ok, voici ce que le logiciel me dit :
System Information (local)
computer name: ELFENOIR-PC
windows version: Windows 7 , 6.1, build: 7600
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 3211845632 total
VM: 2147352576, free: 1971941376
Crash Dump Analysis
No valid crash dumps have been found on your computer
Conclusion
Crash dumps are enabled but no valid crash dumps have been found. It may be that there are problems which prevent crash dumps from being written out. Check out the following article for possible causes: If crash dumps are not written out.
In case your computer does experience sudden reboots it is likely these are caused by malfunctioning hardware, power failure or a thermal issue. To troubleshoot a thermal issue, check the temperature using your BIOS setup program, check for dust in CPU and motherboard fans and if your computer is portable make sure it's located on a hard surface. Otherwise it's suggested you contact the support department of the manufacturer of your system or test your system with a memory test utility for further investigation.
Check out the following articles for more information: Troubleshooting sudden resets and shut downs.
trad, please, parceque là, moi.....
