Je m'inscris et déterre un vieux sujet car j'ai exactement le même problème (post29586.html#p29586). Pouvez vous y jetez un œil svp?
Code : Tout sélectionner
58367680 (2892) - winsat\logging.cpp:0815: --- START 2010\3\29 19:28:57 ---
58367680 (2892) - winsat\main.cpp:4301: Command Line = "C:\Windows\system32\winsat.exe" formal -cancelevent 1491fa6d-da39-4951-a2a8-e00dabaebb29
58367680 (2892) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
58367696 (2892) - winsat\main.cpp:4474: > IsFormal=TRUE IsMoobe=FALSE.
58367727 (2892) - winsat\main.cpp:4585: Watch dog system enabled
58367727 (2892) - winsat\main.cpp:4600: Main watch dog timer set to 600.0 seconds
58367883 (2892) - winsat\main.cpp:2490: > DWM Running.
58368101 (2892) - winsat\main.cpp:2497: > turning off DWM.
58368101 (2892) - winsat\main.cpp:2470: > EMD service will be restored on exit.
58368101 (2892) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
58368101 (2892) - winsat\main.cpp:2793: > power policy saved.
58368132 (2892) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
58368132 (2892) - winsat\main.cpp:2814: > power policy set to maximum.
58368944 (2892) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
58368944 (2892) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
58368944 (2892) - winsat\main.cpp:1775: > Run Assessment features
58376276 (2892) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
58388054 (2892) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 29764400
58388054 (2892) - winsat\main.cpp:2037: > DWM Assessment results processing SUCCESS
58388054 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
58394153 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
58400253 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
58408131 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
58416649 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
58424667 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
58431734 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
58452935 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
58474759 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomF4 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 150;200;241 -batchcnt C(50);C(200);C(300) -objs C(12);C(26);C(45) -noalpha -geomf4shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
58483682 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomV8 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75;100;120 -batchcnt C(25);C(100);C(150) -objs C(8);C(17);C(29) -noalpha -geomv8shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
58492590 (2892) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname CBuffer -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75 -batchcnt C(25) -objs C(8) -rendertotex 6 -rtdelta 3 -texpobj C(1) -cbuffershader -cbufa 2 -cbuff 5 -cbufp 6
58498877 (2892) - winsat\main.cpp:1775: > Run Assessment mfmedia -input C:\Windows\Performance\WinSAT\winsat.wmv -nopmp
58500452 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_MPEG2_HD_15mbps.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
58506677 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_VC1_15mbps.wmv -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
58512636 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480i_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
58518720 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480p_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
58524695 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_10mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
58530670 (2892) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480_5sec_6mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
58536567 (2892) - winsat\main.cpp:1775: > Run Assessment media -input C:\Windows\Performance\WinSAT\winsatencode.wmv -encode C:\Windows\Performance\WinSAT\winsat.prx
58536738 (2892) - media\mediaerror.cpp:0151: mediaencode.cpp @ 572: 0xc00d1b5e == Unknown
58536738 (2892) - media\mediaerror.cpp:0151: mediatest.cpp @ 479: 0xc00d1b5e == Unknown
58536738 (2892) - media\mediaerror.cpp:0095: Erreur : WinSAT n’a pas pu initialiser l’encodeur WMV.
58536738 (2892) - winsat\main.cpp:2056: > media Assessment FAILED due to an error
58536738 (2892) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 29764400
58536832 (2892) - winsat\processresults.cpp:1253: Skipping StdDefPlayback limit check.
58536832 (2892) - winsat\processresults.cpp:1265: Skipping StdDefPlayback limit check.
58536832 (2892) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 0
58536847 (2892) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
58536847 (2892) - winsat\main.cpp:2855: > Power state restored.
58536847 (2892) - winsat\main.cpp:2870: > Successfully reenabled EMD.
58536863 (2892) - winsat\main.cpp:2896: > Composition restarted
58536863 (2892) - winsat\watchdog.cpp:0311: Watch dog system shutdown
58536863 (2892) - winsat\main.cpp:4909: > exit value = 1.
