Tout d'abord Merci de ta réponse.
j'ai fait la première étape je poste ce rapport je dois rebooté et je fais la deuxième étape
Voici le rapport
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Version de la base de données: 4936
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
24/10/2010 18:23:19
mbam-log-2010-10-24 (18-23-19).txt
Type d'examen: Examen rapide
Elément(s) analysé(s): 141424
Temps écoulé: 2 minute(s), 3 seconde(s)
Processus mémoire infecté(s): 3
Module(s) mémoire infecté(s): 5
Clé(s) du Registre infectée(s): 15
Valeur(s) du Registre infectée(s): 4
Elément(s) de données du Registre infecté(s): 0
Dossier(s) infecté(s): 4
Fichier(s) infecté(s): 51
C:\Users\Propriétaire\AppData\Roaming\EoRezo\SoftwareUpdate\SoftwareUpdateHP.exe (Rogue.Eorezo) -> Unloaded process successfully.
C:\Program Files (x86)\EoRezo\eorezo.exe (Rogue.Eorezo) -> Unloaded process successfully.
C:\Program Files (x86)\EoRezo\EoEngine.exe (Rogue.Eorezo) -> Unloaded process successfully.
C:\Program Files (x86)\EoRezo\EoAdv\EoAdv.dll (Rogue.Eorezo) -> Delete on reboot.
C:\Program Files (x86)\EoRezo\EoMultiLanguage.dll (Rogue.Eorezo) -> Delete on reboot.
C:\Program Files (x86)\EoRezo\EoRezoComm.dll (Rogue.Eorezo) -> Delete on reboot.
C:\Program Files (x86)\EoRezo\EoRezoTools_30.dll (Rogue.Eorezo) -> Delete on reboot.
C:\Program Files (x86)\EoRezo\FreeImage.dll (Rogue.Eorezo) -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{549b5ca7-4a86-11d7-a4df-000874180bb3} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{18af7201-4f14-4bcf-93fe-45617cf259ff} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{df76e9b7-35ec-46fc-af56-5b79ded9d64f} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c10dc1f4-ccdf-4224-a24d-b23afc3573c8} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{c10dc1f4-ccdf-4224-a24d-b23afc3573c8} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c10dc1f4-ccdf-4224-a24d-b23afc3573c8} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{c10dc1f4-ccdf-4224-a24d-b23afc3573c8} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{b6acb3f1-6a83-432c-b854-3e1056f87f4e} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{819db72d-1c28-4387-9778-e2ff3dc86f74} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c7b76b90-3455-4ae6-a752-eac4d19689e5} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{c7b76b90-3455-4ae6-a752-eac4d19689e5} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{c7b76b90-3455-4ae6-a752-eac4d19689e5} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{c7b76b90-3455-4ae6-a752-eac4d19689e5} (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\EoRezo (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\EoRezo (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce\softwarehelper (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\eorezo (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\eoengine (Rogue.Eorezo) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\cleansweep.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\cleansweep.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Users\Propriétaire\AppData\Roaming\EoRezo\SoftwareUpdate\SoftwareUpdateHP.exe (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\eorezo.exe (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoEngine.exe (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\EoAdv.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\confmedia.cyp (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\eoEngine.url (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoMultiLanguage.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoBHO.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoComm.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_17.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_19.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_20.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_21.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_22.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoImg_23.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_16.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_17.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_18.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_20.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_21.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_26.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_27.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_28.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_29.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoRezoTools_30.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\FreeImage.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\Host.cyp (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\MngInstaller.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\unins000.dat (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\unins000.exe (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\unins001.dat (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\unins001.exe (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\user.cyp (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\atl90.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\EoRezoBHO.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\mfc90.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\Microsoft.VC90.ATL.manifest (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\Microsoft.VC90.CRT.manifest (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\Microsoft.VC90.MFC.manifest (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\EoAdv\msvcr90.dll (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eoclock.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eoengine.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eonet.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eorezotools.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eosudoku.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\ihm_eoweather.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\lang_en.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\lang_es.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\lang_fr.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\Program Files (x86)\EoRezo\lang\lang_it.xml (Rogue.Eorezo) -> Quarantined and deleted successfully.
C:\cleansweep.exe\config.bin (Trojan.Agent) -> Quarantined and deleted successfully.
