Ecran bleu et Who Crashed
Bonjour voilà j'ai suivi le tuto !
System Information (local)
computer name: PC-DE-SERGE
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) 8250e Triple-Core Processor AMD586, level: 16
3 logical processors, active mask: 7
RAM: 4293451776 total
VM: 2147352576, free: 1884225536
Crash Dump Analysis
On Sun 27/02/2011 11:37:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022711-31683-01.dmp
This was probably caused by the following module: tcpip.sys (tcpip+0x13116F)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\tcpip.sys
description: Pilote TCP/IP
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: snapman.sys (snapman+0x1CF09)
file path: C:\Windows\system32\drivers\snapman.sys
product: Acronis Snapshot API
company: Acronis
description: Acronis Snapshot API
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: snapman.sys (Acronis Snapshot API, Acronis).
Google query: snapman.sys Acronis KMODE_EXCEPTION_NOT_HANDLED
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Merci de votre aide
Serge
Crash Dump Analysis
company: Acronis
Conclusion
Merci de votre aide
Serge
Re: Ecran bleu et Who Crashed
salut !
le souci est simple, c'est acronis true image qui pose souci. Tu le désinstalles complètement avec Revo Uninstaller, puis tu le réinstalles.
Merci de ta réponse mais si je le réinstalle je vais avoir de nouveau le problème ! non ?
Salut !
pas forcément, il suffit parfois d'une désinstallation/Réinstallation pour résoudre un problème.
ok merci il ne peut y avoir autre chose ?
apparemment le rapport ne parle que de acronis
normalement, non mais attends un second avis.
Bonjour serge152
Oui - du meme avis que breizhspotlight - cela concerne acronis ....
Mais tu ne parles pas des circonstances d apparition du BSOD - est ce peu apres l installation d Acronis ?
Un virus me parait a envisager ?
Merci de ta réponse,
Non je ne saurai te dire si c'est peu après l'install. d'acronis ! c'est tellement aléatoire ! de plus acronis est installé mais non activé !!!
tout ce que je sais c'est que je n'avais en deux ans jamais eu cet écran bleu ! avant d'installer Acronis.
Par contre je l'ai installé sur un autre PC et là aussi j'ai eu l'écran bleu, mais je n'ai pas pensé à noter le fichier minidump et je ne l'ai plus, à voir si cela se reproduit ...
Les circonstances d'apparition sont indéfinissables, sans raisons apparentes !
Pour ce qui est du virus je ne pense pas, j'ai fait plusieurs scan avec des outils différents.
Je vous livre ici mon expérience car ce post m'a interpellé.
Je vais essayer de synthétiser.
Novembre 2010,nouveau PC assemblé avec Seven 64 et SSD.
2 ou 3 jours se passent bien et j'installe mes softs comme CCleaner dont j'use et abuse
depuis longtemps avec XP, puis j'achète Acronis True Image Home 2011 et l'installe.
Et c'est là que les ennuis commencent. BSOD à répétition. Je mets cela sur le compte de beaucoup de nouveautés en même temps. Seven en 64, SSD 6Gbs, USB 3.0, écran HDMI etc. et surtout CCleaner que j'utilise peut-être trop au niveau de sa fonction registre.
J'en parle à l'assembleur, il regarde le montage et ne trouve rien d'anormal. Jusqu'au 14/02, là où je craque et je décide de lui demander de réinstaller 7 sur un SSD passé à l'eau de Javel.
Et à part Office 2007 et l'antivirus AVG Free ( pas trop intrusif, par rapport à d'autres), je roule comme ça. Je ne remets même pas CCleaner.
Tout fonctionne à merveille, mon historique de fiabilité flirte avec le 9 /10.
Je décide donc de remettre mes logiciels petit à petit, mais un soft à la fois et je commence par ATIH 2011. Je ne remets TOUJOURS pas CCleaner.
Le lendemain, BSOD, le sur-lendemain nouveau BSOD.
Je n'en conclus rien à la hâte, mais j'ai désinstallé ATIH 2011 et prévenu le support avec qui j'entretien des relations depuis le début car mes sauvegardes se passaient mal.
A suivre donc, mais si je n'ai plus de BSOD d'ici quelques jours, que devrai-je en conclure
Merci de m'avoir lu.
