Voilà je viens poster ici pour un problème d'écran bleu à répétition !
Ma config :
Intel® Core™ 2 Quad Q9400
Gainward Radeon™ HD 4850 512 Mo Golden Sample Edition
Asus P5Q SE2
Cooler Master Hyper 212
Razer Salmosa
Microsoft Reclusa
Crucial Ballistix Tracer DDRII 2 x 2 Go PC6400
Pioneer DVR-216D
Samsung SyncMaster T200
L'analyse complète de WhoCrashed :
On Tue 07/09/2010 13:17:31 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8000E57D90, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\090710-22776-01.dmp
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Tue 07/09/2010 13:09:18 your computer crashed
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8000E582D0, 0xFFFF, 0x0)
Dump file: C:\Windows\Minidump\090710-22495-01.dmp
On Tue 07/09/2010 12:52:02 your computer crashed
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002AA09A0, 0xFFFFF880089E6000, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Dump file: C:\Windows\Minidump\090710-22370-01.dmp
On Tue 07/09/2010 07:37:24 your computer crashed
Bugcheck code: 0x4E (0x2, 0x85BF7, 0x12FFFF, 0x1)
Error: PFN_LIST_CORRUPT
Dump file: C:\Windows\Minidump\090710-24741-01.dmp
On Sun 05/09/2010 15:17:34 your computer crashed
Bugcheck code: 0x1A (0x8884, 0xFFFFFA8000AEA2F0, 0xFFFFFA8000B78190, 0x205)
Dump file: C:\Windows\Minidump\090510-24616-01.dmp
Conclusion
5 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Merci à ceux qui prendront un peu de temps pour m'aider à régler ce problème des plus embêtant
Bonne journée !
