Bluescreen
Posté : sam. 26 mars 2011 19:41
Je rencontre un soucis de bluescreen intempestif depuis maintenant quelques semaines.
J'ai donc décidé de réinstaller Windows 7 et j'ai toujours des soucis.
Sur conseil d'un ami, j'ai installé le logiciel WhoCrashed
et voici les résultats
Qui saurait m'orienter???
On Sat 26/03/2011 17:29:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032611-35973-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x437B3)
Bugcheck code: 0x1 (0xFFFFFFFF82A816DF, 0x0, 0xFFFFFFFFFFFF0000, 0x0)
Error: APC_INDEX_MISMATCH
file path: C:\Windows\system32\ntkrnlpa.exe
Bug check description: This indicates that there has been a mismatch in the APC state index.
This was probably caused by the following module: ntkrpamp.exe (nt!ZwYieldExecution+0xEDF)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntkrpamp.exe .
Google query: ntkrpamp.exe APC_INDEX_MISMATCH
On Sat 26/03/2011 16:29:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032611-27658-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x21865A)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82A6665A, 0xFFFFFFFF9868F8E8, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Sat 26/03/2011 15:43:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032611-19250-01.dmp
This was probably caused by the following module: ndis.sys (ndis+0x1E946)
Bugcheck code: 0xD1 (0x95B04, 0x2, 0x1, 0xFFFFFFFF8AE37946)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\ndis.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote NDIS 6.20
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
