voici le rapport & la conclusion.
Crash Dump Analysis
On Mon 21/11/2011 10:48:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112111-57236-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC40)
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000301833E)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This was probably caused by the following module: rtlh64.sys (Rtlh64+0xFA9E)
file path: C:\Windows\system32\drivers\rtlh64.sys
product: Realtek 8101E/8168/8169 PCI/PCIe Adapters
company: Realtek Corporation
description: Realtek 8101E/8168/8169 NDIS6 64-bit Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtlh64.sys (Realtek 8101E/8168/8169 NDIS6 64-bit Driver , Realtek Corporation ).
Google query: rtlh64.sys Realtek Corporation IRQL_NOT_LESS_OR_EQUAL
On Sat 19/11/2011 12:56:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\111911-41589-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035ED7F7)
On Sat 19/11/2011 12:36:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\111911-44850-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800036007F7)
On Fri 02/09/2011 17:14:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090211-17737-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000300233E)
On Fri 02/09/2011 17:05:18 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090211-17799-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800030137F7)
On Thu 01/09/2011 20:51:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090111-19328-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000300533E)
On Wed 31/08/2011 16:14:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083111-17518-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000301B33E)
On Wed 31/08/2011 13:12:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083111-16442-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035EE33E)
On Tue 30/08/2011 16:06:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-16785-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800030077F7)
On Tue 30/08/2011 15:08:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-16816-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800030157F7)
On Tue 30/08/2011 11:58:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-16988-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000301F7F7)
On Tue 30/08/2011 11:40:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-17144-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035F17F7)
On Tue 30/08/2011 11:28:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-16567-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF8000360233E)
On Tue 30/08/2011 10:42:25 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083011-19640-01.dmp
Bugcheck code: 0xA (0x8, 0x2, 0x0, 0xFFFFF800035FE7F7)
Conclusion
51 crash dumps have been found and analyzed. Only 15 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
Merci pour votre aide
Cordialement,
Clemoons
