Voila mon problème : Depuis quelques temps mon ordinateur m'affiche des écrans bleus avec des rapports d'erreurs concernant plusieurs fichiers et plusieurs types d'erreurs. En recherchant, malheuresement sans trouver, les solutions à ces problèmes, j'ai trouvé un logiciel qui m'indique les fichiers en cause et l'erreur provoqué : "WhoCrashed" je poste donc le rapport de WhoCrashed ici :
System Information (local)
computer name: LVFFY-VAIO
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: AuthenticAMD AMD Athlon(tm) II P320 Dual-Core Processor AMD586, level: 16
2 logical processors, active mask: 3
RAM: 4021182464 total
VM: 2147352576, free: 2008055808
Crash Dump Analysis
On Sun 22/05/2011 16:03:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052211-23524-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70700)
Bugcheck code: 0x101 (0x61, 0x0, 0xFFFFF880009E8180, 0x1)
Error: CLOCK_WATCHDOG_TIMEOUT
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
This was probably caused by the following module: hal.dll (hal!HalReturnToFirmware+0xB2D)
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sun 22/05/2011 15:43:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052211-23228-01.dmp
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFF88000C007CB)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
On Sun 22/05/2011 15:22:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052211-20467-01.dmp
Bugcheck code: 0x1A (0x41287, 0x0, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Fri 20/05/2011 20:38:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\052011-18236-01.dmp
Bugcheck code: 0xA (0x100, 0x2, 0x0, 0xFFFFF80003CEAFBF)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Wed 11/05/2011 13:48:27 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051111-34242-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70740)
Bugcheck code: 0x7F (0x8, 0x80050033, 0x6F8, 0xFFFFF80003CCF829)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
On Tue 10/05/2011 18:00:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051011-39140-01.dmp
Bugcheck code: 0x50 (0xFFFFF8001347D198, 0x0, 0xFFFFF800035ED716, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
On Tue 10/05/2011 00:11:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\051011-19609-01.dmp
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFFA800499EF50, 0x1, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
N'étant pas très fort en informatique, j'espère que vous pourrez m'aider à résoudre mon problème ... Merci d'avance
Ecran bleu, rapport WhoCrashed
Re: Ecran bleu, rapport WhoCrashed
Bonsoir LvffY
juste une petite question avant que quelqu'un vienne te dépanner .
est-ce-que ton ordi était équipé de windows 7 ou est-ce-que tu as fait une mise à niveau de vista à 7
sinon la cause Hardware Abstraction Layer DLL qui concerne ( hal.dll ) est ce fichier qui doit être endommagé .
peut-être faire une réparation au demarrage avec le dvd de win 7 si il est en ta possession .
Windows 7 était déjà installé quand j'ai acheté l'ordinateur, et je n'ai pas le cd d'installation donc j'ai télécharger le fichier hal.dll sur fichier-dll.fr mais je n'arrive pas à remplacer l'ancien parce 'qu'il me faut une autorisation" ... Une solution ? :/
Après d'autres recherches sur le net, j'ai trouvé un logiciel "registrybooster" qui était censé réglé mes problèmes de registre, mais 10 après avoir recherché et corrigé tous les problèmes trouvés, mon ordi a crashé ... Une problème technique peut-etre ?
Bonjour LvffY
avec ce registrybooster tu ne fera qu'agraver le contenu de ton pc ce logiciel ne te sera pas conseillé sur le forum car il fait plus de dégats que de
réparations
(la preuve ci-dessus dans ton post)
commence par ceci :
vérification des fichiers système :
Menu Démarrer / zone de recherche en bas, taper cmd => en haut de la fenêtre démarrer, clic droit sur cmd.exe "Exécuter en tant qu'administrateur".
Dans la fenêtre qui vient de s'ouvrir, taper sfc /scannow (si tu as démarré en mode sans échec avec invite de commande, tu lances de suite sfc)
Laisser faire l'analyse (environ une 10zaine de minutes) puis noter le message.
Si celui-ci indique aucune violation d'intégrité du système, alors c'est OK.
Par contre, si des erreurs sont détectées, copier et coller la commande ci-dessous (tjs en tant qu'administrateur) :
findstr /C:"[SR] Cannot repair" %windir%\logs\cbs\cbs.log >sfcdetails.txt
puis rechercher sfcdetails.txt dans C:\Windows\System32 et en poster le contenu
LvffY a écrit :Après d'autres recherches sur le net, j'ai trouvé un logiciel "registrybooster" qui était censé réglé mes problèmes de registre, mais 10 après avoir recherché et corrigé tous les problèmes trouvés, mon ordi a crashé ... Une problème technique peut-etre ?
réparations
commence par ceci :
