MBR Backup - Sauvegarde du Master Boot Record
Publié : sam. 4 sept. 2010 14:38
Un petit utilitaire présenté sur The Windows Club
MBR Backup
MBR Backup
@+What does MBR Backup do?
MBR Backup helps you create a backup of your Master Boot Record. If you ever need to restore it you know you will have a valid copy available. MBR Backup gives you two ways of backing up your MBR - to a file or by printing(!) it. Believe it or not, printing it is actually the best method to back up your MBR, for several reasons:
* With a printout you always have a physical copy of the MBR to hand
* No chance of saving the MBR to a file on the hard drive that gets corrupted
* The MBR is only 512 bytes in size. Typing it in manually will be the least of your concerns if all your data is gone
