Je revient avec une petite question. J'ai un pc tous neuf (1 mois) sous win7. Depuis quelques temps (15 jours) j'ai eu plusieurs bluescreens au début lorsque j'étais sur internet et maintenant quand je suis sous office. J'ai fait un rapport avec Whocrashed. sa donne :
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: AuthenticAMD AMD Athlon(tm) II X2 215 Processor AMD586, level: 16
2 logical processors, active mask: 3
RAM: 4025868288 total
VM: 2147352576, free: 1975541760
Crash Dump Analysis
On Sat 08/01/2011 14:58:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\010811-13962-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0xB73F4)
Bugcheck code: 0x50 (0xFFFFFFFFF9C15928, 0x1, 0xFFFFF80002AA25BE, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
Bug check description: This indicates that invalid system memory has been referenced.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
This was probably caused by the following module: aswsp.sys (aswSP+0x169BF)
file path: C:\Windows\system32\drivers\aswsp.sys
product: avast! Antivirus System
company: AVAST Software
description: avast! self protection module
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: aswsp.sys (avast! self protection module, AVAST Software).
Google query: aswsp.sys AVAST Software PAGE_FAULT_IN_NONPAGED_AREA
On Sun 26/12/2010 15:11:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\122610-14648-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002DBFDE0, 0xFFFFF88007B48110, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Sat 18/12/2010 08:02:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121810-20841-01.dmp
Bugcheck code: 0xD1 (0x57FFA6E2B98, 0x2, 0x8, 0x57FFA6E2B98)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
On Fri 17/12/2010 13:52:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\121710-17362-01.dmp
Bugcheck code: 0xD1 (0x28, 0x2, 0x0, 0xFFFFF88003DAFD24)
Conclusion
5 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Voila j'espère que quelqu'un pourra m'aidé car je ne comprend pas tous (au bluescreen).
probleme Blue Screen windows 7
firestream
Alain Quarré
Re: probleme Blue Screen windows 7
Sais-tu démarrer en mode sans échec (en tapotant F8 pendant le démarrage de l'ordi, AVANT le démarrage de Windows?
Avast semble en cause dans ces crashs.
Désinstalle-le pour tester.
S'agit-il d'une version commerciale ou gratuite ?
firestream
Ok, oui je sais démarrer en mode sans échec pourquoi?
Ok je vais voir avec avast, il me semble bien que la personne qui s'en sert au quotidien ma parler d'un message d'erreur avast.
Je vais voir sa jeudi, et je vous tiendrais au courant.
Si c'est de avast que tu parle c'est la version gratuite. Cet ordianteur ne sert qu'a la rédaction de texte et a l'envoi de mail, donc pas besoin d'un antivirus de fous.
Sinon je sais plus si j'ai précisé c'est une version légal de win7 qui était équiper d'origine.
Salut !
As-tu résolu ton problème et si oui comment ? car j'ai aussi un bluescreen au démarrage et même rapport avec whocrashed...
