Depuis maintenant 1 mois, j'ai des écrans bleus de temps en temps, en moyenne 1 fois tous les 2 jours. J'avais installé blueviewscreen pour voir d'où cela venait, mais je n'ai pas trouvé grand chose. Entre temps, j'ai formaté et les écrans bleus persistent.
Je vous fournis le détail de whocrashed :
Crash Dump Analysis
On Sun 27/10/2013 00:30:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102713-9328-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007C76028, 0xF607A000, 0x135)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
Conclusion
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Merci d'avance pour vos réponses
Bhqk
