ECRAN BLEU INTEMPESTIF AVEC PC PORTABLE
miaou18
Message par miaou18 »
j'ai très souvent un ecran bleu avec du texte qui apparait
et le pc redémarre
j'ai ceci :
System Information (local)
computer name: PC-TOSHIBA
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz Intel586, level: 6
RAM: 4146774016 total
VM: 2147352576, free: 1989455872
Crash Dump Analysis
On Wed 02/03/2011 17:59:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-27456-01.dmp
This was probably caused by the following module: ndis.sys (ndis+0x2AF9F)
Bugcheck code: 0x100000B8 (0xFFFFFA8004B59B60, 0xFFFFF880009F3FC0, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\ndis.sys
description: Pilote NDIS 6.20
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0xB8 (0xFFFFFA8004B59B60, 0xFFFFF880009F3FC0, 0x0, 0x0)
Error: ATTEMPTED_SWITCH_FROM_DPC
Bug check description: This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
On Wed 02/03/2011 17:55:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-27549-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x82EDA)
Bugcheck code: 0x100000B8 (0xFFFFFA8003B2D9C0, 0xFFFFF8800396DFC0, 0x0, 0x0)
Error: CUSTOM_ERROR
On Wed 02/03/2011 17:47:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-27830-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0x25C2)
Bugcheck code: 0x100000B8 (0xFFFFFA8004B56B60, 0xFFFFFA8003B52B60, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\usbport.sys
description: Pilote de port USB 1.1 & 2.0
On Wed 02/03/2011 13:57:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-18111-01.dmp
Bugcheck code: 0x100000B8 (0xFFFFFA8003B6EB60, 0xFFFFFA800758C060, 0x0, 0x0)
Error: CUSTOM_ERROR
On Wed 02/03/2011 13:55:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-17862-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x80610)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Fri 25/02/2011 11:33:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022511-44288-01.dmp
On Fri 25/02/2011 10:57:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022511-20451-02.dmp
Bugcheck code: 0x100000B8 (0xFFFFFA8004041660, 0xFFFFF80003254CC0, 0x0, 0x0)
Error: CUSTOM_ERROR
On Fri 25/02/2011 06:04:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022511-17300-01.dmp
On Fri 25/02/2011 06:00:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022511-20451-01.dmp
This was probably caused by the following module: tcpip.sys (tcpip+0x85D22)
file path: C:\Windows\system32\drivers\tcpip.sys
description: Pilote TCP/IP
Conclusion
10 crash dumps have been found and analyzed.
merci de m'aider pour ce pc portable
