ECRAN BLEU (BSOD)
Jugi
ECRAN BLEU (BSOD)
Message par Jugi »
Bonjour, j'ai mis à télécharger pendant une nuit un film de 9go nommé The Expendables 3 venant du site cpasbien.com et un jeu "Ghost Recon Phantom", le matin j'éteins le pc, je le rallume peut de temps après, il se connecte à ma session, et là écran bleu il reboot sans arrêt, j'ai fait l'analyse avec WhoCrashed donc je vous montre le problème, j'aimerais avoir des réponses assez rapidement svp merci.
Erreur de l'écran bleu : IRQL_NOT_LESS_OR_EQUAL.
Voici le copié collé de l'analyse WhoCrashed :
System Information (local)
computer name: HOME-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: FJ377AA-ABF a6538.fr, HP-Pavilion, MSI, Boston
CPU: GenuineIntel Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 4293058560 total
Crash Dump Analysis
On Sun 30/11/2014 15:44:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\113014-27159-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF800036037F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800036037F7)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
This was probably caused by the following module: rt64win7.sys (Rt64win7+0x10BB8)
file path: C:\Windows\system32\drivers\rt64win7.sys
product: Realtek 8101E/8168/8169 PCI/PCIe Adapters
company: Realtek Corporation
description: Realtek 8101E/8168/8169 NDIS 6.20 64-bit Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rt64win7.sys (Realtek 8101E/8168/8169 NDIS 6.20 64-bit Driver , Realtek Corporation ).
Google query: Realtek Corporation IRQL_NOT_LESS_OR_EQUAL
On Sun 30/11/2014 15:40:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\113014-33041-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF800035FE7F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035FE7F7)
On Fri 28/11/2014 18:34:57 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112814-28782-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF8000301B7F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000301B7F7)
On Fri 28/11/2014 17:40:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112814-29702-01.dmp
On Thu 27/11/2014 19:35:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112714-28828-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF8000301D7F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000301D7F7)
On Thu 27/11/2014 18:19:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112714-25786-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF800035F57F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035F57F7)
On Tue 25/11/2014 17:23:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112514-26348-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF800030057F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800030057F7)
On Tue 25/11/2014 16:10:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112514-30310-01.dmp
This was probably caused by the following module: hal.dll (0xFFFFF800035F47F7)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035F47F7)
Conclusion
9 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
J'éspère que vous pourrez résoudre mon problème au plus vite, j'attends vos réponses, merci :)
Babac
Re: ECRAN BLEU (BSOD)
Message par Babac »
Allo,
Les causes d'un BSOD sont jamais faciles à cerner.Les messages générés par Who Crashed sont souvent vagues et généraux et pas toujours pertinents.
Il faut d'abord déterminer si la cause est matérielle ou logicielle.
Redémarrez en mode ''sans échec'' et si vous y arrivez sans BSOD, la cause n'est pas matérielle mais bien logicielle.
Un Blue Screen est presque toujours causé par un pilote.Il est important de tout mettre à jour. Dans votre cas, je porterais une attention particulière au pilote de Realtek.
Rendez vous sur ce site et cliquez sur ''Démarrer la détection''. Acceptez l'installation d'un active x, s'il vous est proposé.
Ensuite, cliquez sur ''Mes pilotes...''et faites l'installation de tous ceux proposés,sauf les beta.Les pilotes de vos périphériques seront alors à jour.
http://www.ma-config.com/fr
La deuxième étape consiste à mettre à jour les pilotes de vos logiciels.
Rendez vous sur ce site et installez toutes les mises à jour proposées, sauf les bétas.
http://www.commentcamarche.net/download ... updat(...)
Redémarrez l'ordi et vérifiez si vous avez toujours des Blue Screen.
Si votre problème est matériel,c'est probablement la mémoire qui serait en cause.
Faites alors un test de mémoire avec Memtest.
http://www.commentcamarche.net/faq/899- ... ec-memtest
Toutes les explications concernant son utilisation sont sur la même page.
Vous devez terminer le test sans erreur,avec au moins 4 passes,pour exonérer la mémoire de tout blâme.
Carte mère: Model Asus P9X79
