Windows\System32\Tasks\iWebar-enabler
Fichier Présent : C:\Windows\System32\Tasks\iWebar-firefoxinstaller
Fichier Présent : C:\Windows\System32\Tasks\iWebar-updater
Fichier Présent : C:\Windows\Tasks\iWebar-chromeinstaller.job
Fichier Présent : C:\Windows\Tasks\iWebar-codedownloader.job
Fichier Présent : C:\Windows\Tasks\iWebar-enabler.job
Fichier Présent : C:\Windows\Tasks\iWebar-firefoxinstaller.job
Fichier Présent : C:\Windows\Tasks\iWebar-updater.job
***** [ Raccourcis ] *****
***** [ Registre ] *****
Clé Présente : HKCU\Software\APN PIP
Clé Présente : HKCU\Software\AppDataLow\Software\Crossrider
Clé Présente : HKCU\Software\AppDataLow\Software\iWebar
Clé Présente : HKCU\Software\AppDataLow\Software\PriceGong
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{11111111-1111-1111-1111-110311551110}
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Présente : HKCU\Software\Microsoft\Windows\CurrentVersion\Uninstall\MyFreeCodec
Clé Présente : HKCU\Software\Myfree Codec
Clé Présente : HKCU\Software\PrivitizeVPNInstallDates
Clé Présente : [x64] HKCU\Software\APN PIP
Clé Présente : [x64] HKCU\Software\Myfree Codec
Clé Présente : [x64] HKCU\Software\PrivitizeVPNInstallDates
Clé Présente : HKLM\Software\caphyon
Clé Présente : HKLM\SOFTWARE\Classes\AppID\{0A18A436-2A7A-49F3-A488-30538A2F6323}
Clé Présente : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Clé Présente : HKLM\SOFTWARE\Classes\AppID\{608D3067-77E8-463D-9084-908966806826}
Clé Présente : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Clé Présente : HKLM\SOFTWARE\Classes\AppID\YontooIEClient.DLL
Clé Présente : HKLM\SOFTWARE\Classes\Applications\iMesh_V11_en_Setup.exe
Clé Présente : HKLM\SOFTWARE\Classes\Applications\iMeshV11.exe
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{00000001-4FEF-40D3-B3FA-E0531B897F98}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{007EFBDF-8A5D-4930-97CC-A4B437CBA777}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{11111111-1111-1111-1111-110311551110}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{22222222-2222-2222-2222-220322552210}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{35B8892D-C3FB-4D88-990D-31DB2EBD72BD}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{5C3B5DAA-0AFF-4808-90FB-0F2F2D760E36}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{64697678-0000-0010-8000-00AA00389B71}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{7E84186E-B5DE-4226-8A66-6E49C6B511B4}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{99066096-8989-4612-841F-621A01D54AD7}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{AE07101B-46D4-4A98-AF68-0333EA26E113}
Clé Présente : HKLM\SOFTWARE\Classes\CLSID\{FD501041-8EBE-11CE-8183-00AA00577DA2}
Clé Présente : HKLM\SOFTWARE\Classes\CrossriderApp0035510.BHO
Clé Présente : HKLM\SOFTWARE\Classes\CrossriderApp0035510.BHO.1
Clé Présente : HKLM\SOFTWARE\Classes\CrossriderApp0035510.Sandbox
Clé Présente : HKLM\SOFTWARE\Classes\CrossriderApp0035510.Sandbox.1
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{3F607E46-0D3C-4442-B1DE-DE7FA4768F5C}
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{55555555-5555-5555-5555-550355555510}
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{66666666-6666-6666-6666-660366556610}
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8FFE}
Clé Présente : HKLM\SOFTWARE\Classes\Interface\{FE0273D1-99DF-4AC0-87D5-1371C6271785}
Clé Présente : HKLM\SOFTWARE\Classes\secman.OutlookSecurityManager
Clé Présente : HKLM\SOFTWARE\Classes\secman.OutlookSecurityManager.1
Clé Présente : HKLM\SOFTWARE\Classes\TypeLib\{11549FE4-7C5A-4C17-9FC3-56FC5162A994}
Clé Présente : HKLM\SOFTWARE\Classes\TypeLib\{44444444-4444-4444-4444-440344554410}
Clé Présente : HKLM\SOFTWARE\Classes\TypeLib\{93E3D79C-0786-48FF-9329-93BC9F6DC2B3}
Clé Présente : HKLM\Software\iWebar
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{004db23c-1fbd-4b08-b947-0eb870864ddb}
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{02842f9f-fec3-4dfa-ad5f-f2bd573ee254}
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{5c74297e-fa36-432b-8c73-6be7cc232b64}
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{60afe9fb-e27c-484a-a3ba-09dd2597bb42}
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f3aed1da-89f9-4946-8c77-52f864982a33}
Clé Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{006EE092-9658-4FD6-BD8E-A21A348E59F5}
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\apnstub_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\iMesh_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\iMesh_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\iMesh_V11_en_Setup_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\iMesh_V11_en_Setup_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\privitizevpn_1_rasapi32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\privitizevpn_1_rasmancs
