WHEA_UNCORRECTABLE_ERROR
pingo-power
Salut, aurevoir, siltepali, merci
J'ai ce message souvent quand je joue, et de tmeps en temps avec flash, ou sinon inopinement comme ca, que fiare ?
highlander
pingo-power
Re: WHEA_UNCORRECTABLE_ERROR
Ce site, en voulant soit-disant aider a reparer le BSOD, fait de la pub a ses logiciels qui sont en plus des rogues et EN PLUS il n'apporte pas de vrais solutionshighlander a écrit :Essaie ça, si ce n'est pas déjà fait :
http://www.solvusoft.com/fr/errors/erre ... ble-error/
Télécharge whocrashed de resplendence, lance une analyse et regarde le rapport de texte pour trouver le coupable.
pingo-power
--------------------------------------------------------------------------------grimpeur a écrit :Bonjour,
Welcome to WhoCrashed (HOME EDITION) v 5.03
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which allows you to perform more thorough and detailed analysis. It also offers a range of additional features such as remote analysis on remote directories and remote computers on the network.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: PC-GAMING
windows version: Windows 8.1 , 6.2, build: 9200
windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., Z97-A
CPU: GenuineIntel Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz Intel586, level: 6
RAM: 8530198528 total
Crash Dump Analysis
No valid crash dumps have been found on your computer
Conclusion
Crash dumps are enabled but no valid crash dumps have been found. In case you are experiencing system crashes, it may be that crash dumps are prevented from being written out. Check out the following article for possible causes: If crash dumps are not written out.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Donc pas de BSOD en mémoire et il faudrait le code check exacte mais tu peux déjà regarder de ce côté (msdsn) -> https://www.google.fr/search?biw=1280&b ... =0CBwQBSgA pour savoir à quoi il correspond.
pingo-power
Ou je peut avoir le code exact ?
Lorsque tu joues, il faut le noter ou alors dans l'observateur d'événements windows .
pingo-power
J'ai chercher dans plusieurs tutoriel et j'ai pas compris pour l'observateur d'evenement, il y as beaucoup d'"erreur" et je sait pas presisement ou obtenir le code que tu souhaite
pingo-power
Une astuce ?grimpeur a écrit :Bonsoir,
Un moyen pour que je te transmette le journal d'evenement ?
