Ecran bleu
Publié : lun. 28 août 2017 14:08
Ci-joint vous trouverez le rapport d'erreurs de WhoCrashed. Les écrans bleus ne surviennent uniquement lorsque je joue.
Crash Dump Analysis
On Sun 27/08/2017 23:47:27 your computer crashed
crash dump file: C:\Windows\Minidump\082817-19047-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x6F950)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 02/07/2017 14:38:30 your computer crashed
crash dump file: C:\Windows\Minidump\070217-19749-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70E40)
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF8000307B90C)
Error: IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This was probably caused by the following module: scmndisp.sys (scmndisp+0x16D1)
file path: C:\Windows\system32\drivers\scmndisp.sys
product: ® Neutral Wireless Solution
company: Windows (R) Codename Longhorn DDK provider
description: NDIS User mode I/O Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: scmndisp.sys (NDIS User mode I/O Driver, Windows (R) Codename Longhorn DDK provider).
Google query: Windows (R) Codename Longhorn DDK provider IRQL_NOT_LESS_OR_EQUAL
On Thu 29/06/2017 17:58:18 your computer crashed
crash dump file: C:\Windows\Minidump\062917-19749-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF800030C790C)
On Mon 19/06/2017 20:58:27 your computer crashed
crash dump file: C:\Windows\Minidump\061917-17409-01.dmp
Bugcheck code: 0xA (0x0, 0x2, 0x1, 0xFFFFF8000309590C)
Conclusion
11 crash dumps have been found and analyzed. Only 5 are included in this report. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Crash Dump Analysis
Conclusion