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\privitizevpn_rasapi32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\privitizevpn_rasmancs
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SnapDo_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SnapDo_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\softonic_ggl_1_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\softonic_ggl_1_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_daemon-tools_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_daemon-tools_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_rocketdock_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_rocketdock_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_the-logo-creator_RASAPI32
Clé Présente : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_the-logo-creator_RASMANCS
Clé Présente : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{11111111-1111-1111-1111-110311551110}
Clé Présente : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Présente : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\iWebar
Clé Présente : HKLM\Software\Myfree Codec
Clé Présente : HKLM\Software\PIP
Clé Présente : [x64] HKLM\SOFTWARE\Classes\CLSID\{00000001-4FEF-40D3-B3FA-E0531B897F98}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\CLSID\{11111111-1111-1111-1111-110311551110}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\CLSID\{22222222-2222-2222-2222-220322552210}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\CLSID\{64697678-0000-0010-8000-00AA00389B71}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\CLSID\{AE07101B-46D4-4A98-AF68-0333EA26E113}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{3F607E46-0D3C-4442-B1DE-DE7FA4768F5C}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{55555555-5555-5555-5555-550355555510}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{66666666-6666-6666-6666-660366556610}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8FFE}
Clé Présente : [x64] HKLM\SOFTWARE\Classes\Interface\{FE0273D1-99DF-4AC0-87D5-1371C6271785}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{004db23c-1fbd-4b08-b947-0eb870864ddb}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{02842f9f-fec3-4dfa-ad5f-f2bd573ee254}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{5c74297e-fa36-432b-8c73-6be7cc232b64}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{60afe9fb-e27c-484a-a3ba-09dd2597bb42}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{f3aed1da-89f9-4946-8c77-52f864982a33}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{11111111-1111-1111-1111-110311551110}
Clé Présente : [x64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}
Clé Présente : [x64] HKLM\SOFTWARE\Tarma Installer
Donnée Présente : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - c:\progra~2\searchprotect\searchprotect\bin\spvc32loader.dll
Donnée Présente : [x64] HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - C:\PROGRA~2\SearchProtect\SearchProtect\bin\SPVC64Loader.dll
Valeur Présente : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{AE07101B-46D4-4A98-AF68-0333EA26E113}]
Valeur Présente : [x64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{AE07101B-46D4-4A98-AF68-0333EA26E113}]
***** [ Navigateurs ] *****
-\\ Internet Explorer v11.0.9600.16518
-\\ Mozilla Firefox v27.0.1 (fr)
[ Fichier : C:\Users\geist\AppData\Roaming\Mozilla\Firefox\Profiles\3vz39weq.default\prefs.js ]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.InstallationThankYouPage", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.InstallationTime", 1388032285);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.active", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.addressbar", "NA");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.addressbarenhanced", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncdb.was_copied", "true");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncdb_dbWasSet", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncdb_dbWasSet_FF25_FIX", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncinternaldb.was_copied", "true");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncinternaldb_dbWasSet", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.asyncinternaldb_dbWasSet_FF25_FIX", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.backgroundver", 1);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.certdomaininstaller", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.changeprevious", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.InstallationTime.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.InstallationTime.value", "%221388032285%22");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.InstallerParams.