Ecran bleu intempestif avec PC de Bureau
j'ai windows 7 pro x64 bits
et j'ai des ecrans bleus qui arrivent de temps en temps et le pc redémarre
j'ai essayé de trouver des solutions
j'ai installé whocrased et j'ai eu cela :
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: GenuineIntel Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 2145869824 total
VM: 2147352576, free: 1986592768
Crash Dump Analysis
On Tue 01/03/2011 17:36:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030111-24679-01.dmp
This was probably caused by the following module: athrx.sys (athrx+0x78BCF)
Bugcheck code: 0x100000B8 (0xFFFFFA8006314040, 0xFFFFFA8001874A80, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\athrx.sys
product: Driver for Atheros CB42/CB43/MB42/MB43 Network Adapter
company: Atheros Communications, Inc.
description: Atheros Extensible Wireless LAN device driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: athrx.sys (Atheros Extensible Wireless LAN device driver, Atheros Communications, Inc.).
Google query: athrx.sys Atheros Communications, Inc. CUSTOM_ERROR
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0xB8 (0xFFFFFA8006314040, 0xFFFFFA8001874A80, 0x0, 0x0)
Error: ATTEMPTED_SWITCH_FROM_DPC
Bug check description: This indicates that an illegal operation was attempted by a delayed procedure call (DPC) routine.
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
pourriez-vous m'aider
Crash Dump Analysis
Error: CUSTOM_ERROR
Conclusion
Modifié en dernier par chantal11 le jeu. 3 mars 2011 11:29, modifié 2 fois.
Raison : Titre en majuscules
Re: ecran bleu intempestif
bonsoir
a priori tu as un problème avec le pilote de ta carte réseau wifi
vérifie dans le gestionnaire de périphériques si tu n'as pas un triangle jaune au niveau de ta carte réseau wifi
ensuite fais une détection en ligne avec ma config voir s'il te propose un pilote
http://www.ma-config.com/
a plus
a plus
bonjour et merci d'essayer de m'apporterune solution
j'ai ceci :
configuration 0
Ce service est proposé en partenariat avec TousLesDrivers.com . Il vous permet de télécharger les derniers drivers correspondant à votre système d'exploitation et aux matériels détectés. Pour toutes remarques et rapports d'anomalies, postez sur le forum Service Mes Drivers
Système d'exploitation:
Tous les OS Windows NT Windows 95 Windows 98 Windows 98SE Windows ME Windows 2000 Windows 2003-64 Windows 2003 Windows XP Tablet PC Edition Windows XP Media Center Edition Windows XP Embedded Windows XP-64 Windows XP Windows Vista Windows Vista-64 Windows 2008 Windows 2008-64 Windows 7 Windows 7-64 Windows 2008 R2-64 Options:
Afficher seulement les drivers plus récents que celui installé
Afficher seulement les drivers certifiés WHQL
Afficher les drivers beta
WD SES Device USB Device (Aucun driver installé)Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
Microsoft | Classe: processor | Version : 6.1.7600.16385 | Date: 21/06/2006Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
Microsoft | Classe: processor | Version : 6.1.7600.16385 | Date: 21/06/2006RV516 XT Radeon X1600 Series (Primary)
Fabricant : ATI Technologies Inc | Classe: display | Version : 8.56.1.16 | Date: 25/04/2009 Ati Radeon 9x00/Xx00/X1x00/X2x00/Xpress version 10.2Fabricant : ATI Technologies Inc.
