Ecran Bleu BSOD besoin d'interprétation
Posté : mer. 25 oct. 2017 10:32
Bonjour, je subis des échecs répétés sur une configuration qui m'a été prêtée, avec à chaque fois un final en écran bleu; je n'ai réussi à sauvegarder que des messages sur le Notepad, la connexion ne me permettant guère d'aller plus loin et surtout plus vite !
Voici donc quelques exemples:
L'incident "KERNEL_DATA_INPAGE_ERROR" (avec code: 0x7A )semble le plus fréquent...
On Mon 23/10/2017 21:23:39 your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102417-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x110B5C)
Bugcheck code: 0x7A (0xFFFFFFFFE19318C8, 0xFFFFFFFFC0000185, 0xFFFFFFFFBF910B5C, 0x2663D860)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\WINDOWS\system32\win32k.sys
description: Multi-User Win32 Driver
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Tue 24/10/2017 18:58:04 your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini102417-02.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x22F8F)
Bugcheck code: 0xF4 (0x3, 0xFFFFFFFF8A20C5F0, 0xFFFFFFFF8A20C764, 0xFFFFFFFF805D22DA)
Error: CRITICAL_OBJECT_TERMINATION
file path: C:\WINDOWS\system32\ntoskrnl.exe
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Sur l'un des premiers incidents j'avais les codes suivant:
STOP : 0x0000007A (0xE19318C8, 0xC0000185, 0xBF910B5C, 0x2663D860)
Win32k.sys – address BF910B5C base at BF800000, DateStamp 51315668
J'ai fait pas mal de tentatives: nouveau disque dur système (celui d'origine était endommagé avec beaucoup de secteurs touchés) / changement des cables SATA, retrait ou remplacement de différents éléments: carte TV, carte graphique, fonctionnement avec chacune des 4 barrettes mémoires...
La carte mère est une 965P-S3, Gigabyte Technology Co., Ltd
A l'origine avec l'ancien disque dur j'avais des freezes récurrents sans plantage franc. J'ai installé le nouveau disque et ça n'a jamais fonctionné correctement. Au début j'ai incriminé le réseau de la carte mère qui ne fonctionnait pas. Effectivement en passant par une carte ethernet et en invalidant la carte réseau de la carte mère j'ai eu quelques minutes de connexion internet et depuis les diodes vertes sont là, mais ... le micro plante en écran bleu.
Remarque finale: avec le vieux disque dur tout est OK côté matériel, avec le nouveau j'ai quelques éléments qui apparaissent non installés notamment audio dans le panneau de configuration / matériel. Il doit s'agir des éléments de la carte mère que je n'ai pas connectés pour des causes diverses (pas de hauts parleurs à ce stade des tests, carte graphique ASUS ajoutée)
Qu'en pensez-vous ?
Merci de votre aide en... Partage
Qu'en pensez-vous ?
