Bonjour voila mon ordi n arrete pas de s eteindre en m affichant a ecran bleu suivie d un pourcentage puis le redemarage voici le raport si quelqu un peut m aider se serait super merci
System Information (local)
computer name: PILAR-VAIO
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD E2-1800 APU with Radeon(tm) HD Graphics AMD586, level: 20
2 logical processors, active mask: 3
RAM: 1721098240 total
VM: 2147352576, free: 1972011008
Crash Dump Analysis
On Wed 16-10-2013 11:45:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101613-21902-01.dmp
This was probably caused by the following module: amd_xata.sys (amd_xata+0x7568)
Bugcheck code: 0x7A (0xFFFFF6FC40008750, 0xFFFFFFFFC000009D, 0x5F598860, 0xFFFFF880010EA568)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\Windows\system32\drivers\amd_xata.sys
product: Stor Filter Driver
company: Advanced Micro Devices
description: Stor Filter Driver
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: amd_xata.sys (Stor Filter Driver, Advanced Micro Devices).
Google query: Advanced Micro Devices KERNEL_DATA_INPAGE_ERROR
On Wed 16-10-2013 4:20:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101613-63710-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0x7A (0xFFFFF6FC00018540, 0xFFFFFFFFC000009D, 0x1CCA8860, 0xFFFFF800030A8C60)
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Mon 14-10-2013 10:14:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101413-37767-01.dmp
Bugcheck code: 0xF4 (0x3, 0xFFFFFA8004002B30, 0xFFFFFA8004002E10, 0xFFFFF80002F8D8B0)
Error: CRITICAL_OBJECT_TERMINATION
Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
Conclusion
4 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further
Help me ecran bleu recurant
Re: Help me ecran bleu recurant
Jette un coup d’œil sur ce : POST aide d'un helper nécessaire
- puis ici en Français pour exécuter un CHKDSK / f / r sur la partition système.
- j'irai voir en désinfection, ou si le PC est neuf demander de le changer en garantie (est-ce un HP?)
Ce qui veut dire selon traduction :
trouver votre pilote AMD
ou tous les drivers.com:
http://www.touslesdrivers.com/ à faire pour vérifier si la version actuelle est la bonne. Voir comment installer les drivers.
- tu ferais bien de te faire assister par un helpeur sur "désinfection" cité sur le forum ci-dessus, après on te dira quoi faire...
Si tout échoue, voir après si tu n'as pas besoin de "mettre à niveau sans perte de données":
- amd_xata.sys est connu comme "Storage Filter Driver" chercher sa mise à jour selon nom du modèle et la marque de votre ordinateur:4 crash dumps ont été trouvés et analysés. Un pilote tiers a été identifié pour être la cause de plantage du système sur votre ordinateur. Il est fortement recommandé que vous vérifiez les mises à jour de ces pilotes sur les sites Web des constructeurs.
Cliquez sur les liens ci-dessous pour rechercher sur Google des mises à jour de ces pilotes :
amd_xata.sys ( Stor Filter Driver , Advanced Micro Devices )
Si aucune mise à jour des pilotes n’est disponibles , faites une recherche avec Google sur le noms de ces pilotes en les croisant avec les erreurs qui ont été signalés pour ces pilotes et en incluant la marque et le nom du modèle de votre ordinateur dans la requête.
Cela donne souvent des résultats intéressants sur les discussions d’utilisateurs qui ont connu des problèmes similaires.
Notez qu'il n'est pas toujours possible d'affirmer avec certitude si un pilote signalé est réellement responsable du plantage de votre système ou que la cause est dans un autre module.
...............une recherche avec Google sur le bug doit permettre de vérifier les erreurs avec le nom du modèle et la marque de votre ordinateur, ceci peut vous aider à approfondir cette question plus avant.
