Bonsoire
eniler
Bonsoire
Message par eniler »
Bonsoire,
Je m'appelle Lauréline.
Je suis arrivé sur forum-seven. com par ce lien http://www.forum-seven.com/whocrashed-o ... -bleus-996
Je ne sais pas dans quel topic adressé mon probleme qui est le suivant:
Je cherche une solution au plantage de mon PC qui se produit depuis que je suis passé á la version ultimate 64 bit, au paravant j'avais win 7 basico ( je vis au Brésil) 32 bits.
J'ai pensé que c'est p't que le PC chauffe trop et qu'il faudrait lui mettre des ventilateurs en plus pour la ram vu que maintenant j'ai 8 giga de ram qui tourne et non 3.
j'ai telecharger le programme mentionner sur le lien et voici le rapport:
Welcome to WhoCrashed (HOME EDITION) v 3.06
This program checks for drivers which have been crashing your computer. If your computer has displayed a blue screen of death, suddenly rebooted or shut down then this program will help you find the root cause and possibly a solution.
Whenever a computer suddenly reboots without displaying any notice or blue screen of death, the first thing that is often thought about is a hardware failure. In reality, on Windows most crashes are caused by malfunctioning device drivers and kernel modules. In case of a kernel error, many computers do not show a blue screen unless they are configured for this. Instead these systems suddenly reboot without any notice.
This program will analyze your crash dumps with the single click of a button. It will tell you what drivers are likely to be responsible for crashing your computer. If will report a conclusion which offers suggestions on how to proceed in any situation while the analysis report will display internet links which will help you further troubleshoot any detected problems.
To obtain technical support visit www.resplendence.com/support
Click here to check if you have the latest version or if an update is available.
Just click the Analyze button for a comprehensible report ...
Home Edition Notice
This version of WhoCrashed is free for use at home only. If you would like to use this software at work or in a commercial environment you should get the professional edition of WhoCrashed which also allows analysis of crashdumps on remote drives and computers on the network and offers a range of additional features.
Click here for more information on the professional edition.
Click here to buy the the professional edition of WhoCrashed.
System Information (local)
computer name: LAURELINE-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 8503418880 total
VM: 2147352576, free: 1940975616
Crash Dump Analysis
On Tue 11/09/2012 18:20:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\091112-15334-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7F1C0)
Bugcheck code: 0x4E (0x99, 0x120FC2, 0x2, 0x1)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Fri 07/09/2012 11:03:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090712-13416-01.dmp
Bugcheck code: 0x1A (0x8887, 0xFFFFFA8003E2F470, 0xFFFFFA8003211440, 0x500)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
On Fri 07/09/2012 03:06:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090712-13821-01.dmp
Bugcheck code: 0x4E (0x99, 0xAFC2, 0x2, 0x1)
On Tue 04/09/2012 14:23:21 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090412-16442-01.dmp
On Mon 03/09/2012 01:00:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090212-15428-01.dmp
On Fri 31/08/2012 12:34:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083112-15662-01.dmp
On Tue 28/08/2012 01:59:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082812-14679-01.dmp
On Mon 27/08/2012 13:43:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082712-17877-01.dmp
On Sun 26/08/2012 21:36:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082612-14398-01.dmp
Bugcheck code: 0x4E (0x99, 0xFC2, 0x2, 0x1)
On Tue 07/08/2012 03:25:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080712-14710-01.dmp
Bugcheck code: 0x4E (0x99, 0x20517, 0x2, 0x1DF07)
On Tue 07/08/2012 00:19:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080612-12324-01.dmp
Bugcheck code: 0x4E (0x99, 0x8AFC2, 0x2, 0x1)
On Sat 04/08/2012 22:24:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080412-22167-01.dmp
On Fri 03/08/2012 15:19:13 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080312-15319-01.dmp
Bugcheck code: 0x4E (0x99, 0x80FC2, 0x2, 0x1)
On Thu 02/08/2012 13:29:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080212-15256-01.dmp
Bugcheck code: 0x4E (0x99, 0x2A508, 0x2, 0x2A503)
Conclusion
17 crash dumps have been found and analyzed. Only 15 are included in this report. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Merci de votre attention
Grapheos
Re: Bonsoire
Message par Grapheos »
Bonjour Laureline,
Je ne sais pas si ton souci à été résolu ou pas. Si ça n'est pas le cas, voici les étapes à suivre :
Peux tu me détailler la configuration précise de ton PC ?
1) Nombre de barrettes mémoires avec le format et la taille
2) Type de processeur
3) Quel type de OS windows 7 tu utilise (si officiel ou non)
4) Si tu entend ton PC ventiler comme une voiture de course ou bien très silencieux avant que sa crash
5) fait il une série de "bip" avant de crasher
6) As tu un écran bleu qui apparait avec une tonne de lignes incompréhensible
7) modèle du PC et de la carte mère (si tu à la référence bien entendu :) )
Bref, cites-moi tout ce qui arrive au moment du crash stp, et si ton PC à été configurer et monter "vendu" ou bien si c'est un PC que tu t'es faite toi même, ça permettra d'isoler le problème car windows est très vaste dans le domaine du plantage :lol:
Merci à toi, kiss ;)
