Ecran bleu sous Windows 7 [Résolu]
Juba78
Message par Juba78 »
Bonjour a tous,
J'ai un soucis avec Windows 7, après avoir migré de vista vers seven j'ai eu des écrans bleu tout les 2 minutes, problème que j'ai résolu en mettant a jour la carte graphique, depuis seven est stable, sauf que depuis 3 semaine j'ai des écrans bleu a la fréquence d'une fois tout les 2,3 jours.
Voici un diag :
On Fri 22/01/2010 10:58:15 your computer crashed
This was likely caused by the following module: ntkrnlpa.exe
Bugcheck code: 0xC5 (0x4, 0x2, 0x0, 0x82F3D04D)
Error: DRIVER_CORRUPTED_EXPOOL
Dump file: C:\Windows\Minidump\012210-18080-01.dmp
file path: C:\Windows\system32\ntkrnlpa.exe
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit may be another driver on your system which cannot be identified at this time.
On Sat 16/01/2010 13:56:58 your computer crashed
This was likely caused by the following module: hardware
Bugcheck code: 0x124 (0x0, 0x86707024, 0xB2074000, 0x175)
Error: WHEA_UNCORRECTABLE_ERROR
Dump file: C:\Windows\Minidump\011610-19188-01.dmp
On Thu 07/01/2010 16:04:58 your computer crashed
This was likely caused by the following module: dxgmms1.sys
Bugcheck code: 0x10E (0x1F, 0xAB519918, 0x0, 0x1D6C)
Error: VIDEO_MEMORY_MANAGEMENT_INTERNAL
Dump file: C:\Windows\Minidump\010710-24538-01.dmp
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
On Tue 05/01/2010 17:30:15 your computer crashed
Bugcheck code: 0x19 (0x20, 0x86865780, 0x868657D8, 0x80BD70E)
Error: BAD_POOL_HEADER
Dump file: C:\Windows\Minidump\010510-23010-01.dmp
On Tue 05/01/2010 16:49:33 your computer crashed
This was likely caused by the following module: aswmonflt.sys
Bugcheck code: 0xD1 (0x3, 0x2, 0x0, 0x8B1D3366)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\010510-22791-01.dmp
Ma config : seven edition integral, 3G de ram, double core 3Ghz, Hp ELITE M9065
Merci de votre aide
Juba78
Re: Ecran bleu
Nouveau crash :
On Tue 26/01/2010 23:57:42 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x82E84778, 0x8EBE2C80, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
Dump file: C:\Windows\Minidump\012710-22854-01.dmp
Jango78
Re: Ecran bleu
Message par Jango78 »
Ce sont toujours à priori des problèmes matériels.
Il n'y a qu'une seule mise à jour proposée sur le site HP pour le m9065:
http://h10025.www1.hp.com/ewfrf/wc/soft ... ct=3602287
Juba78
Re: Ecran bleu
Merci je vais allé voir sur le site
Juba78
Re: Ecran bleu
RE- bonjour,
Malgré une mise a jours de tout mes drivers, les ecrans bleu continuent.. merci de votre aide
On Mon 08/03/2010 10:23:27 your computer crashed
Bugcheck code: 0x1A (0x41287, 0x779CDCD0, 0x0, 0x0)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\030810-27924-01.dmp
On Sun 07/03/2010 21:18:18 your computer crashed
Bugcheck code: 0x1 (0x8306B7E1, 0x0, 0xFFFF, 0x0)
Error: APC_INDEX_MISMATCH
Dump file: C:\Windows\Minidump\030710-23680-01.dmp
merci de votre aide
lool
Re: Ecran bleu
Message par lool »
As-tu lancé l'outil de diagnostic mémoire ?
Tu démarres, tu tapotes F8 et tu choisis "Diagnostic de la mémoire".
Le test peut durer un certain temps.
Sinon, as-tu également vérifié le bon enfichage des cartes PCI et des barrettes mémoires ?
