Je dispose d'un Packard Bell EasyNote NJ65 acheté au le 20/08/2010
Depuis 1 mois environ, lors de l'utilisation de l'ordinateur, j'ai constaté de nombreux "Freeze" de Seven ( 64bits) ou de crash type " bluescreen"
Après mettre informé sur le forum je vous ai fait une analyse WhoCrashed en espérant que vous pourriez m'aider à regler ses bugs
En attentes de votre aide !
Cordialement.
Nordkrieg
PS: ttes les mises à jours sont faites, et je n'ai rien toucher au niveau matériel !
Analysis
On Tue 12/10/2010 12:29:52 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007300038, 0xF2000040, 0x800)
Error: WHEA_UNCORRECTABLE_ERROR
Dump file: C:\Windows\Minidump\101210-18408-01.dmp
On Tue 12/10/2010 12:19:01 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007314038, 0xF2000040, 0x800)
Dump file: C:\Windows\Minidump\101210-20264-01.dmp
On Mon 11/10/2010 15:09:45 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA800732E038, 0x0, 0x0)
Dump file: C:\Windows\Minidump\101110-17955-01.dmp
On Wed 06/10/2010 18:41:37 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA80073148F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\100610-18392-01.dmp
On Wed 06/10/2010 15:33:22 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8007358038, 0x0, 0x0)
Dump file: C:\Windows\Minidump\100610-17877-01.dmp
On Tue 05/10/2010 17:33:41 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA800733B538, 0x0, 0x0)
Dump file: C:\Windows\Minidump\100510-16770-01.dmp
On Fri 01/10/2010 09:53:55 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005CCE8F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\100110-19016-01.dmp
On Sun 26/09/2010 20:21:41 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C75038, 0x0, 0x0)
Dump file: C:\Windows\Minidump\092610-17737-01.dmp
On Sat 25/09/2010 09:53:43 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005DBD6F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\092510-20654-01.dmp
On Thu 16/09/2010 21:47:00 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005CBB4B8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\091610-18673-01.dmp
On Thu 16/09/2010 09:41:10 your computer crashed
This was likely caused by the following module: unknown_image
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C9B038, 0xF2000040, 0x800)
Dump file: C:\Windows\Minidump\091610-18657-01.dmp
On Wed 15/09/2010 10:54:50 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C6A8F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\091510-18720-01.dmp
On Wed 15/09/2010 09:33:27 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C89038, 0xB2000040, 0x800)
Dump file: C:\Windows\Minidump\091510-18392-01.dmp
On Sun 05/09/2010 17:29:52 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C7C8F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\090510-19032-01.dmp
On Mon 30/08/2010 16:09:45 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005C798F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\083010-17971-01.dmp
On Sun 29/08/2010 11:23:25 your computer crashed
Bugcheck code: 0x124 (0x0, 0xFFFFFA8005CA98F8, 0x0, 0x0)
Dump file: C:\Windows\Minidump\082910-17862-01.dmp
Conclusion
16 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