Version : 8.593.100.0000
Nom du fichier inf : ch_95951.inf
Date du fichier inf : 10/02/2010
Date de publication (mise en ligne) : 07/04/2010 TéléchargerRV516 XT Radeon X1600 Series (Secondary)
Fabricant : ATI Technologies Inc | Classe: display | Version : 8.56.1.16 | Date: 25/04/2009Realtek High Definition Audio
Realtek Semiconductor Corp. | Classe: media | Version : 6.0.1.6299 | Date: 25/01/2011SAA7131/SAA7133/SAA7135 Video Broadcast Decoder
Fabricant : Philips Semiconductors | Classe: media | Version : 6.0.1.3 | Date: 08/05/2009AR5413 802.11abg NIC
Fabricant : Atheros Communications Inc. | Classe: net | Version : 9.2.0.113 | Date: 13/11/2010N10/ICH 7 Family LAN Controller
Fabricant : Intel Corporation | Classe: net | Version : 8.0.47.1 | Date: 17/11/2007 Intel PRO/100/1000/10GbE version 16.0 WHQLFabricant : Intel
Version : 8.0.47.0
Nom du fichier inf : e100b325.inf
Date du fichier inf : 06/12/2007
Date de publication (mise en ligne) : 30/01/2011 Télécharger82801G (ICH7 Family) IDE Controller
Fabricant : Intel Corporation | Classe: hdc | Version : 9.1.1.1016 | Date: 05/08/200982801GR/GH (ICH7 Family) SATA RAID Controller
Fabricant : Intel Corporation | Classe: scsiadapter | Version : 10.1.2.1004 | Date: 12/01/2011Generic USB CF Reader USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006Generic USB MS Reader USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006Generic USB SD Reader USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006Generic USB SM Reader USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006ST332082 0AS USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006WD Ext HDD 1021 USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006WD My Book 1110 USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006WD My Book USB Device
Microsoft | Classe: diskdrive | Version : 6.1.7600.16385 | Date: 21/06/2006FW322/323
Fabricant : Agere Systems | Classe: 1394 | Version : 6.1.7601.17514 | Date: 21/06/2006LITE-ON DVDRW LH-20A1S
Microsoft | Classe: cdrom | Version : 6.1.7601.17514 | Date: 21/06/2006TSSTcorp CDDVDW SH-S203P
Microsoft | Classe: cdrom | Version : 6.1.7601.17514 | Date: 21/06/2006Souris compatible PS/2
Microsoft | Classe: mouse | Version : 6.1.7600.16385 | Date: 21/06/2006Périphérique USB composite
Fabricant : Optical mouse | Classe: mouse | Version : 6.1.7600.16385 | Date: 21/06/2006Périphérique USB composite
Fabricant : Optical mouse | Classe: keyboard | Version : 6.1.7601.17514 | Date: 21/06/2006Moniteur Plug-and-Play générique
Microsoft | Classe: monitor | Version : 6.1.7600.16385 | Date: 21/06/2006Pont Intel(R) 82801 PCI - 244E
Microsoft | Classe: system | Version : 6.1.7601.17514 | Date: 21/06/200682945G/GZ/P/PL Memory Controller Hub
Fabricant : Intel Corporation | Classe: system | Version : 6.1.7601.17514 | Date: 21/06/200682945G/GZ/P/PL PCI Express Root Port
Fabricant : Intel Corporation | Classe: system | Version : 6.1.7601.17514 | Date: 21/06/200682801GH (ICH7DH) LPC Interface Bridge
Fabricant : Intel Corporation | Classe: system | Version : 9.1.1.1016 | Date: 05/08/2009N10/ICH 7 Family High Definition Audio Controller
Fabricant : Intel Corporation | Classe: system | Version : 6.1.7601.17514 | Date: 19/11/2010N10/ICH 7 Family SMBus Controller
Fabricant : Intel Corporation | Classe: system | Version : 9.1.1.1016 | Date: 05/08/2009Flash Card Reader/Writer (Périphérique de stockage de masse USB)
Fabricant : Alcor Micro Corp. | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006Hi-Speed USB-IDE Bridge Controller (Périphérique de stockage de masse USB)
Fabricant : Hewlett-Packard | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006N10/ICH 7 Family USB UHCI Controller #1
Fabricant : Intel Corporation | Classe: usb | Version : 9.1.1.1016 | Date: 05/08/2009N10/ICH 7 Family USB UHCI Controller #2
Fabricant : Intel Corporation | Classe: usb | Version : 9.1.1.1016 | Date: 05/08/2009N10/ICH 7 Family USB UHCI Controller #3
Fabricant : Intel Corporation | Classe: usb | Version : 9.1.1.1016 | Date: 05/08/2009N10/ICH 7 Family USB UHCI Controller #4
