Bluescreen [Windows 7 64bits]
Posté : dim. 17 oct. 2010 15:03
par Bananelol
depuis quelques temps, j'ai des bluescreens qui deviennent insupportable maintenant et je n'arrive pas à trouver la cause de ceux-ci..
J'ai téléchargé Whocrashed et ça me donne un rapport d'erreur énorme (28 crash)
Je vous fait un copier/coller de mes crashs (Attention c'est chargé !)
On Sat 16/10/2010 21:43:30 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800028F3867)
Error: UNEXPECTED_KERNEL_MODE_TRAP
Dump file: C:\Windows\Minidump\101610-17830-01.dmp
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Sat 16/10/2010 15:01:31 your computer crashed
This was likely caused by the following module: usbport.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88002E2D0D3)
Dump file: C:\Windows\Minidump\101610-17706-01.dmp
file path: C:\Windows\system32\drivers\usbport.sys
product: Système d’exploitation Microsoft® Windows®
description: Pilote de port USB 1.1 & 2.0
On Sat 16/10/2010 11:59:16 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8000288A803)
Dump file: C:\Windows\Minidump\101610-17035-01.dmp
On Fri 15/10/2010 13:14:32 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88004396152)
Dump file: C:\Windows\Minidump\101510-17144-01.dmp
On Fri 15/10/2010 11:04:18 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88004118152)
Dump file: C:\Windows\Minidump\101510-17628-01.dmp
On Fri 15/10/2010 11:01:38 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8800408B0D3)
Dump file: C:\Windows\Minidump\101510-17128-01.dmp
On Fri 15/10/2010 10:15:24 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800028EE28C)
Dump file: C:\Windows\Minidump\101510-16738-01.dmp
On Thu 14/10/2010 18:48:24 your computer crashed
Bugcheck code: 0x1A (0x41284, 0x32A6A001, 0x22F51, 0xFFFFF70001080000)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\101410-17612-01.dmp
On Thu 14/10/2010 17:29:25 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88006BBB0D3)
Dump file: C:\Windows\Minidump\101410-16941-01.dmp
On Wed 13/10/2010 21:46:55 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8800423E152)
Dump file: C:\Windows\Minidump\101310-16036-01.dmp
On Wed 13/10/2010 20:58:38 your computer crashed
This was likely caused by the following module: dxgmms1.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88004173F31)
Dump file: C:\Windows\Minidump\101310-16832-01.dmp
file path: C:\Windows\system32\drivers\dxgmms1.sys
description: DirectX Graphics MMS
On Wed 13/10/2010 19:16:46 your computer crashed
This was likely caused by the following module: nvlddmkm.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8801015AB8E)
Dump file: C:\Windows\Minidump\101310-16270-01.dmp
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 258.96
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 258.96
On Wed 13/10/2010 15:28:30 your computer crashed
This was likely caused by the following module: win32k.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF960001E65A1)
Dump file: C:\Windows\Minidump\101310-17004-01.dmp
file path: C:\Windows\system32\win32k.sys
description: Pilote Win32 multi-utilisateurs
On Wed 13/10/2010 22:35:18 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF96000165B76)
Dump file: C:\Windows\Minidump\101310-18844-01.dmp
On Tue 12/10/2010 20:04:12 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF880040ACAB7)
Dump file: C:\Windows\Minidump\101210-18969-01.dmp
On Sun 10/10/2010 15:53:06 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF960002CC3D6)
Dump file: C:\Windows\Minidump\101010-17721-01.dmp
On Sun 10/10/2010 11:04:55 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF80002DF2695)
Dump file: C:\Windows\Minidump\101010-16707-01.dmp
On Sat 09/10/2010 17:07:03 your computer crashed
This was likely caused by the following module: usbehci.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8800400AA7A)
Dump file: C:\Windows\Minidump\100910-16660-02.dmp
file path: C:\Windows\system32\drivers\usbehci.sys
description: EHCI eUSB Miniport Driver
On Sat 09/10/2010 16:25:39 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF88010032837)
Dump file: C:\Windows\Minidump\100910-16645-01.dmp
On Sat 09/10/2010 14:36:32 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800028C72D4)
Dump file: C:\Windows\Minidump\100910-16801-01.dmp
On Sat 09/10/2010 13:59:49 your computer crashed
This was likely caused by the following module: dxgkrnl.sys
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8800414836D)
Dump file: C:\Windows\Minidump\100910-16723-01.dmp
file path: C:\Windows\system32\drivers\dxgkrnl.sys
description: DirectX Graphics Kernel
On Fri 08/10/2010 21:21:28 your computer crashed
Bugcheck code: 0xA (0x2, 0xD, 0x0, 0xFFFFF8000281339A)
Error: IRQL_NOT_LESS_OR_EQUAL
Dump file: C:\Windows\Minidump\100810-17378-01.dmp
On Tue 05/10/2010 22:23:00 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF8800402D152)
Dump file: C:\Windows\Minidump\100510-17877-01.dmp
On Mon 04/10/2010 20:40:04 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800028C5B87)
Dump file: C:\Windows\Minidump\100410-16957-01.dmp
On Mon 04/10/2010 14:24:11 your computer crashed
Bugcheck code: 0x1A (0x5003, 0xFFFFF781C0000000, 0x40D2, 0xFFFFF8A000108009)
Dump file: C:\Windows\Minidump\100410-20748-01.dmp
On Sun 03/10/2010 15:48:19 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800028F14E6)
Dump file: C:\Windows\Minidump\100310-24913-01.dmp
On Sun 03/10/2010 12:34:57 your computer crashed
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF880042840D3)
Dump file: C:\Windows\Minidump\100310-21871-01.dmp
Pour ce qui est de ma config :
Processeur : Intel core i5 3.33 Ghz
Mémoire : 4Go DDR3 G.skill
Carte graphique : Nvidia GeForce GTX 275
Carte mère : Asus P7P55D-E
Disque dur : 320Go Western Digital
En espérant que vous trouviez une solution a mon problème.. Merci d'avance
Re: Bluescreen [Windows 7 64bits]
Posté : dim. 17 oct. 2010 16:33
Pistes possibles :
  • Problème de pilote ou périphérique USB. Qu'as-tu de branché en USB sur ton PC ?