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.InstallerParams.value", "%7B%22source_id%22%3A%22000172%22%2C%22sub_id%22%3A%220%22%2C%22uz[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.jw_token.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.jw_token.value", "%22a62c03cf-d323-0330-5512-7eccd4e22c19%22");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.uc.expiration", "Sat Mar 15 2014 18:29:17 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.uc.value", "%22%5C%22CA%5C%22%22");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.description", "iWebar");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.domain", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.enablesearch", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.homepage", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.iframe", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerIdentifiers.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerIdentifiers.value", "%7B%22installer_bic%22%3A%22BC0AF124DC79494BA0425EEA4D438[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerParams.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerParams.value", "%7B%22source_id%22%3A%22000172%22%2C%22sub_id%22%3A%220%22%2C%[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerParamsCache.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerParamsCache.value", "%7B%22source_id%22%3A%22000172%22%2C%22sub_id%22%3A%220%2[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerUserIdentifiersCache.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.InstallerUserIdentifiersCache.value", "%7B%22installer_bic%22%3A%22BC0AF124DC79494BA042[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_appVer.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_appVer.value", "239");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_lastVersion.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_lastVersion.value", "25");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_meta.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_meta.value", "%7B%22handlebars.js%22%3A%7B%22id%22%3A183015%2C%22ver%22%3A2%2[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_nextCheck.expiration", "Wed Mar 05 2014 18:39:18 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_nextCheck.value", "true");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_queue.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_queue.value", "%7B%7D");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_183015.expiration", "Fri May 30 2014 18:29:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_196378.expiration", "Tue Jun 03 2014 18:24:05 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353989.expiration", "Tue Jun 03 2014 18:24:05 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353990.expiration", "Fri May 30 2014 18:29:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353991.expiration", "Tue Jun 03 2014 18:24:05 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353991.value", "%22function%20md5cycle%28x%2C%20k%29%20%7B%5Cnvar%20[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_376579.expiration", "Fri May 30 2014 18:29:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_376579.value", "%22//Javascript%20Helper%20Functions%5Cr%5Cn%5Cr%5Cn[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_483924.expiration", "Tue Jun 03 2014 18:24:05 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_483925.expiration", "Tue Jun 03 2014 18:24:05 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_534129.expiration", "Fri May 30 2014 18:29:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_534129.value", "%22/*%21%20Cookies.js%20-%200.3.1%3B%20Copyright%20%[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.installer.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.installer.value", "%7B%22InstallerIdentifiers%22%3A%7B%22installer_bic%22%3A%22BC0AF124[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_bundledUrls.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)")[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_bundledUrls.value", "%7B%22dealply_s%22%3A%7B%22urls%22%3A%5B%22ssf[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_bundledWithHash.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Es[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_bundledWithHash.value", "null");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_last_executable_request.expiration", "Thu Mar 06 2014 05:05:22 GMT-[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_last_executable_request.value", "%22hxxp%3A//www.spybotupdates.biz/[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_notBundledArr_.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est[...]
