J'ai suivi votre procédure avec l'outil whocrashed pour résoudre des problème de " kernel_data_Inpage_error"
je copie le rapport analysis et conclusion ici. je vous remercie de vos réponse sur la procédure pour résoudre ce problème
Cordialement,
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
On Thu 26/01/2017 15:04:15 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012617-27046-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14E3A0)
Bugcheck code: 0x7A (0x4, 0x0, 0xFFFFE000BD20F290, 0x2A2D000)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Thu 26/01/2017 11:20:58 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012617-38890-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x6F000, 0xFFFFE001EE1EF480)
On Mon 23/01/2017 17:06:46 your computer crashed
crash dump file: C:\WINDOWS\Minidump\012317-54718-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x2000, 0xFFFFE00185C4C720)
On Thu 19/01/2017 10:13:15 your computer crashed
crash dump file: C:\WINDOWS\Minidump\011917-56500-01.dmp
Bugcheck code: 0x7A (0x5, 0x0, 0x2000, 0xFFFFE0009AAB0430)
Conclusion
13 crash dumps have been found and analyzed. Only 5 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Kernel_Data_Inpage_error
essaietoujours
Re: Kernel_Data_Inpage_error
J'ai trouvé un topic intéressant concernant cette erreur :
J'ajoute ceci :
Vérifie que tu n'as pas de triangle jaune dans le gestionnaire de périphériques, signe d'une anomalie pour un pilote.
Contrôle que tous tes pilotes sont à jour, au besoin grâce à une détection ici
http://www.touslesdrivers.com/
Tiens-nous au courant.
Source : http://www.commentcamarche.net/forum/af ... page-errorLes causes:
Cette erreur, générant un arrêt immédiat avec écran bleu, est provoquée par un conflit entre la mémoire paginée (il ne s'agit donc pas de la RAM) et des données (data) demandées ou fournies par le noyau (Kernel).
La cause la plus fréquente est l'existence de fichiers corrompus dans la partition système, cette corruption pouvant être due à un virus ou à un conflit généré par l'installation d'un nouveau logiciel, driver, etc.. Bref, le message d'erreur et les problèmes sont alors apparus peu de temps (quelques minutes ou heures) après l'installation sur l'ordinateur d'un élément nouveau. Néanmoins, plus rarement, peuvent être également en cause, une erreur d'un contrôleur de disque (pilote), ou l'existence de blocs défectueux sur le disque dur recevant l'OS (operating system).
La réparation:
Je prendrais le cas le plus grave, c'est-à-dire où s'inscrit le message "operating system not found" avec écran noir. Dans ce cas là, il n'y a plus rien à attendre de Windows qui n'est même plus retrouvé. Il faut, pour pouvoir agir, utiliser des outils de réparation qu'on peut obtenir d'une des manières suivantes:
- soit, en redémarrant l'ordinateur et en tapotant la touche de "réparation" qui varie avec la marque de la machine (F8 sur mon Vaio), choisir ensuite "Réparer l'ordinateur" ce qui affiche les actions proposées,
- soit, en redémarrant l'ordi après avoir mis dans le lecteur le DVD original de Win7 (choisir "Réparer l'ordinateur), ou bien le DVD dit "de réparation" qui a du être gravé en suite de la premiére installation.
Il faut ensuite procéder, dans l'ordre, aux trois actions suivantes:
- >sfc /scannow /r qui scanne les fichiers système, détecte les fichiers corrompus et les répare,
- >bootsect /NT60 c:\ qui répare le Master Boot Record (MBR) du disque dur héber geant l'OS. (Savoir que si le clavier numérique ne fonctionne pas, il suffit d'utiliser les touches numériques du haut du clavier lettres)
- >chkdsk c: /f /r qui vérifie la partition du disque dur sur laquelle se trouve l'OS (windows), en général C: (Nota, cette vérification ne pourra s'exécuter qu'après un redémarrage de la machine).
J'ajoute ceci :