  • Problème du pilote de la carte graphique ou de la carte graphique elle-même
  • Problème de RAM - plus douteux.
Essaie de débrancher tes périphériques USB si tu en as
Essaie de mettre à jour les pilotes graphiques
Lance un sfc /scannow en mode administrateur : Menu démarrer -> Tous les programmes -> Accessoires -> clic droit sur Invite de Commandes -> Executer en tant qu'administrateur. Dans la fenêtre noire, taper sfc /scannow et laisse faire (ça peut direr longtemps).
Posté : dim. 17 oct. 2010 16:57
par casimir2010
bonjour , j'ai eu le même problème j'ai fait cela tout marche bien ,
bonne soiréé
Posté : dim. 17 oct. 2010 17:24
par Bananelol
Ycor a écrit :Bonjour
Pistes possibles :
Bonsoir, tout d'abord merci pour ta réponse rapide.
Comme périphérique branché en USB j'ai : Souris RAZER Deathadder, Clavier Logitech G15, Un casque Gamecom Plantronics
Posté : dim. 17 oct. 2010 17:29
Difficile de débrancher le clavier et la souris :D
Essaie le casque ! et fais quand même le reste de mes propositons.
Posté : dim. 17 oct. 2010 18:09
Voici ce que nous donne DOCmémo
Code 0x0000007f
Logiciel : Erreur STOP Windows
Intitulé : UNEXPECTED_KERNEL_MODE_TRAP
Solution
[1] Windows XP - Si le problème survient pendant que Norton Antivirus 8 ou 9 examine un fichier, il faut corriger une valeur dans la base de registres.
Pour Norton Antivirus 8, sélectionnez la clé HKEY_LOCAL_MACHINE\SOFTWARE\Symantec\Norton AntiVirus NT\Auto-Protect\InternalSettings. Créez une valeur DWORD nommée KStackMinFree et entrez la donnée hexadécimale 2200.
\r\nPour Norton Antivirus 9, sélectionnez la clé HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\LANDesk\VirusProtect6\CurrentVersion\Storages\Filesystem\RealTimeScan. Créez une valeur DWORD nommée KStackMinFree et entrez la donnée hexadécimale 2200.
[2] Windows 2000 - Windows XP - Si le fichier win32k.sys est mentionné comme source du problème, installez le dernier Servcice Pack de Windows 2000 ou le Service Pack 1 (ou 2) de Windows XP.
[3] Windows XP - Si vous installez ou mettez à jour Windows XP sur un HP Pavillon, relancez l'installation. Quand un message vous propose de co tnuer la mise à jour ou de réaliser une nouvelle installation, choisissez la mise à jour. Quand le programme d'installation vous suggère d'enfoncer la touche F6 pour installer un pilote SCSI, ne le faites pas. Enfoncez plutôt F5 et sélectionnez PC Standard.
[4] Windows XP ou Vista - Lors de l'installation, le BIOS pourrait signaler au système que l'ordinateur chauffe trop pour fonctionner. Faites une mise à jour du BIOS.
Code 0x0000001a
Intitulé : MEMORY_MANAGEMENT
Solution
Problème de gestion de mémoire ou problème matériel.
[1] Si vous venez d'installer un nouveau matériel, désinstallez-le.
[2] La mémoire vive est peut-être endommagée. Voyez si les barrettes sont bien clipsées sur la carte mère. Si c'est le cas, essayez de repérer une éventuelle barrette défectueuse. Retirez une barrette et redémarrez. Si l'erreur n'apparaît plus, remplacez la barrette extraite par une nouvelle.
Bonne recherche.
Posté : dim. 17 oct. 2010 18:31
par Bananelol
merci pour votre réponse Nardino.
J'ai fais les mises à jour de mon clavier, souris et j'ai fait le scannow qui n'a rien donner.
J'ai une petite question, j'ai une mise à jour de ma carte graphique a faire mais c'est un pilote <BETA> donc je ne sais pas si il est bien.. Dois-je la faire ?
Posté : dim. 17 oct. 2010 22:28
Il faut se contenter d'installer les versions stables estampillées WHQL pour les pilotes.
WHQL (sigle de Windows Hardware Quality Labs) est un laboratoire de Microsoft ayant la charge de certifier la qualité des pilotes pour le système d'exploitation Windows. C'est également une méthode de certification de Microsoft permettant de garantir qu'un ensemble matériel permet d'exécuter correctement Windows ou une de ses sous-parties (un gestionnaire de pilotes, par exemple).
Wikipédia.
Posté : dim. 17 oct. 2010 22:34
par Bananelol
Bonsoir, dernière nouvelle :
-Ecran bleu BCCode : 7F
- Il n'y a plus marqué sur mes bluescreens : Usbport.sys / win32k.sys
Edit :
Reboot auto à des moments :s
Posté : dim. 17 oct. 2010 22:53
Fais un test de ta mémoire vive.
Dans le panneau de configuration > Outils d'administration > Outils diagnostics de la mémoire
ou
http://www.memtest86.com/
