Il m'est impossible de faire l'indice de performance. J'ai Windows 7 pro 64bits. J'ai avast car j'avais lu que cela pouvait venir de Kapersky.
Voici le fichier winsat. Peut être que quelque chose m'échappe.
Code : Tout sélectionner
2551458 (4328) - winsat\logging.cpp:0815: --- START 2009\12\3 08:18:53 ---
2551458 (4328) - winsat\main.cpp:4301: Command Line = "C:\Windows\system32\winsat.exe" formal -cancelevent 87518142-7f1b-45a9-9044-4dd49dd5f26d
2551458 (4328) - winsat\processwinsaterror.cpp:0095: ERROR: tried to read resource strings, unknown exception occured
2551599 (4328) - winsat\main.cpp:4474: > IsFormal=TRUE IsMoobe=FALSE.
2551630 (4328) - winsat\main.cpp:4585: Watch dog system enabled
2551630 (4328) - winsat\main.cpp:4600: Main watch dog timer set to 600.0 seconds
2551630 (4328) - winsat\main.cpp:3115: A failure occured while trying to read partial assessments from the datastore. Running full assessment
2551630 (4328) - winsat\main.cpp:2490: > DWM Running.
2551801 (4328) - winsat\main.cpp:2497: > turning off DWM.
2551801 (4328) - winsat\main.cpp:2470: > EMD service will be restored on exit.
2552082 (4328) - winsat\syspowertools.cpp:0983: > Read the active power scheme as '381b4222-f694-41f0-9685-ff5bb260df2e'
2552082 (4328) - winsat\main.cpp:2793: > power policy saved.
2552254 (4328) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c'
2552254 (4328) - winsat\main.cpp:2814: > power policy set to maximum.
2553096 (4328) - winsat\logging.cpp:1763: ERROR: pahse enter/leave imballance
2553096 (4328) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
2553096 (4328) - winsat\main.cpp:1775: > Run Assessment features
2553174 (4328) - winsat\main.cpp:1775: > Run Assessment dwm -aname DWM -time 10 -fbc 10 -disp off -normalw 12 -width 1280 -height 1024 -winwidth C(1144) -winheight C(915) -rendertotex 6 -rtdelta 3 -nolock
2565218 (4328) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 47694200
2565218 (4328) - winsat\main.cpp:2037: > DWM Assessment results processing SUCCESS
2565218 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2571395 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2577744 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
2584172 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
2590661 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Batch -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(10) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2596855 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Alpha -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 300 -batchcnt C(75) -objs C(26) -rendertotex 6 -rtdelta 3 -texpobj C(1)
2603032 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname Tex -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -texshader -totaltex 10 -texpobj C(4) -rendertotex 6 -rtdelta 3
2609537 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname ALU -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 500 -batchcnt C(125) -objs C(20) -noalpha -alushader -totaltex 10 -texpobj C(1) -rendertotex 6 -rtdelta 3
2615918 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomF4 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 150;200;241 -batchcnt C(50);C(200);C(300) -objs C(12);C(26);C(45) -noalpha -geomf4shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
2624654 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname GeomV8 -time 7 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75;100;120 -batchcnt C(25);C(100);C(150) -objs C(8);C(17);C(29) -noalpha -geomv8shader -texpobj C(0) -rendertotex 6 -rtdelta 3 -tierframes 60 -tiertime 1
2632875 (4328) - winsat\main.cpp:1775: > Run Assessment d3d -dx10 -aname CBuffer -time 5 -fbc 10 -disp off -animate 10 -width 1280 -height 1024 -totalobj 75 -batchcnt C(25) -objs C(8) -rendertotex 6 -rtdelta 3 -texpobj C(1) -cbuffershader -cbufa 2 -cbuff 5 -cbufp 6
2638881 (4328) - winsat\main.cpp:1775: > Run Assessment mfmedia -input C:\Windows\Performance\WinSAT\winsat.wmv -nopmp
2640613 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_MPEG2_HD_15mbps.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2647352 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_VC1_15mbps.wmv -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2653733 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480i_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2660519 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480p_5sec_6mbps_new.mpg -dshow -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2667055 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_1080_5sec_10mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 135 -expfrmmax 150 -overrideframetype prog
2673591 (4328) - winsat\main.cpp:1775: > Run Assessment mediaex -input C:\Windows\Performance\WinSAT\Clip_480_5sec_6mbps_h264.mp4 -video offscreen -audio mute -width 100%m -height 100%m -constrain -savereg -autoprofname -expfrmmin 270 -expfrmmax 300 -overrideframetype int2fps
2679972 (4328) - winsat\main.cpp:1775: > Run Assessment media -input C:\Windows\Performance\WinSAT\winsatencode.wmv -encode C:\Windows\Performance\WinSAT\winsat.prx
2683341 (4328) - winsat\main.cpp:1775: > Run Assessment moobego
2683341 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption -up
2686399 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression -up
2696524 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2 -up
2699581 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression2 -up
2709628 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption
2719783 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression
2730001 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -encryption2
2740204 (4328) - winsat\main.cpp:1775: > Run Assessment cpu -compression2
2750453 (4328) - winsat\main.cpp:1775: > Run Assessment mem
2755679 (4328) - winsat\main.cpp:1775: > Run Assessment disk -seq -read -n 0
2764462 (4328) - winsat\main.cpp:1775: > Run Assessment disk -ran -read -n 0
2776770 (4328) - winsat\main.cpp:1775: > Run Assessment disk -scen 2009 -drive C:
2847361 (4328) - winsat\processresults.cpp:4018: > Wrote video memory bandwidth to the registry 47694200
2847361 (4328) - winsat\processresults.cpp:0962: > Wrote cpu expression compression score to the registry 151
2847377 (4328) - winsat\processresults.cpp:1004: Total physical mem available to the OS : 3,99 Go (4 290 240 512 bytes)
2847377 (4328) - winsat\processresults.cpp:1253: Skipping StdDefPlayback limit check.
2847377 (4328) - winsat\processresults.cpp:1265: Skipping StdDefPlayback limit check.
2847377 (4328) - winsat\processresults.cpp:1480: > Wrote disk score to the registry 590
2847377 (4328) - winsat\processresults.cpp:1498: > Wrote random read disk score to the registry 1536
2847392 (4328) - winsat\main.cpp:0948: > IsOfficial=TRUE IsFormal=TRUE IsMoobe=FALSE RanOverTs=FALSE RanOnbatteries=FALSE
2847408 (4328) - winsat\main.cpp:4736: ERROR: Unable to save validated results.
2847439 (4328) - winsat\syspowertools.cpp:1015: > Set the active power scheme to 381b4222-f694-41f0-9685-ff5bb260df2e'
2847439 (4328) - winsat\main.cpp:2855: > Power state restored.
2847439 (4328) - winsat\main.cpp:2870: > Successfully reenabled EMD.
2847704 (4328) - winsat\main.cpp:2896: > Composition restarted
2847720 (4328) - winsat\watchdog.cpp:0311: Watch dog system shutdown
2847720 (4328) - winsat\main.cpp:4909: > exit value = 1.
