Ecran bleu again and again :(
Bonjour, je viens vous demandez en aide pour des problèmes d'écran bleus.
Je suis sous windows 7 sur PC fixe.
J'ai déjà tester chaque barette de RAM sur chaque slot.
Voici le rapport Whocrashed.
Crash Dump Analysis
On Wed 18/06/2014 11:35:32 GMT your computer crashed
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF88004E4BA78, 0xFFFFF88004CBBE70, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
On Tue 17/06/2014 18:17:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061714-19281-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75BC0)
Bugcheck code: 0x109 (0xA3A039D896471507, 0x0, 0x7D816191E61E24C7, 0x101)
Error: CRITICAL_STRUCTURE_CORRUPTION
Bug check description: This indicates that the kernel has detected critical kernel code or data corruption.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Tue 17/06/2014 17:06:45 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061714-19609-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0x2D2F1)
Bugcheck code: 0xFE (0x6, 0xFFFFFA8005EFFD20, 0x50456368, 0x0)
Error: BUGCODE_USB_DRIVER
file path: C:\Windows\system32\drivers\usbport.sys
description: Pilote de port USB 1.1 & 2.0
Bug check description: This indicates that an error has occurred in a Universal Serial Bus (USB) driver.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 17/06/2014 17:01:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061714-19141-01.dmp
This was probably caused by the following module: wg111v3.sys (wg111v3+0x73A0C)
Bugcheck code: 0xFC (0xFFFFF88004BF9A0C, 0x80000001387E3121, 0xFFFFF8000448B350, 0x0)
Error: ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
file path: C:\Windows\system32\drivers\wg111v3.sys
product: NETGEAR WG111v3 Wireless-G USB Adapter NDIS Driver
company: NETGEAR Inc.
description: NETGEAR WG111v3 Wireless-G USB Adapter NDIS Driver
Bug check description: This indicates that an attempt was made to execute non-executable memory.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. There is a possibility this problem was caused by a virus or other malware.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: wg111v3.sys (NETGEAR WG111v3 Wireless-G USB Adapter NDIS Driver, NETGEAR Inc. ).
Google query: wg111v3.sys NETGEAR Inc. ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
Conclusion
4 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Merci d'avance !
Crash Dump Analysis
Conclusion
Merci d'avance !
Re: Ecran bleu again and again :(
Le problème n'est pas au niveau des barrettes mais de ton usb NETGEAR .
BUGCODE_USB_DRIVER Pilote de port USB 1.1 & 2.0
Il faut mettre le pilote à jour
Rien n'est sur évidemment dans ce genre de cas, des "events" il y en a beaucoup liés aux pilotes ou même à la mémoire.
N'empêche qu'il est fortement recommandé par "crash report"
voir donc sur NETGEAR exemple:
http://firmware.netgear-forum.com/index ... it=WG111v3
http://support.netgear.fr/product/WG111v3
normalement tu dois avoir un "C:\WINDOWS\system32\DRIVERS\wg111v3.sys [2007-12-28 287232] qui date donc de 2007, ce n'est qu'une indication.
En tous cas voilà la direction possible, sauf avis complémentaire, car je ne suis pas plus spécialiste que ça, il y en a d'autres, y compris pour un risque d'infection
on ne sait jamais.
de mettre à jour des pilotes NETGEAR, et ou adaptateur sans fil NDIS ETC.Click on the links below to search with Google for updates for these drivers:
Ca y est Grimpeur m'a devancé, il a raison, mais je m'étend trop
je quitte à +
je quitte à +
Merci à vous deux je vais mettre à jour le driver et vous tenir au courant.
Sinon précédemment j'ai eu 2 nouveau crash qui traitent d'un usbport et un autre bizarre voici le report.
On Wed 18/06/2014 18:25:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061814-19312-01.dmp
This was probably caused by the following module: usbport.sys (USBPORT+0x13DD4)
Bugcheck code: 0xD1 (0xBF9198BF, 0x2, 0x1, 0xFFFFF880040B8DD4)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
On Wed 18/06/2014 14:12:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061814-27580-01.dmp
Bugcheck code: 0x3B (0xC0000096, 0xFFFFF80002EC5E57, 0xFFFFF88005F1FF20, 0x0)
Il y aurait aussi un problème lié à un pilote USB:
on attend d'autres avis, car un pilotes ..en cache peut-être un autreDescription: USB 1.1 & 2.0 Port Driver
contrôle de Bug description: Ceci indique qu'un pilote en mode noyau a tenté d'accéder à la mémoire paginable à un IRQL processus qui était trop élevé.
Cela semble être un bug de pilote logiciel typique et n'est pas susceptible d'être causé par un problème matériel.
L'accident a eu lieu dans un module standard Microsoft. Configuration de votre système peut être incorrect. Peut-être ce problème est causé par un autre pilote sur votre système qui ne peut être identifié à ce moment.
J'ai mis à jour mon NETGEAR comme vous me l'avaient conseillé mais toujours des crash mais bizarrement ils ne s'affichent pas dans l'analyse de Whocrashed.
Des fois ce sont des écrans figer ou direct le redémarrage du PC.
Et pour les pilotes USB je les mis à jour où ?
Merci d'avance de vos réponses.
Sinon, faire une détection ici -> http://www.touslesdrivers.com/index.php?v_page=29 à l'aide de ce tuto -> topic14356.html (il y a peut-être quelques changements sur le site par rapport au tuto mais tu devrais t'en sortir).
Regarde sur le site du constructeur de ton pc en premier pour savoir si il y a de nouveaux pilotes.Snakiss a écrit :Des fois ce sont des écrans figer ou direct le redémarrage du PC.
Et pour les pilotes USB je les mets à jour où ?
J'ai suivie le tuto et j'ai mis à jour tous sauf l'audio.
J'ai eu un crash tous à l'heure et celui là c'est afficher sur whocrashed :
On Thu 19/06/2014 17:14:51 GMT your computer crashed
This was probably caused by the following module: Unknown ()
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF960000F9375, 0x0, 0x1BB)
Error: KMODE_EXCEPTION_NOT_HANDLED
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown KMODE_EXCEPTION_NOT_HANDLED
Un nouveau bugcheck code sauriez vous peut être de quoi il s'agit ?
Merci d'avance !
Merci d'avance !
Débranche tout ce qui est connecté au pc en Usb et redémarre pour voir.
Pour l'erreur -> Bug Check 0x1E: KMODE_EXCEPTION_NOT_HANDLED en lecture.
Tu dois avoir un pilote qui met le bazard dans ton pc ou Pilote de périphérique défectueux ou service système. De plus, un pilote de périphérique défectueux ou d'un service de système pourrait être responsable de cette erreur. Les problèmes matériels, tels que les incompatibilités du BIOS, les conflits de mémoire, et les conflits d'IRQ peuvent également générer cette erreur.
Si le problème est récent et que tu disposes d'un point de restauration, restaure ton pc à une date antérieur.
