Plantage intempestif windows 7
Pierre31
Message par Pierre31 »
J'ai régulièrement des plantages dans windows 7. Ci-dessous, vous trouverez un compte rendu réalisé par "Whocrashed".
Computer name: FIXE
Windows version: Windows 7 Service Pack 1, 6.1, build: 7601
Windows dir: C:\Windows
Hardware: MS-7616, MEDIONPC
CPU: GenuineIntel Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Intel586, level: 6
RAM: 17170550784 bytes total
Crash Dump Analysis
On Tue 1/09/2015 14:19:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090115-15506-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xADC630)
Bugcheck code: 0x116 (0xFFFFFA8010592010, 0xFFFFF8800FD16630, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 341.81
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 341.81
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 341.81 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8800FD16630)
On Tue 1/09/2015 10:13:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\090115-16816-01.dmp
Bugcheck code: 0x116 (0xFFFFFA801153D010, 0xFFFFF8800FF96630, 0xFFFFFFFFC000009A, 0x4)
On Sun 30/08/2015 17:45:33 GMT your computer crashed
crash dump file: C:\Windows\Minidump\083015-14461-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80168494E0, 0xFFFFF8800FFC1630, 0xFFFFFFFFC000009A, 0x4)
Conclusion
4 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Je présume que mon problème provient de ma carte graphique, qu'en pensez-vous ?
Merci pour votre aide.
Pierre
kykou77
Re: Plantage intempestif windows 7
Message par kykou77 »
bonjour ,
oui , c'est un problème graphique , tape sur google " nvlddmkm.sys " , il y a beaucoup de solutions différentes.
j'esperes que tu trouveras ton bonheur.
bye.