Fabricant : Intel Corporation | Classe: usb | Version : 9.1.1.1016 | Date: 05/08/2009N10/ICH 7 Family USB2 EHCI Controller
Fabricant : Intel Corporation | Classe: usb | Version : 9.1.1.1016 | Date: 05/08/2009HighSpeed Hub (Generic USB Hub)
Fabricant : NEC Corp. | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006Périphérique USB composite
Fabricant : Optical mouse | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006eHome Infrared Transceiver (Récepteur infrarouge eHome (USBCIR))
Fabricant : TopSeed Technology Corp. | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006Périphérique de stockage de masse USB
Fabricant : Western Digital Technologies, Inc. | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006Périphérique USB composite
Fabricant : Western Digital Technologies, Inc. | Classe: usb | Version : 6.1.7601.17514 | Date: 21/06/2006Périphérique de stockage de masse USB
configuration 0
ce probleme d'ecran bleu avec message je l'ai également sur 2 pc portable :un en 64 bits et l'autre en 32 bits
j'ai un probleme lorsde mise a jour :
http://img834.imageshack.us/i/66858032.png/
© 2004 -
j'ai ceci :
configuration 0
Version : 8.0.47.0
configuration 0
© 2004 -
Re: ECRAN BLEU INTEMPESTIF AVEC PC DE BUREAU
bonsoir
le problème vient de se reproduire :
Crash Dump Analysis
On Wed 02/03/2011 21:13:04 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-32463-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x82EDA)
Bugcheck code: 0x100000B8 (0xFFFFFA8004124680, 0xFFFFFA8006DC8640, 0x0, 0x0)
Error: CUSTOM_ERROR
Bugcheck code: 0xB8 (0xFFFFFA8004124680, 0xFFFFFA8006DC8640, 0x0, 0x0)
On Wed 02/03/2011 11:23:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-45879-01.dmp
Bugcheck code: 0x100000B8 (0xFFFFFA8005FBF5E0, 0xFFFFFA8006681060, 0x0, 0x0)
Error: CUSTOM_ERROR
On Wed 02/03/2011 10:52:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-27799-01.dmp
This was probably caused by the following module: usbehci.sys (usbehci+0x2DDB)
Bugcheck code: 0x100000B8 (0xFFFFFA80018E2040, 0xFFFFF80002C1BCC0, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\usbehci.sys
description: EHCI eUSB Miniport Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Wed 02/03/2011 06:32:11 GMT your computer crashed
crash dump file: C:\Windows\Minidump\030211-28376-01.dmp
This was probably caused by the following module: iastor.sys (iaStor+0x29B07)
Bugcheck code: 0x100000B8 (0xFFFFFA8004153040, 0xFFFFFA8002258060, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\iastor.sys
product: Intel Rapid Storage Technology driver
company: Intel Corporation
description: Intel Rapid Storage Technology driver - x64
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: iastor.sys (Intel Rapid Storage Technology driver - x64, Intel Corporation).
Google query: iastor.sys Intel Corporation CUSTOM_ERROR
Error: CUSTOM_ERROR
Conclusion
6 crash dumps have been found and analyzed. 2 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
merci de m'aider encore ...
Crash Dump Analysis
Error: CUSTOM_ERROR
Error: CUSTOM_ERROR
Error: CUSTOM_ERROR
Error: CUSTOM_ERROR
Error: CUSTOM_ERROR
Conclusion
bonsoir
sur ton dernier rapport whocrashed tu as toujours des problèmes de pilotes
toujours problème de pilote pour carte reseau wifi ==>athrx.sys (Atheros Extensible Wireless LAN device driver, Atheros Communications, Inc.)
et problème pilote intel ==> iastor.sys (Intel Rapid Storage Technology driver - x64, Intel Corporation)
pour ce dernier as tu bien installé la version 64 bits ??
sinon quel est la marque et la ref de ton pc ??
on va aller voir sur le site constructeur quels sont les pilotes pour ce pc
a plus
a plus
mon pc est un HP m 7790 fr au départ il était sous vista premium 32 bits
et depuis un moment j'ai installé windows 7 pro X64
Si je comprends bien tu as 2145869824 octets de ram (RAM: 2145869824 total ) ,ce qui fait 1.9 Go
Pour du 64 bit il vaut mieux 4 GO,ça marche avec moins,mais ça peut occasionner des soucis comme le tien.
Si j'ai mal compris,tu oublies tout ce que je viens d'écrire.
mais il fonctionnait très bien jusque là .... il y a 1mois qu'il me cause ce problème
pourriez- vous continuer à m'aider
