VVindovvs 7 plante - Ecran bleu
Posté : dim. 3 mai 2015 10:20
par Louann97
J'ai eu le lien VVhoCrashed par le biais du site de VVindovvs après avoir posé la question : "VVindovvs redémarre après un arrêt non planifié"
J'ai téléchargé ce logiciel et lancé une analyse. Mais bien sûr je ne comprends rien aux "information" ni "conclusion". Il semble qu'il y ait la liste de tous mes plantages. Donc, voici le détail ci-dessous. Quelqu'un peut-il m'aider à comprendre ce qu'il en est exactement et ce que je dois faire ? Merci d'avance.
Crash Dump Analysis
On Sun 03/05/2015 06:31:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050315-25958-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800511E038, 0xB6000000, 0x10015)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x1E3)
On Sat 02/05/2015 19:18:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050215-25194-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80050DD038, 0xB6000000, 0x10015)
On Sat 02/05/2015 09:37:24 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050215-37065-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80050FA038, 0xB6000000, 0x10015)
On Sun 12/04/2015 11:23:58 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041215-39920-01.dmp
This was probably caused by the following module: ataport.sys (ataport+0x1FF3C)
Bugcheck code: 0x7A (0xFFFFF6FC40007140, 0xFFFFFFFFC0000185, 0x63A6F860, 0xFFFFF88000E28F3C)
Error: KERNEL_DATA_INPAGE_ERROR
file path: C:\Windows\system32\drivers\ataport.sys
description: ATAPI Driver Extension
Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
On Tue 31/03/2015 07:03:39 GMT your computer crashed
crash dump file: C:\Windows\Minidump\033115-25521-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800504D038, 0xB6000000, 0x10015)
On Wed 25/03/2015 18:45:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032515-28766-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA800516F038, 0xB6000000, 0x10015)
On Tue 24/03/2015 11:57:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-35474-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA80050DB038, 0xB6000000, 0x10015)
On Mon 16/03/2015 08:44:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031615-28750-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFA8004FE2038, 0xF6000000, 0x10015)
On Wed 11/03/2015 07:42:16 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031115-41714-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x74EC0)
Bugcheck code: 0x7A (0xFFFFF6FC50044EF8, 0xFFFFFFFFC0000185, 0x9886A820, 0xFFFFF8A0089DFA0C)
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Conclusion
15 crash dumps have been found and analyzed. Only 10 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
