Cette erreur est fréquemment reportée sur la toile.
Une solution simple, évitant de te plonger dans le BIOS, est indiquée dans le tutoriel "How to change Model Type and Serial Number of Thinkpad".
Je le cite :
"Steps.
1.Download ThinkPad Hardware Maintenance Diskette (HMD). I have 1.83 attached here. You can certainly find other versions on the Internet somewhere.
2.DO NOT use windows 10!! I've only tried windows 10 & 7, both 64 bit. Windows 7 worked with all my flash drives. But the application will not find your USB stick on windows 10.
3.Unzip the TP HMD. Use "usbfmtpw.exe" to make a bootable HMD USB. If it says "Error: Drive not found to format", then it's very likely it can't run on your OS (Windows 10 for instance). Otherwise, you will see a format window. Make sure it's your flash drive. Don't worry about the size. You can always format it in windows, and the flash drive will turn back to normal.
4.Boot your Thinkpad with the USB stick you just made. You might need to hit "F12" to open the boot options to choose it. You will see a blue screen with some descriptions of the tool.
5.Choose option 1, "1. set S/N.. " or something like that. I can't remember now, but it's pretty straightforward once you are at this step.
6.Follow the instructions. It's pretty easy. You will need to input the Model Type and SN together, with "1S" at the beginning. Say, model type 1234CTO, SN 56789AB, you will need to input "1S1234CTO56789AB". It may vary depending on your machine.
7.Then simply reboot."
Traduction résumée :
1. Télécharge ThinkPad Hardware Maintenance Diskette (HMD). Le fichier à télécharger est situé au bas du tutoriel, voir le lien ci-dessous.
2. Utilise W7, ne pas utiliser Windows 10 - Le rédacteur du topic a utilisé W7 64 bits.
3. Dézippe le TP HMD. Exécute "usbfmtpw.exe" pour créer une clé USB bootable.
4. Boote ton pc sur cette clé bootable. Tu peux avoir à taper la touche "F12", pour ouvrir les options du boot et choisir de booter sur la clé. TU verras un écran bleu avec les descriptions de l'outil.
5. Choisis l'option 1, " "1. set S/N.. " ou quelque chose comme cela. C'est simple quand tu es à cette étape.
6. Suis les instructions. C'est très facile. Tu dois renseigner le type du modèle et le numéro de série ensemble, avec "1S" au début. Par exemple pour un type de modèle 1234CTO et un numéro de série 56789AB, tu devras saisir "1S1234CTO56789AB". Cela dépend de ta machine.
7.Ensuite redémarre ton pc.
Source :
https://sites.google.com/site/shaneucf/ ... f-thinkpad
