ENCORE CET ECRAN BLEU et WHO CRASHED
Posté : dim. 27 mars 2011 11:27
Pouvez-vous m'aider ?
Crash Dump Analysis
On Sun 27/03/2011 09:12:20 GMT your computer crashed
This was probably caused by the following module: Unknown (0x7725E2A0)
Bugcheck code: 0xB8 (0xFFFFFA8003749040, 0xFFFFF8800316DF80, 0x0, 0x0)
Error: ATTEMPTED_SWITCH_FROM_DPC
Bug check description: This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown ATTEMPTED_SWITCH_FROM_DPC
On Fri 25/03/2011 02:01:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032511-33072-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x82EDA)
Bugcheck code: 0x100000B8 (0xFFFFFA80046F1690, 0xFFFFF8800336DF80, 0x0, 0x0)
Error: CUSTOM_ERROR
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
unknown
Crash Dump Analysis
Error: CUSTOM_ERROR
Conclusion
unknown
Télécharge
Clique sur
pour lancer l'installation.
pour lancer le programme.
pour vérifier si une mise à jour du logiciel est disponible.
pour lancer le scan.
quand le scan sera terminé pour mettre le rapport dans le presse-papier.
Le rapport sera enregistré sur le bureau.
Exécuter un examen rapide, clique sur le bouton
