BSOD Fréquent
Nko78
BSOD Fréquent
Message par Nko78 »
Bonjour à tous :)
Depuis 2 jours, je n'arrive plus à allumer mon ordinateur, un BSOD arrive de suite "IRQL_NOT_LESS_OR_EQUAL".
Je n'arrive à accéder à mon bureau Windows 7 seulement en "mode sans échec avec prise en charge réseau".
Auparavant, j'ai eu aussi assez régulièrement des BSOD mais rien qui ne m’empêchais d'allumer mon ordinateur.
Comme conseillé, j'ai téléchargé le logiciel "Whocrashed" et j'ai effectué l'analyse, que voici:
Crash Dump Analysis
On Mon 14/02/2011 12:50:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021411-19016-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x90BD4)
Bugcheck code: 0xA (0x8, 0x2, 0x1, 0xFFFFFFFF82C7EB69)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Google query: dxgkrnl.sys Microsoft Corporation IRQL_NOT_LESS_OR_EQUAL
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrResetFromTimeout+0x321B)
On Sun 13/02/2011 13:58:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021311-17472-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x120996)
Bugcheck code: 0x19 (0x3, 0xFFFFFFFFAA2B6A80, 0xFFFFFFFFA470ADD0, 0xFFFFFFFFA4073810)
Error: BAD_POOL_HEADER
file path: C:\Windows\system32\ntkrnlpa.exe
Bug check description: This indicates that a pool header is corrupt.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Fri 11/02/2011 16:58:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021111-18252-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x4682B)
Bugcheck code: 0xA (0xFFFFFFFF8B45D543, 0x0, 0x0, 0xFFFFFFFF82CC4631)
On Wed 02/02/2011 18:55:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020211-31465-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x120067)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82D2D067, 0xFFFFFFFF95E75AAC, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Wed 02/02/2011 18:54:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020211-23992-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x11F1B6)
Bugcheck code: 0x19 (0x20, 0xFFFFFFFF88738478, 0xFFFFFFFF887386E8, 0xA4E080B)
On Wed 02/02/2011 18:48:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020211-20716-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x99227)
Bugcheck code: 0x19 (0x20, 0xFFFFFFFFA5043138, 0xFFFFFFFFA50433F0, 0xA570208)
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
On Wed 02/02/2011 18:47:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\020211-17830-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x747AD)
Bugcheck code: 0xDE (0x2, 0xFFFFFFFFB30EB278, 0xFFFFFFFFA6B76249, 0x2F5918C4)
Error: POOL_CORRUPTION_IN_FILE_AREA
Bug check description: This indicates that a driver has corrupted pool memory that is used for holding pages destined for disk.
On Thu 27/01/2011 16:38:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012711-17815-01.dmp
Bugcheck code: 0x19 (0x3, 0xFFFFFFFFA773DC70, 0xFFFFFFFFAE007400, 0x31002E00)
On Tue 25/01/2011 17:54:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\012511-16161-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0xDCD10)
Bugcheck code: 0x4E (0x99, 0x73EC5, 0x2, 0x73E84)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
On Sun 16/01/2011 19:18:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011611-21949-01.dmp
Bugcheck code: 0x19 (0x20, 0xFFFFFFFFA253D238, 0xFFFFFFFFA253D4D0, 0xA530201)
On Sun 16/01/2011 19:16:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011611-15724-01.dmp
Bugcheck code: 0xC2 (0x7, 0x1097, 0x0, 0xFFFFFFFFA474FD00)
Error: BAD_POOL_CALLER
Bug check description: This indicates that the current thread is making a bad pool request.
On Sun 16/01/2011 19:14:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011611-16738-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0xA7590)
Bugcheck code: 0x1A (0x403, 0xFFFFFFFFC000A038, 0x23443867, 0xFFFFFFFFC047A050)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
On Sun 16/01/2011 19:09:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011611-17128-01.dmp
Bugcheck code: 0x1A (0x403, 0xFFFFFFFFC00324B8, 0x42F8E867, 0xFFFFFFFFC0000002)
On Sun 16/01/2011 19:07:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011611-16192-01.dmp
Bugcheck code: 0x19 (0x20, 0xFFFFFFFFA2245EB8, 0xFFFFFFFFA22460D0, 0xA43060D)
Conclusion
20 crash dumps have been found and analyzed. Only 15 are included in this report. 3 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
dxgkrnl.sys (DirectX Graphics Kernel, Microsoft Corporation)
dxgmms1.sys (DirectX Graphics MMS, Microsoft Corporation)
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
J'ai moi même effectué quelques recherche mais je n'ai rien trouvé de concluant.
En espérant que quelqu’un puisse m'aider :)
Je vous remercie d'avance,
Nko78 :coucou:
Re: BSOD Fréquent
ceci
indique que tu as des pilotes qui ne sont pas à jour d'ou peut-être les crash
20 décharges crash ont été retrouvés et analysés. Seulement 15 sont inclus dans le présent rapport. 3 pilotes tiers ont été identifiés pour être à l'origine plantage du système sur votre ordinateur. Il est fortement recommandé que vous vérifiez les mises à jour de ces pilotes sur leurs sites Web d'entreprise. Cliquez sur les liens ci-dessous pour des recherches avec Google pour les mises à jour de ces pilotes:
dxgkrnl.sys (DirectX Graphics noyau, Microsoft Corporation)
Si aucune mise à jour de ces pilotes sont disponibles, essayez de chercher avec Google sur les noms de ces pilotes en combinaison les erreurs qui ont été rapportées pour ces pilotes et inclure le nom de marque et le modèle de votre ordinateur ainsi dans la requête. Cela donne souvent des résultats intéressants des discussions des utilisateurs qui ont connu des problèmes similaires.
regarde du côté de ton gestionnaire de périphériques si tout est ok puis chez ton fabricant d'ordinateur pour mettre à jour tes pilotes graphiques
Nko78
Re: BSOD Fréquent
Message par Nko78 »
Tout d'abord merci de ta réponse :)
Je viens de télécharger la dernière mise à jour du driver de ma CG ( HD4890) mais en mode sans échec lorsque j'essai de faire l'installation, celà n'est pas possible : "Impossible de charger le pilote de détection". D'où peux venir le problème?
J'ai aussi fais un memtest86 par usb pour tester ma barrette mémoire de 2GO et voici ce que j'obtiens:
Je ne sais pas du tout décrypter ceci, mes BSOD viendraient il de là?
Nko78
Re: BSOD Fréquent
Message par Nko78 »
Personne? :)
Re: BSOD Fréquent
Inutile de chercher plus loin.
Ta mémoire vive est défaillante.
Il faut envisage le remplacement