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.monetization_plugin_notBundledArr_.value", "%5B%5D");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.lastDailyReport", "1394041157576");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.lastUpdate", "1394041152999");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.manifesturl", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.name", "iWebar");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.newtab", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.opensearch", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.pluginsurl", "hxxps://w9u6a2p6.ssl.hwcdn.net/plugin/apps/35510/plugins/093/ff/plugins.json");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.pluginsversion", 106);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.publisher", "iWebar");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.searchstatus", 0);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.setnewtab", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.thankyou", "");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.updateinterval", 360);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.ver", 239);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.FilesValidatorDueTime", "1394041818987");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.apps", "35510");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.bic", "1447fc3bb6368af85cf5c74c90c5cc68");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.cid", 35510);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.firstrun", false);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.hadappinstalled", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.installationdate", 1393712938);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.modetype", "production");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.reportInstall", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.statsDailyCounter", 5);
Ligne Trouvée : user_pref("extensions.crossrider.bic", "1447fc3bb6368af85cf5c74c90c5cc68");
[ Fichier : C:\Users\THOMAS\AppData\Roaming\Mozilla\Firefox\Profiles\zx2bk18q.default\prefs.js ]
Ligne Trouvée : user_pref("browser.newtab.url", "hxxp://feed.snapdo.com/?publisher=Somoto&dpid=Somoto&co=CA&userid=305d859b-b5b6-3d2a-6267-5f1a90eade86&searchtype=nt&installDate=13/01/2014");
Ligne Trouvée : user_pref("browser.search.defaultenginename", "Web Search");
Ligne Trouvée : user_pref("browser.search.selectedEngine", "Web Search");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.InstallationThankYouPage", true);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.jw_token.value", "%22a146d3b9-16e9-a4f2-f12f-0e1043ade38c%22");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.cookie.uc.expiration", "Sun Mar 16 2014 20:45:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_appVer.value", "237");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_nextCheck.expiration", "Tue Mar 04 2014 06:50:35 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_remote_resources.expiration", "Fri Feb 01 2030 00:00:00 GMT-0500 (Est)");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_remote_resources.value", "%7B%22remoteId%22%3A0%7D");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_183015.expiration", "Wed Mar 26 2014 01:17:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_196378.expiration", "Mon Jun 02 2014 01:50:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353989.expiration", "Mon Jun 02 2014 01:50:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353990.expiration", "Wed Mar 26 2014 01:17:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_353991.expiration", "Mon Jun 02 2014 01:50:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_376579.expiration", "Wed Mar 26 2014 01:17:12 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_483924.expiration", "Mon Jun 02 2014 01:50:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_483925.expiration", "Mon Jun 02 2014 01:50:58 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.internaldb.Resources_resource_534129.expiration", "Sat May 24 2014 03:11:32 GMT-0400");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.lastDailyReport", "1393912235256");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.lastUpdate", "1393912234889");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.pluginsversion", 104);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.35510.ver", 237);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.FilesValidatorDueTime", "1393912294146");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.bic", "1432d55ba53e3272784e06528548e644");
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.installationdate", 1388035030);
Ligne Trouvée : user_pref("extensions.a2eb528f3950d48a3be4b5d7de6c8331ea41e199b6ca44d23ab8773f2d1973314com35510.statsDailyCounter", 13);
Ligne Trouvée : user_pref("extensions.crossrider.bic", "1432d55ba53e3272784e06528548e644");
Ligne Trouvée : user_pref("keyword.URL", "hxxp://feed.snapdo.com/?publisher=Somoto&dpid=Somoto&co=CA&userid=305d859b-b5b6-3d2a-6267-5f1a90eade86&searchtype=ds&installDate=13/01/2014&q=");
-\\ Google Chrome v33.0.1750.146
[ Fichier : C:\Users\geist\AppData\Local\Google\Chrome\User Data\Default\preferences ]
[ Fichier : C:\Users\THOMAS\AppData\Local\Google\Chrome\User Data\Default\preferences ]
[ Fichier : C:\Users\Simon.geist-PC\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [47457 octets] - [05/03/2014 17:31:14]
########## EOF - C:\AdwCleaner\AdwCleaner[R0].txt - [47518 octets] ##########
Rapport MalwareByte
Malwarebytes Anti-Malware 1.75.0.1300
www.malwarebytes.org
Version de la base de données: v2014.03.05.11
Windows 7 Service Pack 1 x64 NTFS
Internet Explorer 11.0.9600.16518
geist :: GEIST-PC [administrateur]
2014-03-05 17:43:34
mbam-log-2014-03-05 (17-43-34).txt
Type d'examen: Examen rapide
Options d'examen activées: Mémoire | Démarrage | Registre | Système de fichiers | Heuristique/Extra | Heuristique/Shuriken | PUP | PUM
Options d'examen désactivées: P2P
Elément(s) analysé(s): 292673
Temps écoulé: 7 minute(s), 33 seconde(s)
Processus mémoire détecté(s): 0
Module(s) mémoire détecté(s): 0
Clé(s) du Registre détectée(s): 3
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{A5A51D2A-505A-4D84-AFC6-E0FA87E47B8C} (PUP.Optional.ShopperPro.A) -> Mis en quarantaine et supprimé avec succès.
