BLUESCREEN réguliers et écrans noirs Alienware M17X R4
Posté : dim. 26 nov. 2017 00:11
Bonsoir . je vous contacte pour obtenir quelques conseils quand à ce bug récurent : des bluescreens , mais qui souvent sont des écrans noirs sur mon alienware M17X R4 .
J'ai effectué le test de mes rams , aucun souci rencontré.
j'ai utilisé expertool de gainward pour underclocker ma 675M GTX ça limite mes bugs écrans noirs qui sont des bluecreens .
Voici le rapport de Whocrashed :
Crash Dump Analysis
On Sat 25/11/2017 22:42:10 your computer crashed
crash dump file: C:\Windows\Minidump\112517-48563-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x921340)
Bugcheck code: 0x116 (0xFFFFFA800D7CA4E0, 0xFFFFF8801060B340, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 344.65
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 344.65
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 344.65 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8801060B340)
On Fri 24/11/2017 01:35:02 your computer crashed
crash dump file: C:\Windows\Minidump\112417-29811-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7359A)
Bugcheck code: 0x100000B8 (0xFFFFFA800BBE7B50, 0xFFFFFA800BBECB50, 0x0, 0x0)
Error: CUSTOM_ERROR
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Conclusion
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
J'en ai déduit logiquement que c'était le pilote de ma carte graphique qui posait problème. J'ai installé less derniers drivers , 388 XX , j'ai remis ceux fournis sur mon cd d'installation alienware , le 299 XX , etc ... Rien n'y fait impossible de supprimer ce bug .
Je suis en BIOS A12 .
Si quelqu'un a une idée , une piste de recherche , merci beaucoup pour votre aide et vos conseils.
Crash Dump Analysis
Error: CUSTOM_ERROR
Conclusion
