ENCORE CET ECRAN BLEU et WHO CRASHED
Pouvez-vous m'aider ?
Crash Dump Analysis
On Sun 27/03/2011 09:12:20 GMT your computer crashed
This was probably caused by the following module: Unknown (0x7725E2A0)
Bugcheck code: 0xB8 (0xFFFFFA8003749040, 0xFFFFF8800316DF80, 0x0, 0x0)
Error: ATTEMPTED_SWITCH_FROM_DPC
Bug check description: This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown ATTEMPTED_SWITCH_FROM_DPC
On Fri 25/03/2011 02:01:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032511-33072-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x82EDA)
Bugcheck code: 0x100000B8 (0xFFFFFA80046F1690, 0xFFFFF8800336DF80, 0x0, 0x0)
Error: CUSTOM_ERROR
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
unknown
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Crash Dump Analysis
Error: CUSTOM_ERROR
Conclusion
unknown
Re: ENCORE CET ECRAN BLEU et WHO CRASHED
Télécharge ZHPDiag de Nicolas Coolman sur ton bureau.
Clique sur
pour lancer l'installation.
Clique sur
pour lancer le programme.
Sous Vista et Sept , il faut cliquer droit dessus et dans le menu contextuel sur Exécuter en tant qu'administrateur.
Clique sur
pour vérifier si une mise à jour du logiciel est disponible.
Clique sur
pour lancer le scan.
Clique sur
quand le scan sera terminé pour mettre le rapport dans le presse-papier.
Héberge ce dernier sur Cjoint.
Poste le lien obtenu.
Referme l'outil.
Le rapport sera enregistré sur le bureau.
Clique sur
Clique sur
pour lancer le programme. Sous Vista et Sept , il faut cliquer droit dessus et dans le menu contextuel sur Exécuter en tant qu'administrateur.
Clique sur
Clique sur
Clique sur
Héberge ce dernier sur Cjoint.Poste le lien obtenu.
Referme l'outil.
Belle panoplie.
1-
Télécharge AD-Remover sur ton bureau.
Double clique sur AD-R.exe
Clique sur le bouton Nettoyer.
Poste le rapport qui va s'ouvrir en fin de scan.
Le rapport est sauvegardé sous C:\Ad-report-SCAN[1].txt
Puis ferme le programme par Quitter.
2-
Télécharge et installe Malwarebytes Anti-Malware de RubbeR DuckY
Double-clique sur le fichier mbam-setup-1.50.exe (sous Vista et 7 autorise les modifications)
Clique sur Terminer
Coche
Exécuter un examen rapide, clique sur le bouton
A la fin du scan, sélectionne tout et clique sur Supprimer la sélection
Poste le rapport qui s'ouvre après cette suppression.
3- Fais un scan avec ton antivirus et poste le rapport avec les deux autres.
4- Fais analyser ce fichier : C:\Program Files (x86)\Artisteer 2\bin\Artisteer.exe sur VirusTotal
5- Mets à jour Java et supprimes les autres versions.
-Java Runtime Environment (JRE)6u24 :
http://java.sun.com/javase/downloads/index.jsp
Clique sur Download Java Runtime Environment (JRE) 6 update24
Dans la page suivante, choisis Windows dans Platform coche I agree to the Java SE Runtime Environment 6 License Agreement et Continue
Dans la nouvelle page, coche Windows Offline Installation - jre-6u24-windows-i586.exe //15.75MB.
Tu l'installeras hors connexion.
Belle panoplie.
1-
Double clique sur AD-R.exe Clique sur le bouton Nettoyer.
Poste le rapport qui va s'ouvrir en fin de scan.Le rapport est sauvegardé sous C:\Ad-report-SCAN[1].txt
2-
Double-clique sur le fichier mbam-setup-1.50.exe (sous Vista et 7 autorise les modifications)A la fin de l'installation, veille à ce que les options suivantes soient cochées
- -Mettre à jour Malwarebytes' Anti-Malware
Clique sur TerminerUne fenêtre Mise à jour de Malwarebytes' Anti-Malware va s'ouvrir avec une barre de progression.
Coche
Poste le rapport qui s'ouvre après cette suppression.Redémarre le pc si cela est demandé
belle panoplie ??? c'est à dire ???
Rapport Ad Remover : http://cjoint.com/?1dBnoGVPsZh
Rapport Malwraebytes : http://cjoint.com/?1dBnzAyKpxu
je n'arrive pas à avoir virus total !
As-tu encore des problèmes ?
pour l'instant non mais cela etait déjà très aléatoire !
que voulais tu dire par belle panoplie ?
et enfin je n'arrive pas à avoir virustotal
Belle panoplie veut dire que tu avais une certaine quantité de toolbars inutiles entre autres.
Pour VirusTotal qu'est-ce que tu n'arrives pas à avoir ?