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{A5A51D2A-505A-4D84-AFC6-E0FA87E47B8C} (PUP.Optional.ShopperPro.A) -> Mis en quarantaine et supprimé avec succès.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{A5A51D2A-505A-4D84-AFC6-E0FA87E47B8C} (PUP.Optional.ShopperPro.A) -> Mis en quarantaine et supprimé avec succès.
Valeur(s) du Registre détectée(s): 0
Elément(s) de données du Registre détecté(s): 0
Dossier(s) détecté(s): 2
C:\Users\geist\AppData\Local\Google\Chrome\User Data\Default\Extensions\cigiagpbkapepgklncnajbakkpkopmam (PUP.Optional.CrossRider.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\AppData\Local\Google\Chrome\User Data\Default\Extensions\cigiagpbkapepgklncnajbakkpkopmam (PUP.Optional.CrossRider.A) -> Mis en quarantaine et supprimé avec succès.
Fichier(s) détecté(s): 14
C:\Users\geist\Desktop\DTLite4461-0327.exe (PUP.Optional.OpenCandy) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\AppData\Local\Temp\ShopperProJSFull.exe (PUP.Optional.ShopperPro.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\Downloads\BitLordInstall.exe (PUP.Optional.InstallCore.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\Downloads\Daemon-Tools-Lite.exe (PUP.Optional.InstallCore) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\Downloads\SoftonicDownloader_pour_aviaddxsubs.exe (PUP.Optional.Softonic.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\Downloads\SoftonicDownloader_pour_daemon-tools.exe (PUP.Optional.Softonic.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Simon.geist-PC\Downloads\SoftonicDownloader_pour_rocketdock.exe (PUP.Optional.Softonic.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\CR_Downloader_pour_super-smash-bros.-melee-(v1.02) (1).exe (PUP.Optional.InstallCore.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\CR_Downloader_pour_super-smash-bros.-melee-(v1.02).exe (PUP.Optional.InstallCore.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\FlightSim_RocketFuelInstaller (1).exe (PUP.Optional.RocketFuel.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\FlightSim_RocketFuelInstaller.exe (PUP.Optional.RocketFuel.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\photoshop cs6.rar (PUP.RiskwareTool.CK) -> Mis en quarantaine et supprimé avec succès.
C:\Users\THOMAS\Downloads\TinyMediaPlayer_RocketFuelInstaller.exe (PUP.Optional.RocketFuel.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\geist\AppData\Local\Installer\Install_1596\sense.exe (PUP.Optional.Bundler) -> Mis en quarantaine et supprimé avec succès.
(fin)
Enfin, le lien
http://cjoint.com/?0Cgai6iDT6n
Merci encore.
Jeanno
Rapport AdwCleaner
# Option : Scanner
Rapport MalwareByte
2014-03-05 17:43:34
(fin)
Enfin, le lien
Merci encore.
Jeanno
Désinstalle Spybot - Search & Destroy v2.2.25 devenu obsolète.
Mets à jour ces deux logiciels.
Java Runtime Environment
Ouvre cette page
Coche Accept License Agreement .
Clique sur Windows x86 Offline - 27.79 MB -
jre-7u51-windows-i586.exe
Installe le fichier téléchargé.
Lis les clauses en cours d'installation. (Il n'est pas nécessaire d'installer les programmes tiers proposés).
Désinstalle toutes les autres versions existantes sur ton pc dans Ajout/Suppression des programmes ou Programmes et fonctionnalités selon le système.
Si tu ne modifies pas les paramètres, les nouvelles versions te seront proposées au téléchargement automatiquement.
La version 64 bit n'est utile que pour l'utilisation d'un navigateur en 64bit
Acrobat Reader XI
Ouvre cette page
Choisis ton système d'exploitation, la langue souhaitée, la version Reader 11.0.6 French for Windows
Décoche
Oui, installer McAfee Security Scan Plus (facultatif) (0.98MO)
Clique sur
Télécharger dès maintenant
L'installation se fera automatiquement en cliquant sur le fichier obtenu :
install_reader11_fr_mssd_aih.exe
Ce fichier s'auto-détruira.
