Depuis quelques jours j'ai des écrans bleus à répétition et ce à n'importe quels moments et sans que je fasse quelque chose en particulier!!
J'ai testé ma ram avec memtest, j'ai fait un checkdisk, j'ai mis mes pilotes à jour mais rien n'y fait..........
merci d'avance de votre aide
Je joins un rapport de whocrashed
Ma config: Intel(R) Core(TM)2 Duo CPU E8400
2Go RAM Corsair
CM: Gigabyte EP45-DS4
RAdeon HD5750
DD Western Digital WD6400
Windows Seven Integrale 32 bits
On Mon 07/03/2011 19:05:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030711-13322-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0x4E23)
Bugcheck code: 0xD1 (0x0, 0x2, 0x1, 0xFFFFFFFF8E77EE23)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\usbport.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote de port USB 1.1 & 2.0
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Mon 07/03/2011 18:11:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030711-13603-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x9F973)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFFFFF82CB9973, 0xFFFFFFFF8B12B934, 0xFFFFFFFF8B12B510)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\ntkrnlpa.exe
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
On Sat 05/03/2011 17:24:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-14414-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x11F1B6)
Bugcheck code: 0xC2 (0x7, 0x1097, 0x110A0706, 0xFFFFFFFF94CBCB60)
Error: BAD_POOL_CALLER
Bug check description: This indicates that the current thread is making a bad pool request.
On Sat 05/03/2011 16:42:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030511-13946-01.dmp
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFFFFF82CE4973, 0xFFFFFFFF8B127934, 0xFFFFFFFF8B127510)
On Tue 01/03/2011 17:25:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030111-13712-01.dmp
This was probably caused by the following module: win32k.sys (win32k+0x59B0)
Bugcheck code: 0xC2 (0x99, 0xFFFFFFFF8A6ACB00, 0x0, 0x0)
file path: C:\Windows\system32\win32k.sys
description: Pilote Win32 multi-utilisateurs
On Sat 26/02/2011 16:15:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022611-17550-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x231334)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82E42334, 0xFFFFFFFF8A3B6C50, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
On Sat 26/02/2011 15:25:40 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022611-14648-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x4681B)
Bugcheck code: 0xA (0x30, 0x2, 0x0, 0xFFFFFFFF82F22F69)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
On Sat 26/02/2011 14:57:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022611-14242-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82E6D334, 0xFFFFFFFF8B003C50, 0x0)
On Sun 20/02/2011 09:58:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\022011-19266-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x859EB)
Bugcheck code: 0x1A (0x41287, 0x4, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Sat 19/02/2011 14:32:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021911-35583-01.dmp
This was probably caused by the following module: tcpip.sys (tcpip+0x85323)
Bugcheck code: 0xA (0x60F209, 0x2, 0x0, 0xFFFFFFFF82CDB66A)
file path: C:\Windows\system32\drivers\tcpip.sys
description: Pilote TCP/IP
On Fri 18/02/2011 16:44:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021811-14071-01.dmp
This was probably caused by the following module: hdaudio.sys (HdAudio+0x36E33)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFFFFF9490FE33, 0xFFFFFFFF98174AFC, 0xFFFFFFFF981746E0)
file path: C:\Windows\system32\drivers\hdaudio.sys
description: High Definition Audio Function Driver
On Wed 16/02/2011 18:26:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021611-14601-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0x230EE4)
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82E3CEE4, 0xFFFFFFFF821B7C50, 0x0)
On Wed 16/02/2011 17:53:44 GMT your computer crashed
crash dump file: C:\Windows\Minidump\021611-13977-01.dmp
This was probably caused by the following module: watchdog.sys (watchdog+0x1276)
Bugcheck code: 0x113 (0x4, 0xFFFFFFFF88369398, 0x0, 0x0)
Error: VIDEO_DXGKRNL_FATAL_ERROR
file path: C:\Windows\system32\drivers\watchdog.sys
description: Watchdog Driver
Bug check description: This indicates that the dxg kernel has detected a violation.
Conclusion
On your computer a total of 37 crash dumps have been found. Only 36 could be analyzed. Only 15 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
sptd.sys
Ecran bleu .........
Re: Ecran bleu .........
Tu as bien installé un émulateur de CD comme Alcohol ou DaemonTools ?
Si oui désinstalle-le .
bonjour,
ca y est je l'ai désinstallé mais j'ai toujours des problèmes............ce que je ne comprends pas dans le rapport whocrashed c'est que l'erreur change presque à chaque fois!!!
A l'aide
A l'aide
AS-tu encore des BSoD depuis la désinstallation de ton émulateur ?
oui toujours je renvoie le rapport whocrashed avec les 2 BSOD depuis que j'ai désinstallé daemon tools.
On Wed 09/03/2011 16:43:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030911-11996-01.dmp
Bugcheck code: 0x1000008E (0xFFFFFFFFC0000005, 0xFFFFFFFF82CF2973, 0xFFFFFFFF8C8BFAE0, 0x0)
On Wed 09/03/2011 16:36:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030911-12339-01.dmp
Bugcheck code: 0x1A (0x41287, 0x40000024, 0x0, 0x0)
Conclusion
On your computer a total of 41 crash dumps have been found. Only 40 could be analyzed. Only 15 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
sptd.sys
Conclusion
sptd.sys
Télécharge DeFogger de Jpshortstuff sur le bureau.
http://www.jpshortstuff.247fixes.com/Defogger.exe
Double clic sur DeFogger
Sous Vista et Sept, clique droit e sur l'icône et sur "Exécuter en tant qu'administrateur".
Clique sur le bouton Disable pour désactiver les drivers d'émulateurs CD.
Cliquer sur Yes pour continuer.
Un message 'Finished!' apparaîtra, clique sur OK.
Il sera demander de redémarrer la machine, OK accepte.
bonjour,
j'ai fait ta manip pour l'instant ça tourne pas de BSOD....................
je reposte si jamais
Merci bcp
Merci bcp
Il faudrait supprimer ce fichier :
C:/Windows/system32/sptd.sys
(je mets des slashes car je suis sous Mac et je n'ai pas encore trouvé les antislashes)
