[BSOD] Ecran Blue récurrant et irrégulier [Résolu]
UHU Stick
Message par UHU Stick »
Je viens de finalisé ma nouvelle config
Configuration N° 27744
A l'origine j'ai HD5670 qui me posais problème avec mon ancienne carte mère. J'ai donc pensé que le problème venais de là mais j'ai des aussi BSOD avec ma 4650.
voici le raport des dmp
On Wed 14/07/2010 22:02:40 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x1A (0x403, 0xFFFFF680000091E8, 0x90B00000C7F04867, 0xFFFFF680000081E8)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\071410-19515-01.dmp
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Tue 13/07/2010 11:57:06 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88003BDB018, 0xFFFFF88003BDA870, 0xFFFFF800028AD35F)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\071310-20451-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
description: Pilote du système de fichiers NT
Conclusion
2 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Il y en a que 2 car dans un dernier espoir j'ai réinstallé Win7 hier mais autrement. J'ai d'autre dmp sauvegardés, le problème n'est jamais le même et bien sur c'est souvent ntoskrnl.exe qui est mis en cause.
J'ai fait un C:\Windows\system32>sfc /scannow
Début de l'analyse du système. Cette opération peut nécessiter un certain temps.
Démarrage de la phase de vérification de l'analyse du système.
La vérification 100% est terminée.
Le programme de protection des ressources Windows n'a trouvé aucune violation d'
intégrité.
J'ai fait un memtest 10 pass et aucune erreur, j'ai même fait avec chaque barrette seule. Par contre je me demandais si une mémoire peut passer memtest haut la main et quand même planter une fois sur windows ?
Je m'explique en fait la type de ram que j'ai choisit ne figure pas sur la liste des Qualified Memory.
J'ai aussi fait un scandisck sur le disk systeme... rien de chez rien.
Je ne sais plus où chercher ... votre aide serait la bienvenue.
Modifié en dernier par UHU Stick le mer. 28 juil. 2010 09:10, modifié 1 fois.
Re: [BSOD] Ecran Blue récurrant et irrégulier
Bonjour UHU Stick
Est ce que tes drivers sont a jour ?
Ma-Config.com.
UHU Stick
J'ai effectivement 2 drivers qui n'était pas a jour.
Drivers réseaux et contrôleur SATA.
Par contre durant le manipulation mon PC n'a pas voulu démarré à plusieurs reprise et ceux pour la première fois !
Les Q_LED de la carte mère m'indiquait un problème avec le CPU :s. J'ai démonté remonté, flashé le BIOS ca redémarre ... Wait and See !!!
UHU Stick
L'attend fut de courte durée ...
On Wed 14/07/2010 18:01:22 your computer crashed
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF880072ED228, 0xFFFFF880072ECA90, 0xFFFFF80002AF063A)
Dump file: C:\Windows\Minidump\071410-19921-01.dmp
:hein: j'ai lu dans la section anti-virus que KAS 2011 faisait déraillé la machine ... je vais tenté cette piste ...
[Edit]
Pour le coup pas de plantage depuis hier soir, mais faut pas crier victoire trop vite.
UHU Stick
Anti-virus désinstallé, drivers a jour, pas de problème d'intégrité, scandisk et memtest ok ...
Pourtant
On Thu 15/07/2010 20:39:45 your computer crashed
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002DD1AE3, 0xFFFFF880066BA0C0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Dump file: C:\Windows\Minidump\071510-22729-01.dmp
Si quelqu'un a une idée, je suis preneur.
Poste le dernier fichier Minidump en pièce jointe pour analyse.
Tu le trouveras dans C:\Windows
On aura peut-être une indication supplémentaire.
UHU Stick
Voici le dernier minidump .
071510-22729-01.zip
(24.68 Kio) Téléchargé 174 fois
Une copie du texte aurait ete plus simple :
1 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
L'analyse du fichier dump met en avant le fichier MsMpEng.exe
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: MsMpEng.exe
CURRENT_IRQL: 0
Ce processus MsMpEng.exe appartient à Windows Defender.
Désactive complètement Windows Defender et teste la stabilité de ton système.
Edit : @ txuku : le texte cité ne donne aucune information sur l'origine du BSOD ;)
UHU Stick
D'accord j'essaye ca en rentrant ce soir...
