Plantage pc
deimos6544
Plantage pc
Message par deimos6544 »
Bonjour as tous
il y as as peu pres deux jours que mon pc as commencer as planter depuis la mise as jour de mes drivers de carte graphique ,malgrer apres avoir désintaller correctement les drivers et remis les anciens , mon pc plante toujours .
le plantage se suit sur un freeze de l ecran et du son et que je suis obliger de rebooter mon pc
etant donner que j ai deja lu le forum as la recherche d information , je vous communique le rapport de whocrashed:
Analysis
On Mon 05/04/2010 23:43:21 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x124 (0x0, 0x861548FC, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
Dump file: C:\Windows\Minidump\040510-19422-01.dmp
On Mon 05/04/2010 23:10:35 your computer crashed
Bugcheck code: 0x124 (0x0, 0x862BB024, 0x0, 0x0)
Dump file: C:\Windows\Minidump\040510-20763-01.dmp
On Sat 03/04/2010 07:18:07 your computer crashed
Bugcheck code: 0x124 (0x0, 0x860C98FC, 0x0, 0x0)
Dump file: C:\Windows\Minidump\040310-23384-01.dmp
On Fri 02/04/2010 22:24:05 your computer crashed
Bugcheck code: 0x124 (0x0, 0x862FA024, 0x0, 0x0)
Dump file: C:\Windows\Minidump\040210-17737-01.dmp
On Thu 01/04/2010 19:53:43 your computer crashed
Bugcheck code: 0x124 (0x0, 0x8638C8FC, 0x0, 0x0)
Dump file: C:\Windows\Minidump\040110-18564-01.dmp
On Wed 31/03/2010 23:14:33 your computer crashed
Bugcheck code: 0x124 (0x0, 0x863CE63C, 0x0, 0x0)
Dump file: C:\Windows\Minidump\033110-17940-01.dmp
On Mon 04/01/2010 18:03:16 your computer crashed
Bugcheck code: 0x124 (0x0, 0x8631E594, 0x0, 0x0)
Dump file: C:\Windows\Minidump\010410-22526-01.dmp
On Mon 04/01/2010 00:22:25 your computer crashed
Bugcheck code: 0x124 (0x0, 0x8563738C, 0x0, 0x0)
Dump file: C:\Windows\Minidump\010410-35303-01.dmp
On Sat 02/01/2010 17:39:20 your computer crashed
Bugcheck code: 0x124 (0x0, 0x863238FC, 0x0, 0x0)
Dump file: C:\Windows\Minidump\010210-18922-01.dmp
Conclusion
9 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
je vous remercie d avance pour votre aide :)
Re: Plantage pc
Message par SYNTAX-ERROR »
Lis ce topic:topic4465.html
Apparemment il s'agit d'un problème matériel.