Autre piste, la vérification des fichiers système :
Menu Démarrer / zone de recherche en bas, taper cmd => en haut de la fenêtre démarrer, clic droit sur cmd.exe "Exécuter en tant qu'administrateur".
Dans la fenêtre qui vient de s'ouvrir, taper sfc /scannow (si tu as démarré en mode sans échec avec invite de commande, tu lances de suite sfc)
Laisser faire l'analyse (environ une 10zaine de minutes) puis noter le message.
Si celui-ci indique aucune violation d'intégrité du système, alors c'est OK.
Par contre, si des erreurs sont détectées, copier et coller la commande ci-dessous (tjs en tant qu'administrateur) :
findstr /C:"[SR] Cannot repair" %windir%\logs\cbs\cbs.log >sfcdetails.txt
puis rechercher sfcdetails.txt dans C:\Windows\System32 et en poster le contenu.
Bye,
lool
marko
Re: Ecran bleu
Message par marko »
J'ai passé 2 semaines à chercher pourquoi mon W7 x64 plantait brusquement avec des bsod différents tous les jours.
Après avoir suivi pleins de pistes, sans succès, je commençais à me résoudre à reformatter et réinstaller mon pc, quand hier après un énième redémarrage, Avast 5 ne se lançait pas.
J'avais un beau message comme quoi mon pc n'était pas protégé.
J'ai essayé de relancer à la main les différents modules, sans succès.
J'ai alors pensé que j'avais un virus qu'Avast n'avait pas détecté.
J'ai téléchargé AVG (entre autres) et j'ai désinstallé Avast.
J'ai lancé un scan complet du pc qui n'a rien trouvé.
Mais depuis deux jour, plus de de bsod ....
Alors Avast 5 incompatible avec W7 ?
En tout cas depuis deux jours, mon pc tourne sans problème ...
14niepce
Re: Ecran bleu
Message par 14niepce »
salut marko et merci pour l'info,
j'ai aussi pensé que le probleme venait de mon antivirus et désinstallé bitdefender.
Mais dans mon cas pas fausse route.
Pour l'instant mon PC est stable depuis la suppression definitive d'un pilote.
A suivre
Intel Q8200 (2,33 GHz), 4Go Ram, SSD 64Go, Nvidia 9400GT 512Mo
Windows 7 (32bits) et Ubuntu 9.10
Juba78
Re: Ecran bleu
Merci a tous pour vos réponses :super:
Mais mon problème perdure toujours :hein: malgré formatage, installation d'un nouveau antivirus (Trend micro), installation d'une nouvelle version de w7 (32bit)
Voici les derniers évènement :
On Wed 07/04/2010 12:32:50 your computer crashed
Bugcheck code: 0x1A (0x403, 0xC0014CD0, 0xB6B78867, 0xC0014CC0)
Dump file: C:\Windows\Minidump\040710-20857-01.dmp
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Tue 06/04/2010 20:10:50 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x82842C81, 0xA3222C90, 0x0)
Dump file: C:\Windows\Minidump\040610-23587-01.dmp
On Tue 06/04/2010 14:24:03 your computer crashed
Bugcheck code: 0x50 (0xFFFFFFCF, 0x1, 0x8228182D, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Dump file: C:\Windows\Minidump\040610-29671-01.dmp
Je me pose des questions a revenir sur vista vu que même le constructeur HP n'apporte pas de reponse concrete malgré que le pc soit de 2009 :hein:
Juba78
Re: Ecran bleu
Re- bonjour a tous,
J'ai vu sur plusieurs forum qu'une mise a jour d'une Bios ( quoique dangereuse) pouvez réglé se type de problème lorsqu'aucune solution n'a fonctionné
Qu'en pensez vous? Merci pour vos réponses d'avance. :coucou:
Sur le site d'Hp, il n'y aucun mise a jours de Bios disponible pour mon bios ( révision 5.19 09/20/2007) :hein:
