Bonjour j ai un ecran bleu de la mort et mon pc plante tout le temps apres quelque temps
J'ai un acer aspire ax3810 et windows 7 64x
voici l analyse de l'erreur avec le logiciel whocrashed et aussi un copié collé du rapport d erreur dans le journal d evenements windows
et il marque aussi quand le syteme plante un message d erreur. Erreur du type E/S 0x000000e
pourriez vous m aider a resoudre ce probleme, s il vous plaît?Je vous remercie.
Welcome to WhoCrashed (HOME EDITION) v 4.01
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. It will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
Voici le rapport du journal des evenements erreur critique
Nom du journal :System
Source : Microsoft-Windows-Kernel-Power
Date : 2/06/2013 20:17:56
ID de l’événement :41
Catégorie de la tâche :(63)
Niveau : Critique
Mots clés : (2)
Utilisateur : Système
Ordinateur : kevin-PC
Description :
Le système a redémarré sans s’arrêter correctement au préalable. Cette erreur peut survenir si le système ne répond plus, s’est bloqué ou n’est plus alimenté de façon inattendue.
XML de l’événement :
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-06-02T18:17:56.908414700Z" />
<EventRecordID>10689</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>kevin-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Ecran bleu de la mort
Re: Ecran bleu de la mort
Comment sont réglés les paramètres des options d'alimentation sur ton ordinateur
Est-ce-que les pilotes graphique sont bien à jour