Lance ZHPFix par l'icône sur le bureau
Clique sur Importer dans la fenêtre de l'outil et sur OK dans le message suivant
Tu copies le script suivant (dans l'encadré Code ci-dessous)
Tu le colles dans la fenêtre de ZHPFix comme ci-dessous, sans ligne vide au début, tu cliques sur GO pour le lancer.
Confirme la suppression par Oui dans l'avertissement qui s'affiche
Le résultat va s'afficher dans la fenêtre de l'outil et un rapport va s'ouvrir avec le bloc-notes.
Tu envoies un copier-coller du rapport dans ta réponse, il est enregistré sur le bureau.
Ouvre cette pageCoche Accept License Agreement .
jre-7u51-windows-i586.exeInstalle le fichier téléchargé.
Acrobat Reader XI
Ouvre cette pageChoisis ton système d'exploitation, la langue souhaitée, la version Reader 11.0.6 French for Windows
Décoche
Oui, installer McAfee Security Scan Plus (facultatif) (0.98MO)Clique sur
Télécharger dès maintenantL'installation se fera automatiquement en cliquant sur le fichier obtenu :
Tu copies le script suivant (dans l'encadré Code ci-dessous) Code : Tout sélectionner
Script ZHPFix
C:\ProgramData\ShopperPro
C:\Windows\Prefetch\SHOPPERPROJSFULL.EXE-184CAC64.pf
C:\Windows\Prefetch\SHOPPERPRO.EXE-94DAAA42.pf
C:\Users\geist\Downloads\AntiCrashSetup.exe
EmptyFlash
EmptyTemp
EmptyCLSID
Voilà c'est fait. J'ai utilisé çi-joint pour le rapport car il est trop long. Voici le lien
http://cjoint.com/?0CgpMhfJohS
Merci.
Merci.
Pour terminer, nous allons supprimer tout ce qui n'est plus nécessaire et qui nous a servi à mener à bien cette désinfection.
Relance AdwCleaner par le bouton Désinstaller.
Vide la quarantaine de Malwarebytes.
Ouvre l'onglet Quarantaine et clique sur le bouton Tout supprimer
Referme le programme.
[sub]
[/sub] TFC de OldTimer
Sous Vista et Windows 7, il faut être sous un compte administrateur
Ferme toutes applications en sauvegardant le travail en cours sinon l'outil le fera.
Clique sur l'icône en forme de poubelle et sur le bouton Start.
Quand le nettoyage sera terminé, clique sur le bouton Exit pour quitter l'outil.
[sub]
[/sub] delfixsur ton bureau en cliquant sur Télécharger.[/b]
Il ne nécessite pas d'installation
Il va supprimer les outils utilisés pour cette désinfection.
Clique sur le fichier delfix.exe pour lancer l'outil.
Icône du fichier
Coche la case Supprimer les outils
Puis clique sur le bouton Exécuter
Passe la question en résolu
Edite le titre du message d'origine et ajoute [résolu]
Maintenant que nous avons remis le pc au clair, il serait judicieux de ne pas avoir à recommencer.
Je t'invite à lire ce que va t'afficher le lien ci-dessous. Clique dessus.
Conseils à lire
Bloquer les publicités inacceptables sur le Web
Vide la quarantaine de Malwarebytes.Ouvre l'onglet Quarantaine et clique sur le bouton Tout supprimer
[sub]
[/sub] TFC de OldTimerSous Vista et Windows 7, il faut être sous un compte administrateur
Clique sur l'icône en forme de poubelle et sur le bouton Start.Quand le nettoyage sera terminé, clique sur le bouton Exit pour quitter l'outil.
[sub]
[/sub] delfixsur ton bureau en cliquant sur Télécharger.[/b]Il ne nécessite pas d'installation
Clique sur le fichier delfix.exe pour lancer l'outil.Icône du fichier
Coche la case Supprimer les outilsPuis clique sur le bouton Exécuter
Passe la question en résoluEdite le titre du message d'origine et ajoute [résolu]
Conseils à lire
Re: [Résolu] ecran bleu de la mort
Merci beaucoup!!!
