Kernel_Data_Inpage_error
Posté : ven. 27 janv. 2017 15:11
J'ai suivi votre procédure avec l'outil whocrashed pour résoudre des problème de " kernel_data_Inpage_error"
je copie le rapport analysis et conclusion ici. je vous remercie de vos réponse sur la procédure pour résoudre ce problème
Cordialement,
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
On Thu 26/01/2017 15:04:15 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012617-27046-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14E3A0)
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE000BD20F290, 0x2A2D000)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Thu 26/01/2017 11:20:58 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012617-38890-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x6F000, 0xFFFFE001EE1EF480)
On Mon 23/01/2017 17:06:46 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012317-54718-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x2000, 0xFFFFE00185C4C720)
On Thu 19/01/2017 10:13:15 your computer crashed
crash dump file: C:\WINDOWS\Minidump\011917-56500-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x2000, 0xFFFFE0009AAB0430)
Conclusion
13 crash dumps have been found and analyzed. Only 5 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Cordialement,
Crash Dump Analysis
Conclusion
