Mes icônes s'ouvrent avec Lecteur Windows Média [Résolu]
Re: Mes icônes s'ouvrent avec Lecteur Windows Média [Résolu]
bonjour
voici le rapport
les cles run par labougie
Run by lydia at [13/06/2010 18:22]
Architecture [x86]
#-----------Systeme de lydia
Windows 7 Home Premium
#-----------Resultat de la recherche
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
BackupManagerTray REG_SZ "C:\Program Files (x86)\NewTech Infosystems\Acer Backup Manager\BackupManagerTray.exe" -h -k
Hotkey Utility REG_SZ C:\Program Files (x86)\Acer\Hotkey Utility\HotkeyUtility.exe
EgisTecLiveUpdate REG_SZ "C:\Program Files (x86)\EgisTec Egis Software Update\EgisUpdate.exe"
Adobe Reader Speed Launcher REG_SZ "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe"
Adobe ARM REG_SZ "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
SunJavaUpdateSched REG_SZ "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
HP Software Update REG_SZ C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
OPTENET_GUI REG_SZ C:\PROGRA~2\SFR\CONTRO~1\bin\OPTGui.exe
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\OptionalComponents
[HKEY_LOCAL_MACHINE\Software\Microsoft\Shared Tools\MSConfig\startupreg]
#----- Etat de certains Services
#--- Centre de Securite
SERVICE_NAME: wscsvc
TYPE : 20 WIN32_SHARE_PROCESS
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Gestionnaire des Comptes de Securite
SERVICE_NAME: SamSs
STATE : 4 RUNNING
(NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Netlogon
SERVICE_NAME: Netlogon
STATE : 1 STOPPED
WIN32_EXIT_CODE : 1077 (0x435)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Pare Feu Windows
SERVICE_NAME: MpsSvc
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Service du Profil Utilisateur
SERVICE_NAME: ProfSvc
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Windows Defender
SERVICE_NAME: WinDefend
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Windows Update
SERVICE_NAME: wuauserv
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_PRESHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Eol
#-----------Fin de la recherche
a+
voici le rapport
Architecture [x86]
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SamSs
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Netlogon
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 1 STOPPED
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Windows Update
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
#--- Eol
a+
Je te remercie crisreu pour ta participation.
J'ai transmis le rapport.
Peux-tu me confirmer que tu es bien en 64 bits ?
Qu'en est-il de ton MSE ?
L'icône refuse toujours de s'afficher directement dans la zone de notification ?
Tant que tu vois dans msconfig -> onglet Démarrage, que la case Microsoft Security Essentials est bien cochée, tu ne risques rien.
MSE est bien actif au démarrage.
bonjour
je ne me sert plus du 64 bit , du coup je pense que je suis sur un 34 bit.
sinon ok, pour mse , qui n'ai toujours pas en bas.
a+
a+
Je parlais de ton système, mais tu as tout de même répondu à ma question, car si tu as IE8 64 bits, ton Windows 7 est bien en 64 bits
Je pense que tu faisais allusion à IE8 en 64 bits et tu utilises bien sûr IE8 en 32 bits, ce qui est impératif, puisqu'il n'existe pas de version 64 bits de Flash Player.crisreu a écrit :je ne me sert plus du 64 bit , du coup je pense que je suis sur un 34 bit.
bonjour
ok, je vous remerci pour tout
a bientot
a bientot
N'hésite pas si tu as d'autres interrogations
bojour
merci beaucoup, je vous recontacterai pour l'ancienne session.
A bientot
Bonjour crisreu,
Excuse-moi, je n'avais pas vu que tu étais revenue.
Ce sujet est dèjà très long.
Il serait judicieux d'ouvrir 1 autre sujet pour ton problème d'images.
Je vais essayer de diviser et transférer ce qui concerne le problème d'images sur un autre sujet.
Pour ton ancienne session, si je me souviens bien, tu avais récupéré toutes tes données personnelles et tu les as transférées sur ta nouvelle session.
Si c'est bien le cas, tu te connectes sur ta nouvelle session.
Dans Panneau de configuration\Comptes et protection des utilisateurs\Comptes d’utilisateurs, tu cliques sur Gérer un autre compte
Puis tu cliques sur le compte à supprimer.
Une nouvelle fenêtre Modifier le compte de ........ s'ouvre
Tu cliques sur Supprimer le compte et tu valides ne pas conserver les fichiers et tu suis l'assistant.
Redémarre le PC si c'est demandé.
Ne te trompe pas, supprime bien l'ancien compte
Edit : le sujet pour les images est ici -> topic6357.html
bonjour
je vous remerci, ancien compte bien supprimé.
A bientot
A bientot
